Question about Craftsman 6" Bench Grinder with Lamp
Bench grinder 319.19062 capacitor wiring- old capacitor had red and black wire. New one has two grey wires. does it matter how they get hooked up relative to how the black and red ones got connected?
Bench grinder model number 319.19062 capacitor burned out. Had a one red and one black wire coming out. I kept track as to where each went. New capacitor has two grey wires. Does it make a different which wire gets connected to the respective locations of the old wires?
3 Suggested Answers
SOURCE: older sears bench grinder wont run 1/3 hp model 397 19581
Can you get a replacement? If not, we could probably figure out some suitable substitute.
Charlie
Posted on May 31, 2009
torqueman200
  • 12 Answers
I know this is an old post, but maybe it will help others looking for information.
I have the Craftsman 1/3-HP grinder models: 397.19580 & 397.19581.
They are Split-Phase single voltage (115 V), and use a Klixon start-up current style relay - 2CR14-224.
The relay is normally open. When the large starting current in the main/run winding circuit is sensed by the the relay coil (term 3 & 4) which is in series with the main winding, the relay contacts close (term 2 & 4).
The one end of the start-up winding is connected to the main coil's BLK wire in the coil pack.
When the relay contacts close the start-up winding is energized. The start-up coil is used to provide a boost to over-come the resting inertia of the rotor.
Once the rotor reaches between 65% - 75% of operating speed, the current through the main winding circuit is reduced to the point that the relay coil cannot over come the return-springs force, acting on the relay contact arm. With the contacts open, the start-up winding is no longer energized.
This should take about 2-3 seconds, if the relay malfunctions, the high current through the start-up windings (thin wires) may be damaged.
Here is a diagram I have made.
Klixon 2CR relays are no longer available.
You may find a suitable replacement here:
http://www.herbach.com/Merchant2/merchant.mv?Screen=PROD&Store_Code=HAR&Product_
Posted on Feb 24, 2016
Disconnected wire to a bp bench grinder mod. # BG-6 and need info to reconnect
first of all the white wires are common from the line in to the plug. the line black from the plug goes switch and red from the switch to the cap and then to the motor and should work fine
Feb 02, 2018 | Electrical Supplies
Hi guys just wanting to know if you can tell me how to hook up power cord to bench grinder it is single phased .
the red wire (power--active-- wire) goes to one side of the switch
the other side will be red wire (power --active --wire) to the motor
the black wire is the neutral wire and will join directly to the black wire from the motor
the green/ yellow striped wire (ground /earth wire is screwed directly to the metal body of the grinder
IN some countries there are different color codes for active, neutral wires so get an electrician in to be safe
Jan 09, 2016 | Bench Grinders
Motor wiring diagram
A suppression capacitor has 2 wires and can be have red and black wire pair, and a motor have 2 wires from the electric field to the carbonbrushes and 2 other wires from the magnetfield goes to the switch and on the same wires can be connected a parallell suppresion capacitor connected bud in most cases its not needed in practice.
The other 2 wires have to come from the powercable on the switch the most grinders to find in shops are class 2 angle grinders with double insulation, But If this is an bench grinder there must be a class 1 cable used with 3 wires to earthing a metal point on the housing. look always for the 2 square symbol its class 2 and cable has 2 wires otherwise 3 .
Aug 14, 2014 | Grinders
I have a 1/3 hp motor with a capacitor. There are four motor leads coming out of motor, the capacitor is mounted in the wiring box. This motor does not have a centrifugal switch, to isolate the capacitor...
I am in the process of replacing a capacitor on a Craftsman 6 in 1/3 grinder, 2.8 amp, single phase, 110v. Not sure on the centrifugal switch. model 319.190621, ser B9530. When I took the old one out the black wire from the capacitor went to the cluster of back wires (in my case 3) in the wire nut. The blue wire from the grinder went to red wire from the capacitor in a wire nut. Hope that helps you....
Maybe you can help me... the specs on the capacitor burned off when it failed. Can you tell me what the capacitor specs are on yours?
Nov 16, 2010 | Craftsman 6" Bench Grinder with Lamp
I have a Cummins 1/2 hrs.bench grinder in pieces. 3 wires from the inside - Black, red, and blue. A capacitor with two male connectors on the end and a switch. How does it need to be wired?
The capacitor goes across the Line, terminals, of the Motor, The Black, should Be Neutral, the RED should be Power IN to the Switch, and the Blue, the "Other" side of the switch. The Capacitor, sometimes goes on the Spare (If any) Terminals of the "Cold" side of the Power Switch.
International color code is Red Positive or Phase, Blue, Phase or Positive, Black, usually Neutral, Negative .
The capacitor is a Suppression" capacitor,and is usually "Across the Motor terminals on "Cold" or "Switched" side of the circuit.
The circuit is simple, Neutral is "Common" the Power comes in to the Switch Contact, whereby the activation of said switch, joins the "Contacts" to the Phase. Positive, Wire to the "Motor". The "Other Terminal Wire from the Motor, goes to Common. The capacitor. Is installed in Parallel with the Phase and Neutral on the "Cold" or normally unpowered side of the circuit.
Mar 13, 2010 | Grinders
It hums but won't turn. are there brushes? what is the black canister hooked to wiring going to motor? aloha, chip
Hi Chip , have you tried !!carefully!! turning the grinding wheels whilst the grinder is powered up and humming and does this start the machine , if it does your motor start capacitor ( a cylinder/tube with 2 wires or connectors on it ) will be deffective or the leads might have became detached from it , a replacement capacitor is quite cheap but you must replace it with the exact one ( a motor start/run capacitor of the correct Mfd or uF rating typically 30 uF/Mfd and at the correct voltage 110/220V )
if this dosent fix your problem most likely your motor start windings in the motor field coils are burnt out and the grinder is uneconomical to repair .
hope this helps .
Jan 22, 2010 | Delta Shopmaster 8" Bench Grinder
Older sears bench grinder wont run 1/3 hp model 397 19581
May 31, 2009 | Craftsman 6" Bench Grinder with Lamp
Older black & decker bench grinder
Usually a new wire wheel comes with different size bushing just for the problem you are describing. Either that or take it back and get one specifically for your tool.
Jan 31, 2009 | Black & Decker 3/4 Hp, 8" 205MM, Heavy...
Grinder won't stay running
The capacitor is easy to change and can be matched once you remove it by any electronics parts house.
Nov 24, 2008 | Delta 23 884 8 Inch Bench Grinder Wheel,...
Craftsman 6" Bench Grinder with Lamp Logo
306 people viewed this question
Top Craftsman Grinders Experts
Jim London
Jim London
Lawrence Oravetz
Vernon Taylor
Are you a Craftsman Grinder Expert? Answer questions, earn points and help others
