Question about Vizio VO47L 47 in. LCD TV
My VO47LF HDTV screen went blank, stopped responding to remote commands, and would not even turn off at the switch on the side of the tv... A service tech came out and charged me $50 to tell me it was
I opened the back and looked it over. It's beautiful, no burns or swollen caps, etc.
  • Vizio Master
  • 8,617 Answers
Sounds like a main board issue. With a black screen and no remote functions . Does the Vizio logo stay white or orange?
Posted on Nov 04, 2012
  • Dan Holley Nov 09, 2012
    Thanks Sonny, Between yo9ur validating what the home repair rep gave me I got it going again. I ordered a recertified main board from jamescindy7046 on ebay ($75 with no core chargd and free shipping). Got it and installed it today, works perrfect. You rock my friend! Thanks so much, Dan Holley
  • Sonny Berry
    Sonny Berry Nov 09, 2012
    Glad that I could assist congratulations on getting the set fixed.
5 Suggested Answers
  • 8457 Answers
SOURCE: Vizio VX37L HDTV went to a black screen (frozen
Not,power.It the backlight video board it needed replaced.
Posted on Nov 22, 2009
  • 10 Answers
SOURCE: Vizio GV42L 42inch LCD/HDTV
there are several possibilities. first if the unit comes on and the "VIZIO" light turns white, but no picture or sound, then the main control board is most likely the issue. could be the LCD control board(s) depending on model one or two. and ultimately could be the power supply on the upper side....if the "VIZIO" light does NOT turn white, the whole power supply unit is out. after that, would have to scope the circuits to find out. Seems that the control board is the most common and tends to happen on many different sizes. new board will be around $350.00. Might get lucky and find a used one, but it MUST be EXACT part or it wont work right. if you dont find one or want to sell yours for parts, id be interested in the screen. can reach me at kmarlin@grandvalleygolfclub.com. thanks, keith
Posted on Aug 10, 2009
Slapnuts1975
  • 51 Answers
SOURCE: Vizio L32 HDTV 10A - Won't Turn On
Bad capacitors in the power supply. Open it up and look for swollen electrolytics.
Posted on Sep 22, 2008
  • 27 Answers
SOURCE: went blank sound and picture went off will not
Most LCD tv's having a lot of bad caps in the power supply ,that makes for really weird things happen, since they work like a computer during boot. For that 2-3 second "boot" the processor in the set checks for a combination of things and if those caps go bad in the supply the set will show a wide variety of symptoms.
Usually the set won't start for a minute or two and sometimes longer, after that comes some weird things like lines and what not and the set finally just won't come on period.
I could write a book about how simple fix like changing a few caps causes all kinds of phenomena..lol
Posted on Apr 09, 2010
SWOLLEN LEG AND FOOT...HAD CANCER TREATMENT FOR 6 MONTHS FOOT BURNS WHEN I STAND TO LONG.
so call your doctor. we cant help you with that kind of thing here at fixya. sorry
Jun 23, 2017 | Health & Beauty
Tip
Green light but no backlight or video or blackscreen.
I had one that had a black screen and fixed the problem by repairing the inverter. When I opened the unit I looked at the capacitors on the inverter board and found them swollen. I looked at the bottom of the board and found that the fuse had opened up. The caps were a cheap quality low temp variety 150uF at 25V I replaced them with 330uF 25 volt 105C caps. I then replaced the 2.5A surface mount fuse with an axial 2.5A pico fuse and the TV worked beautifully.
on Jan 08, 2010 | Philips 15PF5120 15 in. LCD Television
Backlight shutt off
if. it works for about 3-5 seconds and cuts off
then the power supply is the problem..
open and look for capacitors that is swollen, or change the 2x1000uf 10v/16v, change the 2x 470uf/10/16v ,or the 2 small caps by the inverter
may be swollen, you can use higher voltage caps , no problem
May 25, 2014 | Samsung SyncMaster P2770HD - LCD monitor -...
Im looking for a dixon tms8 circuit diagram
Are you trying to repair it? If so you dont need one. Test the mosfet to see if they are shorted. Replace all needed, look on board for bad components, such as bad or leaky caps, burned diodes, check other parts around each one. Check in transistors for short or opens, replace as needed. Look for input caps swollen etc, etc. they are all built almost the same way, some with better parts cheaper ones with lesser an weaker parts.
Mar 20, 2014 | Computers & Internet
PP4018 gas cap won't come off.
BOIL UR KETTLE, THEN SLOWLY TIP IT OVER THE CAP.... IT WILL ENLARGE THE CAP MORE,,, THEN USE A RAG OR OPENING TOOL.. SHLD WORK OK...GOOD LUCK
Aug 24, 2012 | Poulan Garden
My lg32lc46 tv will not come on from red light.I've had a peep inside, all 4 of the 10v capacitors have swollen tops.The rest of them look ok.
That peep was probably the sound of a swollen cap out-gassing (dead). This means a trip to the service shop. Sorry
Oct 22, 2011 | Televison & Video
Coleman rooftop air conditioner - Unit's fan works well, but when turned to A/C, the compressor short cycles: 2-3 sec on, then off for 15 sec, then on / off again. The compressor gets pretty hot...
It could very well be the capacitor which I would check first because it is a cheap fix. If the capacitor looks pregnant or swollen it could be shorted. You can check it with an ohm meter if you have one. Disconnect the capacitor, writing down where the wires go. Set the ohm meter on the highest ohm setting, and touch the leads to both sides of the capacitor. If the needle goes up and then bleeds back down, the capacitor is good. If the need goes up and stays up, the cap is shorted. If it doesn't move at all, the cap is open. Either shorted or open, it needs to be changed.
Worst case could be that the compressor is "locking up" or the piston is swollen and will not pump but for a few seconds before is seizes. This would mean a bad compressor. Hope this helps.
Jul 03, 2011 | Coleman Mach III Air Conditioner
No picture in Philips 42pf7220a/37 Plasma TV.
Hi my name is Roety,
I can help you with your issue ,
You can look for two bad capacitors on the power supply. They will look swollen on top like this photo
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Nov 14, 2009 | Philips 42PF7220A 42 in. Plasma Television
Flat tv, sound but no picture. have tried
Jun 12, 2009 | Philips 15PF5120 15 in. LCD Television
No picture
Mar 26, 2009 | Philips 15PF5120 15 in. LCD Television
Vizio VO47L 47 in. LCD TV Logo
532 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
