Question about Singer Commercial Grade Serger
Needle screw needed for a commercial singer serger
I need a tiny screw to hold the left needle in place.
  • Singer Master
  • 18,391 Answers
Singer profinish serger
This sounds like a timing issue. You need a professional.
Jan 18, 2014 | Singer Vacuums
I have a singer 600E touch and sew. I accidently took out the bobbin case and can't seem to get it back in. Can you please tell me how? Thanks
Open the slide plate, and remove the needle plate.The needle plate should be raised by a lever on the right hand side of the bed.Move it to the left, then raise the needle or take it out.It is also easier if you remove the sewing foot.Once you have the slide plate moved towards you you will see a black piece of metal in the front right corner of the bobbin area.Lift it up and slide it to the right.Position the bobbincase with the metal flap that locks the bobbin in towards you so when you lift it up it is on the end closest to you.Make sure the bobbin case is in the groove of the hook(the round thing that spins when you turn the handwheel)once you have the bobbin case in position you bring the black metal pieceover to the left and it will drop down to secure the bobbincase.Turn the hand wheel towards you the bobbincase should stay in place and the hook should turn around it.If it turns smoothly replace the needle plate,close the slide plate,screw the foot back on and replace the needle.You are done. www.sewvac.com
Feb 01, 2011 | Vacuums
I have a Singer 478 sewing machine and need to replace the top gear on the verticle shaft. Is there a repair manual for doing this. There was not category expert on this so please direct to the correct...
This is an easy fix. a lot disassembly required, you will need to gain access through the belt side to the singer cover plate,four clips hold it on from the back side. Once that is off, two screw hold small access plate which is under the letters Sin, remove plate, rotate shaft to access screw through opening which holds Vertical Top Shaft Gear, Singer # 155819 in place. Remove bottom cover, locate belt pulleys (2), remove cam tensioner, with a hex wrench remove pulleys, this makes it easier to remove lower belt. with a long thin, blade screwdriver, loosen screw on gear (through small access cover), slide shaft downward Rand R gear, reverse process, done. Be sure you document removal, take pictures, mark references with marking pen.This makes reassembly easy. I just replaced mine, I am handy but not an expert, hope this helps you...
Jan 27, 2011 | Vacuums
I need a threading diagram for a Singer 16-188 sewing machine. TIA Mike
The upper thread flows from the left to right as it goes through metalstems (posts) with holes, along the top of the machine head, and thendrops down and passes over and under the upper gension disk and thetake up spring.  Then, moves back up to the take up arm (which moves upand down like a goose's neck when turning the handwheel) then startsthe trip down to the needle, going through a couple metal loops (calledthread guides) and lastly through the needle thread guide and throughthe needle eye, as I recall from left to right (?), this part is moreobvious when looking at it.
Heres a link to a manual for that machine. hope this helps
http://parts.singerco.com/IPinstManuals/16-133_CLASS_16.pdf
Jan 13, 2011 | Singer Vacuums
I just bought the Singer 1409. The needle is off center to the left. So far off I cannot use the zipper foot. Is there way to adjust to center or do I need to exchange the machine for another one?
If, it is like my Brother machine (CS6000) the needle is set to the left, I have to move it with the button. See, if yours is like that, If not, call Singer at 1-800-4singer Monday at 9am and ask them what is the thinking that decided this so that you cannot even use a zipper foot? Maybe, there is a trick that they do not make clear in their manual. Very strange.
Jan 02, 2011 | Singer Vacuums
Singer Commercial Grade Serger Logo
52 people viewed this question
Top Singer Vacuums Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Vernon Taylor
Are you a Singer Vacuum Expert? Answer questions, earn points and help others
