Question about Acer Extensa 4620 Notebook
Maxtor external hard drive stopped working
Maxtor 3200 500gb external hard drive has stopped functioning will power up when switched on but seems to go into a very slow boot up and the whole computer seems to freeze icon shows up in my computer but when clicked on to open sats drive not recognized
  • therimmers Jan 07, 2009
    sorry late in replying but i just had to get away from pc for a bit , yes pc ok when starting without usb connected but soon as it is connected everything goes into a very slow mode including pc.
    Sergeant:
  • 366 Answers
How is it connected ? USB?
If you start w/o Maxtor connection is your PC starting correctly?
Is issue showing when you connect USB cable on working PC?
Posted on Jan 04, 2009
  • Pat Batta
    Pat Batta Jan 10, 2009
    be sure to have Maxtor drive for your OS and PC model.
    try using different USB port.
    remove USB Universal serial Bus controller from Hardware device manager in Control Panel/ system/ Hardware Tab/ device manager
    and reinstall.
    Try connecting same device to another PC
    If Maxtor is already formatted be sure your windows canmange same file system (FAT NTFS)
External HDD no longer recognized by new win7 PC
Probably not the right answer for your problem. Mine is an external 1 TB Simple Drive. Mine wouldn't respond at all. I unplugged the power cable from the back of the hard drive and replugged it in and instantly it worked. I had tried rebooting the computer, plugging/unplugging over and over into the computer and that didn't work.
Jun 19, 2010 | Maxtor OneTouch 4 500GB External USB 2.0...
I have a Maxtor Personal Storage 3100 80 GB Hard Drive which has always worked and listed as drive G. However, on eday it just stopped listing drive G. Everytime I connect it to my port hub or to the...
Try a different "data" cable between your computer and the external disk-drive.
If there is an external power-supply, borrow a "multimeter", and test that the power-supply is supplying power (correct voltage and correct amperage).
Try connecting it to another computer.
Disassemble it, and disconnect the disk-drive from the USB-to-disk-drive adapter. Connect the disk-drive as a "slave" disk-drive in a desktop computer, and see if the disk is working.
If it still is under warranty, either your local retail store, or Maxtor/Seagate will honour the warranty, and replace it.
Jun 15, 2010 | Maxtor Personal Storage 3100 (M01B080) 80...
I have a maxtor one touch4 and tryin to conect to my bell 6131 hd reciever if formats fine reboots but will not see the drive just tells me to go the bell.ca/pvrmax page wich is pretty useless
Comparing the list of requirements, the ONLY questionable one is the requirement that the external drive does NOT have a sleep mode...
The Maxtor MIGHT have that and not be compatibleas a result. ALL the other requirements seem to be met assuming you are using the external power adapter on the Maxtor..
Jan 03, 2010 | Maxtor OneTouch 4 500GB External USB 2.0...
My maxtor external hard drive has stopped working. When I plug the power in the light only comes on temporarily therefore i can't use it. Have I lost all my saved data?
My maxtor external hard drive has stopped working.There is a chance that you can recover data using a USB to IDE or SATA Adapter Cable to recover your data they cost about $30 if you cant get hard drive to power with adapter chances are it has crashed there are places that can get data off hard drive but they are very pricey hope this helps.
Nov 28, 2009 | Maxtor Computers & Internet
Something Dopped on maxtor 500G, Now not reading - making beep
two thing could be the power supply in the external box or it could be the drive it self
go to maxtor.com and download the software to test the drive
Aug 11, 2009 | Maxtor OneTouch 4 500GB External USB 2.0...
Can a external hard drive with a power supply issue be fixed?
the data on the drive should hopefully be safe as it sounds like it is the drive enclusure that has failed here (not the drive)
your data should be intact if the drive hasn't failed.
however to access the data is a different matter, as I am unsure how maxtor deal with this, to do it manually you would put the drive into a working enclosure or connect it to a functioning HDD adapter (for your drive type)
however to do this the drive would need to be removed from the enclosure (voiding the warranty)
hope this helps
Apr 14, 2009 | Maxtor OneTouch III 300 GB Hard Drive
Maxtor 3100 external drive
If the computer is connected to the power line, even if it is shutdown, you probably have in the BIOS settings the option to power it on from external sources like LAN, USB etc that is turned ON. So the USB port are still powered hence the external HDD is powered also.
Nov 19, 2017 | Maxtor Personal Storage 3100 (M01B080) 80...
Maxtor Portable 320 GB External Hard drive doesn't show on my Mac
If you can get a 3rd party disk utility like DiskWarrior because if the disc information has corrupted the computer cannot see it, the utility will re write this and if the drive is OK it will re appear
Dec 07, 2008 | Maxtor Hard Drive
500GB BAsics External USB drive
Simple Solution, Install XP on the Vista Machine...
Aug 28, 2008 | Maxtor Hard Drive
Maxtor external hard drive failure
If you really want those files, try DriveSavers.com. They do wonders with dead hard drives (known to have recovered files off a burned hard disk). But it comes with a hefty price. So check their website, http://www.drivesavers.com/.
Dec 23, 2007 | Maxtor 100GB 7200 RPM Personal Storage...
Acer Extensa 4620 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
