Question about Sony VAIO VGC-V617G PC Desktop
Vaio VCG-LT38CE on boot goes directly to black screen with 3 beeps on the boot?
I get three short beeps on the boot and then my screens remains black. I can't get in to set the BIOS to default, yet the boot continues into windows 7. Even though I can't see this, my theme plays a piece of music right after entering Window. I need to decipher the beeps on boot. This should tell me what my probably error is and point at a solution. I have been a tech in mainframes, mid-range and PCs for almost 30 years and I am stumped. Sony's faq pages do not help much as they fail to give viable information.
  • Sony Master
  • 27,725 Answers
Keyboard is not connected properly
Verify that the keyboard is connected properly to the computer by turning off your computer and then disconnecting and reconnecting the keyboard to the computer.
Stuck key
Ensure that there are no stuck keys on the keyboard.
If all keys appear to be ok and you have a standard desktop computer with keyboard, turn the keyboard over and gently hit the back of the keyboard to loosen any dirt or hair that may be stuck in the keyboard.
Bad keyboard
Try another keyboard on the computer to verify that the keyboard has not gone bad.
Bad PS/2 or AT port
If all of the above solutions are not able to resolve your issue it is likely that the port on the back of the computer may be bad and the motherboard or I/O board may need to be replaced.
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
make sure that your RAM modules and Cmos battery are securely seated
on some motherboards Cmos batteries are soldered in
Test all power and data leads that attach from motherboard to your hard drive IDE SATA
make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
if its a flat 40 pin ide it will be the first to fail
check the graphics card is seated properly with no dust in the socket you might have to remove it to check for dust reinstall it
restart your computer the found new hardware wizard should activate
a computer needs power and data to travel through every working device and to its continue its cycle and to have and end to function.
hope this helps
Posted on Nov 04, 2012
5 Suggested Answers
Sunil Panem
  • 80 Answers
SOURCE: VAIO PCV-W700G Screen (LCD) Blacks out
it could be an issue with the chipset.....the chipset needs to be replaced
Posted on Jan 30, 2008
gabndan2
  • 35 Answers
SOURCE: sony vaio pcv-rs510 fails to fully boot
reinstall os.bios should be preset to boot from cd/dvd but if not power on then press delete key or escape key till bios loads-in boot opt. select cd/dvd drive first boot.put os disk in drive and restart when asked to press key to boot from cd do so.follow inst. instructions.after insall detects previous version of xp select repair (r key) and follow inst. should solve startup problem without losing data.if not reinstall os but select leave files intact instead of format or you will lose all files.
Posted on May 31, 2009
SOURCE: I have a Vaio PCV-W20, and a few months ago the
Ok try this, at boot up press F8, when the Menu comes up, choose Safe Mode, but this time instead of going to the desktop, choose System Restore, follow instructions, and when the Calender type window comes up, simply choose a time BEFORE, the time it went faulty. This should completely restore you to working again. As long as there are NO other problems.
support.microsoft.com/kb/306084 -
Posted on Jul 21, 2010
byteguy
  • 2229 Answers
SOURCE: Sony VAIO VGC-RB52 PC Desktop Computer beeps 3
This is usually a memory error in the 1st 1K of memory.
You can try to replace the memory stick.
Posted on Oct 02, 2011
1 LONG BEEP 2 SHORT BEEPS
Does anything ever post to the screen when you press the power button? if not, it's your video card. The links below are for 1 long and 2 short and they say it's the video card. I've heard that Sony extended the warranty on some models so you might want to go to their website and check yours or in a google search type: Sony GPU Extended Warranty. I did and I see they extended it from one to three years. They have the faulty Nvidia Graphics Card which was a major problem for many manufacturers.
Beep Code Links Below:
http://www.biosbeeps.com/sony-vaio-bios-beep-codes.html
http://www.techsupportforum.com/forums/f108/sony-vaio-vgn-ar51-beep-codes-614124.html
Extended 3 Year Warranty for Defective Nvidia Graphics Card links below:
http://apcmag.com/sony-vaio-notebooks-suffer-from-faulty-nvidia-gpus.htm
http://www.slipperybrick.com/2009/08/sony-warns-laptop-owners-of-defective-nvidia-gpus/
May 16, 2012 | Sony Computers & Internet
Acer aspire 5100.When turned on the green light is on and the fan starts up and then I get 1 long beep and 2 short beeps ,it fails to boot up and remains a black screen and then shuts down after 1 to 3...
AWARD BIOS beep codes
Below are Award BIOS Beep codes that can occur. However, because of the wide variety of different computer manufacturers with this BIOS, the beep codes may vary.
Beep Code Description 1 long, 2 short Indicates a video error has occurred and the BIOS cannot initialize the video screen to display any additional information Any other beep(s) RAM problem.
May 18, 2011 | Computers & Internet
I checked the ram modules and the thing is when i press to start the computer the led on the screen doesn't turn green , i get either one long beep or 3 beeps, and the screen remains black and it doesn't...
One long beep + 3 short beeps denotes a video problem for Sony Vaio. Unfortunately it doesn't get more specific. If you have a video card, try re-seating the card. Try using a different monitor. Try upgrading the drivers (probably here: http://www.driverboost.com/lp/drivers/update/ati-video-drivers.php ) of course you will have to go to a different PC to download them onto a CD/dvd and try to run them. You might consider trying to boot into safe mode and doing a system restore. It could be many things. Without more information I can't really be of much more help. Hope one of these works for you.
Good luck
Oct 15, 2010 | Sony VAIO VGC-LS21N PC Desktop
Boot, black screen, error code 3
2 short, 1 long
BIOS checksum error
1 long, 2 short
Memory test failure (bad memory during memory sizing)
Jul 30, 2009 | Dell Dimension E521 (D10E16) PC Desktop
Gigabyte GA-945P-S3 short beep codes on cold boot. Tried reseating RAM, didn't help. system runs fine after beeping stops
Using the manual for the Gigabyte GA-945P-S3 MB. Go to page 71 & you'll see bios beep codes for your board: AWARD BIOS Beep Codes 1 short: System boots successfully 2 short: CMOS setting error 1 long 1 short: DRAM or M/B error 1 long 2 short: Monitor or display card error 1 long 3 short: Keyboard error 1 long 9 short: BIOS ROM error Continuous long beeps: DRAM error Continuous short beeps: Power error As you can see there isn't a code for three short beeps. When you boot your system try to pause your boot up screen. See if the bios is reporting the correct total of memory in your system. Bios codes from the link below. http://www.computerhope.com/beep.htm#05 3 beeps for the AMI bios code reports Base 64K RAM failure. You can test your memory. Go to memtest.org Scroll down the site to just under the three screen shots. Download Memtest86+ V2.11 You have a choice in making a bootable floppy disk or a bootable CD-ROM disk. Once completed you boot your system to the testing program. Memtest will check your system memory. This should help. Thanks for using FixYa! Mike
Jun 04, 2009 | Gigabyte GA-945P-S3 Motherboard
Gateway c140 beeps
If you have an AMI bios (you can tell when you boot and the black screen has writing on it at startup - the bios type and version is the first thing at the top of the screen)
1 long and 3 short beeps indicates that the memory is not seated properly. You should check that it is secure on your motherboard. If it is seated securely, your memory is maybe faulty.
Mar 21, 2008 | Computers & Internet
Sony VAIO VGC-V617G PC Desktop Logo
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
