Question about Husqvarna Garden
Identifying the hot wire on a clutch for husqvarna yth1542xp
Yth 1542xp
wadembly
  • 513 Answers
SOURCE: husqvarna yth 1746 mower deck won't re-engage once shut off
the safty swich is getting hot & wont alow it to engage again untill cool
Posted on Jul 08, 2009
  • 21 Answers
SOURCE: I have a Husqvarna Yth 180, the lawn mower shut
try unplugging the pto then start the mower next engage the blades and see if the fuse blows if it does the problem lies in the mowers wiring if not the problem lies in the pto. hope this helps
Posted on Jul 27, 2009
harlan301
  • 205 Answers
SOURCE: husqvarna yth 2348how to check and see if battery is charging and
there are one to two wires that come from under the fly wheel. thy are attached to our stator (charging sys) the flywheel has a magnet on it. know the wires my or my not go to a voltage regulator than a fuss and to ether the solenoid battery side, or to the battery. the easy way to check is on your battery with a meter. check battery fri st than start your engine to see if the amps come up should be around 12.9 to 14.6 volt. make sure your at full throttle. good luck, let me know.
Posted on Oct 16, 2009
  • 146 Answers
SOURCE: Husqvarna YTH 2042 lawn tractor
If it really 'lugs', meaning the engine gradually chugs slower and slower as if it's struggling, then it could be a belt problem, but I'm going to guess it just quits, which suggests a problem with the seat safety switch. Look under the seat, take out the safety switch, and tape it in the pushed-in position. See if the tractor runs now. If so, the switch is the culprit - either it failed, or the mounting is wonky so it doesn't activate when you're in the seat.
Posted on Jun 05, 2010
SOURCE: Husqvarna YTH 2448 mower PTO switch is getting hot
I have a husqvarna yth2448 mower whitch the pto switch burns out and pull apart .Blade stop turning and mower remains running
Posted on Sep 16, 2010
Husqvarna yth 22v42 cable clutch routing diagram
Contact Husqvarna directly to request the diagram.
Sep 12, 2017 | Husqvarna Garden
Husqvarna YTH 2448 shuts off when I let out clutch or engagae mower blades
Hi, check or replace the switch on the seat, basically its not telling the safety system that you are on the seat. Regards Phil.
Jul 07, 2012 | Husqvarna Garden
What type of oil do you use in a Husqvarna YTH1542XP trans-axle ... and , how much ?
For the trans-axle use 2 quarts and use 10w-30 any brand that you would like, be careful when unscrewing the cap you do not want hot oil over you.
Thanks.
Jul 20, 2011 | Husqvarna Garden
Husqvarna YTH 2448 mower PTO switch is getting hot and melting the plastic internal parts. Any ideas on what is causing the overload? The mower deck will shut off when the switch melts and the push/pull...
The problem with an electric cluch is that when the engine is running without the clutch engaged the clutch can turn into a dynamo which then passes power back up to the switch, most machines will have a diode close to the clutch in the wireing to stop the current flowing back to the switch, so i guess the diode is bad on your machine and power is flowing back to the switch and melting it,
Nov 08, 2017 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
My Husqvarna YTH 145 just clicks when trying to start it
that just leaves the battery, the terminals, or the wiring.
May 23, 2010 | Husqvarna Garden
I would like to know the part number of the electric clutch on my Husqvarna YTH1700 mower (42" cutting deck).
went on the husqvarna website and couldn't find a yth with a 42 inch deck - found a yth1746, though and the part number is 532145028
Aug 20, 2009 | Husqvarna Garden
Husqvarna yth 1746 mower deck won't re-engage once shut off
Jul 03, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Garden Logo
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
