Question about Refrigerators
Wiring refrigerator compressor relay
Relay has 4 prongs and only 1 wire. Which prong do I connect wire to?
    Top Expert:
  • Refrigerators Master
  • 9,472 Answers
Posted on Nov 04, 2012
  • 11 Answers
SOURCE: PTC relay on compressor
Try to find the "secret" wiring diagram.  Almost all refrigerators have a hidden paper wiring diagram.  It is usually tucked into a slot under the refrig, behind the front grill, or otherwise on the inside of the lower rear cardboard fan cover, or sometimes inside the back area near the fan.  While you're in there, it's a good practice to clean the coils.
Posted on Oct 23, 2007
SOURCE: Kenmore refrigerator PTC relay for compressor
This is for a Kenmore PTC relay that I just pulled from my fridge. It dosn't have an ice maker. Hope this helps.
Pin 1 = White
Pin 4 = Blue
Gold Pin = Red
Posted on Nov 05, 2008
  • 531 Answers
SOURCE: Refer will not get cold.
my advice to you call service
Posted on Apr 02, 2009
mrfixit3667
  • 262 Answers
SOURCE: The compressor prongs and relay connection burned
if you have 50% of that pin left, I would try a hard start kit first. the risk wold be under $50.00.
Posted on Jan 27, 2010
bobicehouse
  • 1524 Answers
SOURCE: Free Refer Hotpoint csx27dma. Owner had two new
From cabinet you have three wires. 2 Orange,and 1, Black
1 Orange goes to on side of run capacitor the other Orange goes to the (2) R on the relay. The Black goes to the overload (round black disk). 1 White wire connector on end goes to run capacitor the other end connects to the (1) S on the relay.
The run capacitor is a small black cube like device with two prongs.
Posted on Oct 27, 2010
Hy My Beko f freezer compressor gets very hot (can hardly touch it). Unable to source replacement ptc switch although the unit still restarts, it looks burned! Prob causes? Any suggestions please?
TRY THIS
To check ur compressor with multi meter:
Disconnect and remove the relay and capacitor from compressor, sometimes located next to compressor in a casing.
You wills see 3 prongs coming out of compressor. 1 goes to ur start winding, 1 goes to ur run winding and the center goes to ur ground or COM
Place ur meter connector or prong on the start prong and the other on the ground (center prong) take note of the reading in OHMS for example 5 ohms.
Next place meter prong on run prong and the center ground prong agin. Take note of the reading in OHMS. Example 4 ohms
Next place meter prong on the start prong and the other on the run prong, now take note of the reading example 9 ohms. Now match the total of this ohms test with the total of ur two separate test. 9 ohms, if they match ur ok give or take 5 percent plus or minus. One more test to make to test of there is a short in compressor attach meter prong to ground prong and rub the other end of meter prong to metal ( scrape the metal clean of paint and test on metal surface not painted surface. If it shows continuity or ohms, u have a short in ur compressor. It should show infinity
God is so good: so this is why I give free advice so please thank him not me.
TO REPLACE RELAY AND CAPACITOR WITH A HARDSTART KIT YOU CAN USE
A 3 in 1 start kit for compressors sizes 1/4 through 1/3 HP. And a 5 in 1 for higher H.P. (BE SURE TO MATCH WITH UR COMPRESSOR MODEL NUMBER AND TYPE) The kit includes relay, capacitor, and overload device, pre-wired. The kit will replace all 3 electrical components on capillary refrigeration systems. For newer systems with a run capacitor use proper kit. For smaller horsepower compressors useTJ90RCO810.
The wire set up is as follows the red wire goes to the right side of compressor prong, the white wire to the left side prong, the black wire to the center prong, and the 2 other black wires go to the power and the ground connection
http://www.appliancerepair.net/refrigerator-repair-1.html
Refrigeration System Basics Chapter 1
Feb 11, 2017 | Beko Refrigerators
Hi the condenser fan not running on ge refrigerator model PFE29PSDASS serial # HZ500118 can you please explain how to test diagnosE it the picture is for J2 plug .thanks
Condenser
Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush and your vacuum cleaner to clean the coils of any lint, pet hair, etc. You may not be able to get to all of the condenser from the front, it may be necessary to clean the remainder of the condenser from the rear of the refrigerator.
May also need to check the defrost timer, u can get by and test manually by placing a small screw driver into the tiny slot or hole underneath the timer and turn slowly clockwise till u hear 1 click. this will engage ur defrost cycle in about 15 minutes u should be able to come back and feel the heat in freezer as it melts the ice providing ur terminator is not bad?
Another way to test it is with a multi meter. Remove timer it from fridge and you will see 4 prongs numbered 2,1,4,3 in that order. Place ur meter prong on prong 1 & 3 (if your fridge has a capacitor wired in series with the windings, then u check for micro fares rather than OHMS) If u cannot confirm this test, still try the next.
