Question about Hunter Fan Company 5/1/1 Programmable Thermostat
Can not get the heat to work only cold air
We just installed a hunter programable thermostat and the heater is not working. Did we connect the wrong wires? The one that came out was an old Robert Shaw that didn't even have the same letter coded wires as the new one.
Two questions what brand heater and what are the wire colors at the t-stat
Posted on Jan 04, 2009
We put in a hunter thermostat and now our central air conditioning unit is blowing cold air with the heater on.
Susan,
This means that the new thermostat is wired wrong. You did not post the make and model of the new one, the old one and possible the furnace and we need those in order to check your wiring and compatibility.
Oct 29, 2017 | Hunter Heating & Cooling
Honeywell thermostat blows cold air on heat
Thermostats don't actually blow anything, the heating system might though. Check the breakers for your heat system, then call a heating specialist. They're really not that expensive.
Oct 06, 2014 | Honeywell Heat/Cool Thermostat
Hunter 44272 Not turning on heater
i am recommending you try again to call to the service man. The reason is simple you change it and they have all the wiring diagram for do it quickly. Get support via ONLINE or chat or phone.
Maybe you have some wrong wires connect
God bless you
Oct 08, 2012 | Hunter 44272 5-Minute 5-1-1 Day...
Ive tried to program the heat in my house, but its always too cold, how can i turn on the heat
the thermostat may be in the wrong location for it to work correctly. make sure its in a well heat vented room and not in a closed low volume room. it you want heat push the "hold" button and set a temp that works for you. when done push "run program" buttom to run what you have set into the program.
Jan 31, 2011 | Honeywell Electronic Programmable...
Bought 44155c hunter thermostat air won't turn on.
If unit worked before you tryed changing t-stat then its possible the t-stat wires are shorting each other out.take t-stat back off cut back wires a good 6 to 10 inches or if you dont have that much wire to play with just cut back as far as you can and make sure there is no bare wire touching each other ,then just to test unit to make sure its working ok twist yell.,red,green together this should bring both units on and should blow cold.if this works up to this point on the new stat read directions closely there might be a jumper wire in the stat that needs connected usually from y1 to w1 you would install a jumper wire .see if this helps if not write back i have 1 other solution.i hope this helps
Sep 14, 2009 | Honeywell Programmable Thermostat Heater
Air and heat have both been running on Hunter 44155C
There should be a switch on the thermostat.
AC-OFF-HEAT
And another switch
FAN ON-OFF-AUTO
Normally, you just set it for heat or AC and set the fan for auto. If it isn't wired correctly, the switches won't make any difference. It will either run all of the time or not at all.
Feb 17, 2009 | Hunter Fan Company 5/1/1 Programmable...
Heater blows cold air
the electric motor that open the heat door looses electrical connection there by the door stays on cold / it is located under the a/c heater assembly / which requires removing the whole dash and heater assy// also bleed all air out of coolant system
there are three doors / 1/ a/c heat 2/ mode /defors 3/ recurculation dodgeboy6069@yahoo.com
Jul 19, 2008 | 2004 Jeep Wrangler
Hunter 44360 thermostat wiring
OMG! has anyone came up with a solution? I have the same problem as mlc3530b
Mar 08, 2008 | Hunter Fan Company 5/1/1 Programmable...
How to wire hunter 44155
Go to the hunter web site. They will have the proper wiring diagrams on the site. If you cannot do that pick up a basic wiring book at your local electric parts supplier. the place you got the thermostat would be a good start. I do know that menards has some books in the electric area that would be a great help to you. You also will need to be sure that the thermostat is able to handle both air and heat. many only do heat. If this does not help let me know and I will try and get more information to you
Feb 07, 2008 | Hunter Fan Company 5/1/1 Programmable...
Hunter Fan Company 5/1/1 Programmable Thermostat Logo
140 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
