Question about Gateway C-140 C-140S C-140X C-140XL M280
Screen is real dim, but I can see if use another monitor
My screen is real dim, I can barely see image. Gateway c140 X tablet. I can connect another monitor and see on that though.
  • Dan Semi Nov 04, 2012
    I have replaced the inverter board and I don't see a difference. I can see dimly lit shapes of the content on the screen, but very dimly. If I hook up another monitor with a VGA cable It displays on the other monitor. what else could be causing this?
    Scholar:
    New Friend:
  • 115 Answers
The back light might have failed. You will need to have tis repaired if you cant do it yourself.
Posted on Apr 17, 2014
Gateway Laptop screen goes dim.
Please connect it to external monitor. If it is not affected there. there, it could be an issue with backlight or inverter.- a hardware issue.
Jun 03, 2013 | Gateway Computers & Internet
Why is my Gateway 4028GZ screen black
The display on this laptop is backlit. What that means, in a nutshell, is that the image on the display prevents the output from a constant light source (the back light) from showing through, thus giving a usable image on the screen. From your description, the backlight is no longer operating. This can be an issue with the LCD display panel, the backlight power module, our (less likely) a power trace on the motherboard. Repair would likely cost as much or more than replacing with a used laptop and just transferring your hard drive. If you choose to replace and swap hard drives make certain that the interface on the new laptop is the same as your Gateway's.
Jun 08, 2017 | Gateway 4028GZ Notebook
I have a Gateway 450ROG with very dim video on the display, I can hook up an external monitor and the video on the external monitor is fine but still very dimvideo on the monitor of the laptop. You can...
Hello !
Since an external monitor works, it is the display's backlight or inverter board.
If you were experiencing discoloration in the screen (pinkish lower light hues) before it failed, that would indicate a CCFL backlight issue. If the screen suddenly went dim on you rather than a slow degradation the inverter would be indicated.
In either case, a technician in your area should be able to help. Evaluate to see if the repair is cost-effective.
Hope this helps.
Oct 26, 2010 | Gateway 450ROG Notebook
Gateway M-1631u screen keeps going to full backlight power
Connect an external monitor to your laptop. If it the image is ok on the external monitor and bad on the laptoop screen it means one of more of backlight/inverter/screen is defective. Have it repaired by a professional.
Oct 09, 2009 | Gateway M-1628 Notebook
Monitor
If you see a very dim image or black screen or flicking image on the LCD screen it means you have a backlight problem.
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Mar 25, 2009 | Gateway MX3215 Notebook
Dell Inspiron laptop monitor is gone very faint
Connect an external monitor to the laptop and power it up, if you see a clear image on an external monitor, this means your video card is OK.
If you see a dim image or flicking image on the LCD screen it means you have a backlight problem.
Mar 14, 2009 | Dell Inspiron 6000 Notebook
My Gateway mx7118 lcd flickers whenever screen is opened,closed,
If you see a dim image or flicking image on the laptop's LCD screen it means you have a backlight problem.
Mar 13, 2009 | Gateway MX7118 Notebook
I can tell the power is on but I get nothing on the screen.
Mar 12, 2009 | Gateway MT3418 Notebook
Just replaced a cracked screen in a toshiba a105-s4074....when i turn it on i can barely see the screen....it is very dim.....when i plug the old cracked 1 up it works fine....any suggestions?
If you see a dim image on the LCD screen it means you have a backlight problem.
Mar 10, 2009 | Toshiba Satellite A105-S4074 Notebook PC
VGA port connection to old style TV
Right click an empty spot on your desktop, select properties. Click the Settings tab. Right click the gray-ed out monitor, select enable.
To push the image to that screen, press the Function (FN) key and F4 normally.
Feb 16, 2009 | Gateway CX200S Tablet PC
Gateway C-140 C-140S C-140X C-140XL M280 Logo
76 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
