Question about Fisher and Paykel 24 in. DS603H SS Free-standing Dishwasher
My fisher & paykel dishwasher won't empty water after washing and rinsing. Water overflowed from the dishwasher then remained in the bottom. I can hear the pumpt trying to pump. The dishwasher
My fisher & paykel dishwasher won't empty water after washing and rinsing. Water overflowed from the dishwasher then remained in the bottom. I can hear the pumpt trying to pump. The dishwasher beeped at me and said F1.
stephanos18
  • 144 Answers
SOURCE: Fisher & Paykel Dishwasher DS603- water not draining out
Does it show a fault code? eg F4?
Posted on Mar 27, 2009
vitg55
  • 78 Answers
SOURCE: Fisher Paykel F1 error / double dishwasher drawer
F1-water on bottom of dishwasher. Uselly it cost by broken drain hose. Need expert tech to fix the problem.
Posted on Dec 01, 2008
SOURCE: possible pump blocked
dishes have white film glasses are foggy
Posted on Feb 11, 2009
  • 784 Answers
SOURCE: F1 Error on Fisher & Paykel Nautilus
It leaked before leading to this.
1- Unplug the power.
2- Dry out the leak.
3- Before taking off the lid seal, check if Lid actuator working by going to diagnostic mode. 4- Select LD.
5-Pull the drawer half way out so you can see the lid going down or not when you turn on by pressing lock button.
6- Press the lock button again to release the Lid.
7- Most the time it is a Lid actuator problem and your seal look good, then you replace the Lid actuator only.
8- If it is a problem with the Lid actuator and your seal look bad then replace all .
Posted on Jul 03, 2009
  • 784 Answers
SOURCE: My Fisher & Paykel DD 603 has the fault code
Check at bottom housing both top and bottom drawers for leaks.
Pull the tube out, on the left side below the tub you can access to touch the bottom housing. Dry it out with a tower. Un plug the power cord at least 24 hor so the flood sensor can be dried out before pluggin it back.
However, if you don't fix this leak, the sam F1 problem will happen again.
There is not much clogging up in filter. If you expect something clogged up, you have to take the spraying arm off then take out the bottom stainless steel with a lot of holes out to see the impeller clean or not. Good luck.
Posted on Sep 12, 2009
Machine stuck in drain mode, beeps, can only turn off at powerpoint.
Your motor controller board is faulty
needs repair or new/recondition board.
May 06, 2013 | Fisher and Paykel Fisher Paykel Intuitive...
DD603 top draw cycle getting stuck on 73min??????
Normally if you started the rinse cycle with water already in the base of the dishwasher it will immediately go into circulating the water through the wash arms. Do you hear the wash arms running when the washer is stuck at 11mins? Also when the washer is stuck at 73 mins are the wash arms running all the time or do you hear the pump operate at some stage?
If you have the dishwasher manual available make sure the water pressure setting is at HI or LO depending on your rated mains water pressure.
Apr 30, 2013 | Fisher and Paykel 24 in. DD603H W Built-in...
Hi i have a double dishdrawer and i cant find my manual, my bottom drawer wont empty and its showing a tap aymbol what does this mean?
The icon that looks like a faucet/tap indicates that there was a fill fault. This sometimes comes on if the water is turned off and the unit stops getting water.
There is an overflow sensor/shutoff valve assembly ("water block") attached to the water inlet hose, to shut off the supply if overflow or flooding is sensed. If the water block is tripped, it can result in the fill fault.
A short circuit somewhere in the electronics could also cause this problem.
You will need to unload any dishes in the bottom drawer, and then empty the water manually. I would use a sponge to soak up the water and wring it into the sink.
The manual for the DD605SS may be helpful- it looks pretty close to the model you have.
The parts diagram has a (small) picture of the water block, and gives some indication of its location. I don't know how it works or if you can reset it somehow, but you may be able to get a better look at it if you pull the unit out. I would take a look anyway, just to be sure there's not a leak somewhere.
