Computer won't run disk
Can't run OR eject the disk.
  • 27,725 Answers
If this is a cd/dvd drive you are referring to
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem
"you only need to do the following"
if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Posted on Nov 04, 2012
Can not get the mac pro osx 10 5 8 to start with the utility disk or with regular start up my on pilot lite keeps blinking
Put the Mac install disk back in. Try pressing command-option-escape to force quit. If nothing happens, then press command-control-power to force a restart. If that doesn't work, press and hold the power button for five seconds or so until the computer shuts down. Power up the computer again, and hold the option key so you can select the instal disc for startup. Run Disk Utility again. Sometimes you get a tangled file reference that requires several tries to undo - this could be calling the sleep routine instead of what it's supposed to do.
May 28, 2013 | Computers & Internet
Mac 0sx 10.5.8
The disk might not have a working OS on it.
It you have successfully run the disk utility the disk probably in full working order. I think that the OS on the disk is either missing, corrupt or not compatible with the computer you are running it on.
May 28, 2013 | Apple Leopard 10.5 Osx Mac Operating...
Disk won't eject
Normally all readers have a mechanical system that can be accessed from the front or the back of the reader to open using a small tool. Normally it's a little hole (like on smartphones) where you can insert a metal piece and push on it to eject the drawer.
May 30, 2017 | LG RHT599H 500GB HDD DVD Recorder with...
Music CD won't eject from Dell Studio 15 notebook
Open "COMPUTER" hold cursor over the Device CD/DVD right click scroll down to "EJECT" and click.
Nov 01, 2012 | Dell Computers & Internet
I am constantly receiving this message with a micro 2 GB cruzer, "The disk was not ejected properly. If possible, always eject a disk before unplugging it or turning it off. To eject a disk, select...
I have just experienced this problem with e 32Gb ScanDisk card. Every 40 seconds it dismounts with "The disk was not ejected properly. If possible, always eject a disk before unplugging it or turning it off." and the automatically remounts itself.
The card was formatted in my Canon camera and works fine, I also can read the files with iPhoto from the camera, however with a LogiLink card reader it has the above described problem on my MacBoook Pro with MountainLion OS.
Its about time Apple that you researched and found a solution!!!!
Hans Steller
Jul 04, 2012 | SanDisk Cruzer Sdcz36-002g-b35 2 Gb Flash...
I can't get my DVD disc to eject. It will play but won't eject? Any suggestions
You should try unplugging the DVD player from its power source then plugging it back in. Now try to open it and if that doesn't work than you'll probraly have to take it apart to get the disk out but sometimes the DVD players can get worn out or if you have a cheaper DVD player it might just be freezing up on you. I have had these problems before. I just took the DVD player apart to get my disk and then trashed it.
Jan 23, 2012 | GoVideo DV2150 DVD Player/VCR
CD stuck in disk drive and won't eject. Computer is XPS M1530
Manually eject:
1. There is a small hole on every CD drive
2. Take a paper clip and on fold it
3. Stick it into the hole on the CD drive
Additional Reference
Instructions on how to manually eject a CD drive
Best Regards,
Embraced Support
Fort Lauderdale computer repair
Sep 05, 2011 | Dell XPS M1530 Notebook
Hey my mac won't eject a disc. i have tried a lot of stuff and nothing happened. when i restart it the disk spins and doesn't sound stuck and when i used disk utility it said there was an error...
Resolution Tip: Make sure the CD or DVD disc is not in use. Quit all applications that are using files on the disc.
  1. Press the Media Eject key at the top-right corner of the keyboard.
  2. If that doesn't work, drag the disc's icon to the Trash.
  3. If that doesn't work, restart the computer, then hold down the mouse button or trackpad button while the computer is starting up, until the disc is ejected.
    To restart, choose Restart from the Apple menu.
Aug 16, 2011 | Computers & Internet
Disk drive keeps kicking the cannon software disk out
You don't need to use the Canon software.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Dec 25, 2008 | Canon PowerShot A590 IS Digital Camera
Computers & Internet Logo
282 people viewed this question
David Payne
David Payne
