Question about AOpen F70PS 17" Flat Panel LCD Monitor
Green Power light blinking
I have an AOpen F7OPS monitor. My daughter pressed the power button to turn off the monitor. When I pressed the button, the power light started blinking and doesn't display a picture. I tried unplugging everthing and restarted the computer, but I don't get a picture...just a blinking green light.
I connected a new VGA cable, but still have same result.
My PC will display through the old monitor.
any idea?
  • 585 Answers
Check the resolution in the Windows while connected to the old monitor. If greater than 1280 X 1024 and/or the refresh rate exceeds 75 Hz, the monitor may not respond. But you should at least see the BIOS splash when the computer is turned on. If that does not appear, maybe a problem has occurred in the monitor. Another indicator: if you turn the monitor power button off and then back on, you should get some sign of life such as "no signal", or "out of range". If nothing appears, that would indicate some problem within the monitor.
If you find my suggestions to be helpful, please share with us some details so that others may benefit from knowing the whole story. Thank you!
Posted on Jan 11, 2009
My AOpen 19" LCD Flat Screen Monitor (Model F2915) is like new and works perfectly except for one thing. The push button power switch located on the top of the monitor has broken off and fallen insid
Certainly, if you jumper the connections to see which ones turn the monitor on or off, then you can go to an electrical supply place and get a micro switch and wire it in in place of the power button, or perhaps find a type that is flat that the power button can press. What you need to determine is if it is a push-on, push -off type switch, which always stays on or off depending on position or if it is a momentary interrupt switch where the button pressed momentarily turns it on and then releases and a second press connects the circuit to turn it off. You can do this by testing with your jumper wire, attach it and if the monitor stays on when you remove it, then goes off when you attach it again, you need the second type switch, if it goes off when removed, you need the always-on always -off first type switch. .
Mar 07, 2012 | AOpen F90GS 19 inch Monitor
My aopen when you turn it on the green light kept blinking
Try it on another PC first, if it still does not work and you want to DIY repair, then please read below:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 13, 2010 | AOpen F70PS 17" Flat Panel LCD Monitor
The power button is not working it blinks a green light
Disconnect the display from the Computer and remove its power plug. While the display is turned off, press and hold the power button for 30 seconds. After two minutes connect the power cord and the display cord to the Computer and the power source and turn it ON.
If the power indicator on the display keeps blinking, then it's required to open it up to repair it.
Feb 26, 2010 | Dell E172FP 17" LCD Flat Panel Monitor
We get a blinking green light response where the ''On'' button is on our Compac presario SR 1111 NX and cannot get the computer to turn on. Is this a battery problem of some sort? Can I fix it? The...
take out all the cables from the back of computer,press the power button for 1 min and then plug in only keyboard,mouse,monitor and power ,it will work
Feb 09, 2010 | Computers & Internet
"monitor has a green tint AOpen f2915"
moz-screenshot.png The solution: a hidden menuwithin the main menu itself. Hold the Menu button down while pressing Power topower on, and release power button only when the screen comes up, still holdingthe menu button. The menu will appear and there will now be a hidden selection,"Auto Color", printed in a red-on-black font at the bottom of themenu. Use the +/- buttons to access it, and press Menu. My green/yellow tintwent away! Now my picture works great, and the setting lasts throughAuto-Adjusts and Resets!
May 09, 2009 | AOpen F2913-8S Monitor
My aopen f2925 monitor has a green tint.
The solution: hidden menu within the main menu itself. Hold the Menu button down while pressing Power to power on, and release power button only when the screen comes up, still holding the menu button. The menu will appear and there will now be a hidden selection, "Auto Color", printed in a red-on-black font at the bottom of the menu. Use the +/- buttons to access it, and press Menu. My green/yellow tint went away! Now my picture works great, and the setting lasts through Auto-Adjusts and Resets!
Apr 08, 2009 | AOpen F70PS 17" Flat Panel LCD Monitor
Flashing green power light - Black screen
I had the same problem with an AOPEN 17' lcd that was left behind at a rental property... I plugged it into my dell dimmension 4400 in place of my old analog. It worked fine the fist night, and got up and when turned it on again it had the famed green blinking power light. I switched back to the analog, and just disappointed I plugged in the AOPEN to another power source, and power came on a steady red light. I plugged it back into the puta and it came on again. I have not turned the monitor off again for fear of the blinks, and has been working great for close to a week now. Hope it helps someone else out there. Richard
Mar 27, 2008 | AOpen F75PS 17" Flat Panel LCD Monitor
Comp won't start
maybe there is something wrong with your power supply.. i think you need to change it
Mar 01, 2008 | Computers & Internet
3yr old got ahold of monitor
ok, get to the event where you get this to happen "...then turn it back on the monitor does come on normally...", but just after power-up, press the F8 key to go to safe mode. If nothing visible, press ENTER anyway...get to safe mode yet?
Oct 27, 2007 | Computers & Internet
AOpen F70PS 17" Flat Panel LCD Monitor Logo
433 people viewed this question
Top AOpen Computers & Internet Experts
Michael Galve
Michael Galve
David
David
Alun Cox
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