Take ur meter prong and connect to prong 1 & 4, it should read resistance or ohms ( closed) now remove prongs and place on prong 1 & 2, this should now read infinity or open (no ohms) now take a small screwdriver place it in the tiny hole or slot under the timer. Turn it clockwise slowly till u hear 1 click. Now ur 1& 2 should read closed ( showing ohms or resistance) now place meter prongs on 1 & 4 and you it should now show open ( or no resistance - no ohms) this is how u know ur timer is good, Remember when testing for ohms ADJUST meter to use a high ohms rating in the thousands as the resistance is very high in OHMS. And adjusting to low ohms rating may give a false reading or not show the proper resistance..
THE COMPRESSOR:
If you hear a clicking sound coming from the back of your refrigerator/freezer, then the problem is most likely the compressor, relay and or capacitor is overheating or not getting proper power and will not start.The compressor is the component on your refrigerator that allows your refrigerator to cool. If this component is not working properly your refrigerator will stop cooling. Most of the time the compressor is not the component that has failed.
Disconnect and remove the relay and capacitor from compressor, some located next to compressor in a casing.
You wills see 3 prongs coming out of compressor. 1 goes to ur srtart winding, 1 goes to ur run winding and the center goes to ur ground.
Next place meter prong on the start prong and the other on the run prong, now take note of the reading example 9 ohms. Now match the total of this ohms test with the total of ur two separate test. 9 ohms, if they match ur ok give or take 5 percent plus or minus. One more test to make to test of there is a short in compressor attach meter prong to ground prong and rub the other end of meter prong to metal ( scrape the metal clean of paint and test on metal surface not painted surface. If it shows continuity or ohms , u have a short in ur compressor. It should show infinity
Lastly you should also check ur THERMISTORS in the freezer and fridge section for continuity OHMS and for amount of OHMS current being put out. In most models around 13000 ( give or take 150 ohms) ohms is required.
Read more:
http://removeandreplace.com/2013/10/31/fix-refrigerator-freezer-wont-cool-freeze/#ixzz3WDEo5NDJ
REMEMBER GOD IS THE REASON FOR GOOD ADVICE"
Refrigerator Is Not Cooling What To Check And How To Fix
Oct 08, 2016 | GE Refrigerators
MAYTAG MODEL MTB1521ARW FRIDGE CKT IS RUNNING BUT COMPRESSOR STARTS AND AFTER 2 SEC ITS STOP .EVAPORATOR AND CONDENSER FAN IS RUNNING GOOD. WHATS THE REASON?
Condenser
THE COMPRESSOR:
Read more:
Jun 04, 2016 | Maytag Refrigerators
My Samsung rs20nrsv side by side has issues where compressor cuts off but does not come back on unless you unplug and replug it so what can you do
Fridge not starting? CLICKING? FIRST ALWAYSCHECK FORpower at the outlet,checkfor 120 volts.
MAY HAVE A BAD START RELAY OR CAPACITOR ON THE COMPRESSOR , CAN BUY A INEXSPENSIVE 3 IN 1 HARDSTART KIT AND BY PASS THEM , NOT THAT HARD TO DO, COMES WITH INSTRUCTIONS> BY THE WAY DO U HEAR ANY CLICKING SOUNDS FROM COMPRESSOR? BUT U MAY ALSO WANT TO CHECK UR COLD CONTROL THERMOSTAT IF IT GOES BAD U MAY GET A NON START ALSO HAVE IT CHECKED FOR PROPER VOLTAGE AND OHMS RESISTANCE WHEN IN THE ON POSITION
A BAD DEFROST TIMER though seldom CAN SHUT DOWN COMPRESSOR HAVE IT CHECKED WITH MULTI METER.
AT TIMES YOU MAY HEAR THE COMPRESSOR CLICK OFF AND ON OVER AND OVER. Signs of a bad start relay or capacitor. Check with an OHMS meter for continuity (ohms) and voltage, capacitor can be checked for Microfares. ( if in series with the windings)
Feb 06, 2016 | Samsung Refrigerators
How do the wires get reconnected to the starter relay on tfx26apdaww
see pics To check ur compressor with multi meter:
Jan 13, 2016 | GE Refrigerators
Front panel has no lights working, inside main light still works and turns on, top temperature control is off. Whats wrong?
Dec 24, 2015 | GE Profile PSS29NHS Side by Side...
Free Refer Hotpoint csx27dma. Owner had two new parts for the compressor. a start switch and an overload switch. The compressor has 3 round connection prongs for these parts to fit on to. Installed...
Oct 26, 2010 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Refrigerators Logo
91 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
