Can not remove screw with hex key - Computers & Internet
  • 7,627 Answers
RE BOOT
Posted on Nov 07, 2012
What size hex key do i use to remove the 3 screws that hold the air filter on (2002 roadking fuel injected)
Unless they've changes something, they take a 3/16" hex key. They are standard size, not metric. If you're talking about the ones that hold the outer cover on, they are larger, 1/4 inch or larger.
Good Luck
Steve
Jul 15, 2011 | 2002 Harley Davidson FLHRCI Road King...
How do i remove the caps covering the bolts on the handlebar
The bolts are taken off with a hex key (allen wrench). The caps are pressed into the hex key opening. The corner of a razor blade or a tiny electrical screw driver slipped between the cap and the screw will allow you to pry it straight up. They can easily be reinstalled by pressing them in with your thumb.
May 28, 2011 | 2006 Yamaha XVS 250 Drag Star
How do I replace the chuck on a craftsman model 315.101370 hammerdrill
The chuck can be removed and replaced with a new one.
Unplug the drill.
Insert a 5/16 in. or larger hex key into the chuck of the
drill and tighten the chuck jaws securely.
Tap the hex key sharply with a mallet in a clockwise
direction. This will loosen the screw in the chuck for
easy removal.
Insert the hex key into the chuck and tighten the chuck
jaws securely. Tap sharply with a mallet in a counterclockwise direction. This will loosen the chuck on the
spindle. It can now be unscrewed by hand.
Feb 15, 2011 | Craftsman Drills
My keyless chuck is open and will not close in order for removal. Drill motor works fine. Manual states that hex key opens it for removal but it must be closed first in order for the key to work. I cannot...
Every chuck I have changed on a portable drill has a hex screw in the back/bottom and you can only get at it if the chuck is open. look down in and see if there is a hex screw. It very well could be reverse threaded. This holds the chuck on/ sometimes in conjunction with threads on the chuck itself. So you may need to unscrew the chuck after you remove the hex screw. Again this may be reverse threaded (lefty-tighty rightly-loosy)Now I can no say for certain that this is the case with your chuck.
Feb 12, 2011 | Craftsman Drills
How do i access the battery
It appears the battery is under the left side of the gas tank.
First get a 3 mm hex key and remove all the side panel screws and remove the screws that hold the cover around the gas filler cap, and remove the two plastic side panels. After the screws are out the side panels the panels slide forward and will come out. There are two hex screws (size ?) that have to be removed to release the fuel tank. One is under the tank and is accessed from the rear with about a 1 foot extension for the hex bit. The other is on the front rt side and is quite obvious. There is enough fuel hose on the tank that you can simply prop-up the front of the tank with a piece or wood or anything convenient and get access to the battery. I put battery tender leads on my 696. Hardest part is removing all the small screws that hold the side panels and cover for the fuel tank.
Oct 21, 2009 | 2008 Ducati Monster 696
How to reach the battery on 696 monster ducati, and install charger.
Under gas tank cover
Oct 20, 2009 | 2008 Ducati Monster 696
How do you take the seat off a 2006 Eliminator 125 to fit soft luggage?
My 2006 125 Eliminator just got a reupholstered seat. Remove hex bolt at the very rear of seat. Remove right side plastic cover over battery (open with key, pull off cover) .Remove plastic cover on left side (2 large phillips head screws.) Remove 2 stainless hex heads on each side of bike that hold chromed plastic sleeves under passenger part of seat (4 hex heads). Then remove 2 smaller black hex heads (one on each side) under point where tapered passenger part of seat begins. Slide seat toward rear of bike do disengage from metal lip that holds down the front.
Be sure to use metric hex wrenches. 15 minutes or less off or on.
good luck
ride easy
Oct 18, 2009 | 2006 kawasaki EL 125 Eliminator
Moen Posi-Temp Shower Handle removal
I hate to say this but maybe the inside of the allen screw has been rounded out by a previous worker. You can drill the screw out and replace the handle with a new one. NOTE: Moen replacement parts are not cheap!
Jul 08, 2009 | Moen & Posi-Temp Single Handle Shower Or...
How do I remove the chuck off a milwaukee hole hawg. Ihave removed the screw inside the chuck and have tryed to trun it off but it wont move.
With the lock screw removed (it's a reverse threaded screw) you can procede with getting the chuck off the drive shaft.
OK, you need to put a 1/4" or larger hex key wrench into the chuck and tighten it in place with the chuck key. Put the short end into the chuck.
Once you've done that, place the drill chuck, only the smooth part, not the part with the teeth, on the edge of a solid workbench. Now hold the chuck with the hex key (long end) at a 30 degree angle off the bench top and strike the hex key with a hammer going counterclockwise (looking at the front of the tool) to loosen the right hand threads that hold the chuck to the shaft (spindle). You should now be able to easily remove the chuck by hand at this point.
Here's link to a manual for your Hole Hawg that will also show a nice illustration of the removal method, to make it a bit easier, as well as giving you other good info about your drill. Print a copy for your files and future reference.
http://www.milwaukeetool.com/CMS/Diagrams/58-14-1782d9.pdf
That should do it! Hope you find this Very Helpful and best regards!
Jun 13, 2009 | Milwaukee 1670 1 Drill 1/2 900 Hole Hawg
Computers & Internet Logo
15 people viewed this question
David Payne
David Payne
