Squealing noise when turning on and switching sources. The picture also has scan lines seen going up the screen.
I'm pretty sure the squealing is from the flashback transformer but unsure if this is causing the scan lines.
    Sergeant:
  • 214 Answers
I would also guess you are hearing a high voltage squeal. Your only options are using equipment to test the flyback or just replace it and see if it fixes the problem. As for the scan lines that may be a totally different problem. I would check capacitors and make sure they are good. If they are good you would have do some testing on other components in the TV as it could be anything and can't give you a straight forward answer on that. Good luck!
Posted on Nov 03, 2012
  • 1694 Answers
SOURCE: RCA F32450 ATC113 chassis Dead & Squealing
IHVT # 257805 or ASTI 2078 = 20.00.......................T.
Posted on Dec 13, 2007
rey jr
  • 149 Answers
SOURCE: Samsung TX-P2670WH 26" tv squealing
hi there, you do have a problem at the hozintal section, check the FBT and some parts at the horizontal section and at the power supply section. ty
Posted on Jan 01, 2008
  • 453 Answers
SOURCE: RCA F36650 36" TV
is the squealing noise from the back of ur set , if so it is ur flyback transformer
Posted on Jun 28, 2008
SOURCE: Squealing noise powering up in TTM-2401 Polaroid TV
Its a different model number but this should be your fix...
http://www.badcaps.net/forum/showthread.php?t=6215
Posted on Jan 09, 2009
SOURCE: My Philips 20' TV Dead condition
Ok clicking tends to a relay trip do to over power caused by a dead fuse. unscrew your tv after you unplug it look at the board pull the fuse and replace its usually says like 250v blah blah blah and that should do you if that doesn't do the trix then it may be a blown compacitor wich you can't fix your self, unless educated in soldier repair.
Posted on Jul 12, 2009
How can I figure out what's squealing? Where can I find belt diagrams?
I had something similar with two seperate vehicles after replacing everything I could think of it turned out to be a bad bearing in my alternator on both vehicles.
Aug 04, 2014 | 2005 Hyundai Elantra GLS
Can't find the source of the squeal
Year make and model ??
The belt could be glazed and slipping even if it is tight.
You could have a weak belt tensioner too.
The noise when the ac or heat is turned on can be the extra load from the ac compressor or the alternator. The compressor cycles on and off especially in defrost mode.
The load from the alternator is the first noise of the day. As the belt warms up it becomes better at handling the load of the accessories.
Even tho the belt looks fine, you may have to replace it to get rid of the noise.
Feb 13, 2013 | Cars & Trucks
2000 montero sport: There's a loud squealing noise coming from the engine. What could be wrong?
Squealing is most common with loose or worn belts, I would start by replacing the drive belt on the front of the motor and go from there, Its easier to troubleshoot a squealing motor if you know that the belt or belts are good.
Oct 20, 2012 | 2000 Mitsubishi Montero Sport
I am hearing a squealing noise when I turn left....
I'm having the same deal. High pitch when turning and a low noise other times.
The bearings may be going out.
Jun 13, 2012 | 1997 Chevrolet Cavalier
My son has a 2002 GMC Sonoma crew cab that is making a grinding noise when making turns, both left and right. This may be an unrelated problem but the tires are also squealing when taking off from a stop,...
the grinding noise sounds like the axle shaft joints are no good and need replacing.also the wheel bearings could be so bad that they are causing this problem.i have seen where badly worn out brakes have made a grinding noise on turns.the tire squealing i don`t think is related to the grinding noise.check out the other things just in case it is changing the tire angle which could cause squealing.
Apr 05, 2011 | 2002 GMC Sonoma Extended Cab
Really loud whirring/squealing noise
Yes, It is still safe but very annoying...
The source is probably the guide rollers for the drum or the belt tensioner pulley. To know for sure you will need to pull the dryer apart and turn it by hand slowly and see where the noise is coming from...
Heatman101
Mar 03, 2010 | Whirlpool Dryers
My tv, just shut off! the screen does not turn on, and makes a squealing noise! what is wrong?
That is the classic case of the color wheel going out on you. The color wheel has ball barrings that tend to break and cause friction within the wheel. It'll start squealing loudly when it becomes stuck. Before it broke, did you notice the color going out or a fuzzy picture with poor skin tones? That's the color wheel!
Feb 04, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
Humming or squealing noise when tv is turned on (model 32LG30)
Be sure you have installed the stand scresw weather or not you are using the stand.
The back panel can vibrate without the screws.
Other sources of a hum are the coils on the power supply.
The power supply would have to be replaced to solve the issue.
Jan 19, 2010 | LG 32LG30 32 in. LCD HDTV
Hanns G 19" LCD monitor Screen Problem
D3mon,
Looking at the photo that you took... You've defintely got a damaged panel. My advised get a new one...saved you the headached and $$$....
Oct 10, 2008 | Hanns.G Corporation HU-196DP LCD Monitor
RCA D61W20 has become a big useless decoration
I know exactly what is wrong with your TV I charge 315.00 in my shop to repair here i get paid 0$$$$
I get paid $50.00 up front to look at set and then determine what the problem is Defection board 125.00 plus 190.00 labor - 50.00 repair cost 265.00 plus tax SSB board 325.00 plus labor/ wondering can you solder if so start out by resoldering everything on Deflection board solder all pinns on Flyback transformer squealing noise is caused by coil in high voltage area LL037 resolder it then take glue gun and glue on top and around it. all so check second ribbon connector that feeds over to SSB board make sure it is installed good and there is 3 capacitors that go bad on same board 2200uf 16v two 220uf 35v located in front of board they are green with gold writing you can try all of this or order new Deflection board 1-800-648-6657 union electronics's
Oct 01, 2008 | RCA D61W20 61" Rear Projection Television
Televison & Video Logo
19 people viewed this question
Top Televison & Video Experts
Electro Med Services...