Even if your warranty is up, you might also try contacting Fisher & Paykel customer care for help with this problem. http://www.fisherpaykel.com/customercare/contactus
Jul 21, 2011 | Fisher and Paykel 23 in. DD-603SS Built-in...
I have an ecosmart Fisher&Paykel. Goes OK through all the cycles until the spin. Won't empty water. Tried rebalancing load, and it is level. Manual says it could be a suds build-up and to do a deep...
Hi there, it sounds like your drain pump is not working. Tip the washing machine back and look underneath. The drain pump has a little black fan on it. Disconnect the hose to see if there's anything stuck in the drain, like coins, hair clips etc. Clear out the pump and remember to reconnect the hose securely before trying out the washing machine.
Please remember to rate this solution, thanks.
Jul 01, 2011 | Fisher and Paykel Washing Machines
U1 code 920 model filter is clean no hoses bent or kinked ? can it be fixed ? hans
The U1 code means:-
Dishwasher attempted to fill to correct level but failed. = Water tap not turned on. Turn the water tap on.
Too much foam. Rinse aid setting too high or has been spilled. = Turn the rinse aid dial to a
lower setting or wipe the spill. Incorrect detergent. Ensure that you use a detergent that is intended for a domestic automatic dishwasher. Egg yolk. Place an extra tablespoon of detergent in the dishwasher door for pre-rinsing.
Too much detergent. Use the recommended quantity of detergent
Wash pump faulty. Call your Fisher & Paykel Dealer or Authorised Service Centre.
Dishwasher not draining. = Drain hose bent or kinked. Straighten drain hose so water can flow through. Strainer blocked. Empty out the strainer and ensure the filter plate is clear of food
particles..
Feb 19, 2011 | Fisher and Paykel Dishwashers
I HAVE A TWIN DRAWER MACHINE ABOUT 5 YEARS OLD THE TOP DRAWER IS WASHING DISHES BUT LEAVING WATER IN THE BOTTOM OF THE DRAWER WHICH I AM NOW HAVING TO EMPTY MANUALLY HOW CAN I FIX THIS PROBLEM
Have you tried running the rinse cycle to check if the water drains out?
If you are not getting any fault codes, then it might be simply a matter of cleaning the base filter plate and the sump. The user manual will tell you how to do this.
If that does not help then post a comment along with the model number of your fisher and paykel double drawer unit and I will suggest further diagnostics.
Jan 29, 2010 | Fisher and Paykel Dishwashers
Fisher and Paykel GW11 not staying hot
WHEN I CALLED FISHER AND PAYKEL PARTS CENTER WITH THE SAME PROBLEM . THIS IS THE REPY I RECEIVED. "THE HOT WATER FILLS IN FOR A SHORT TIME, THEN THE DIRVERTER RECIRCULATES FOR A FEW MORE MINUTES, THEN FILLS THE REMAINING WATER LEVEL YOU HAVE SELECTED WITH COLD WATER. THE REASON BEING: (GET THIS) FISHER PAYKEL SAYS THAT THE AMOUNT OF HOT WATER AT THE BEGINING OF THE
CYCLE IS SUFFICIENT TO DISOLVE THE DETERGENT. AFTER THE DEVERTER CYCLE (THE SIDE RINSE AS YOU CALLED IT) THE REMAINING WILL BE COLD WATER FILL".
HE ALSO STATED MANY PEOPLE CALL HIM ON THIS AND HE SAID IN THE MANUAL IT IS EXPLAINED THAT THIS IS THE WAY THE MACHINE WORKS. SO MUCH FOR ECOSMART
Jan 02, 2009 | Fisher and Paykel GWL11 Top Load Washer
Fisher paykel will not complete rinse spin cycle
will sence it will spin once the water is out .that must mean your pump is restricted.unplug go to buttom of washer find pump and clean out
Dec 31, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher and Paykell DD601 V2 Top Drawer Overflowing
I suggest pressing the keylock and power button together, hold for 5 secs, the display will change orange, the display should read HP if it says LP, press the start button to make display read HP.Then press power button to store. You will need to manually removed the water from the machine before restarting
Jul 03, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
None use for 7 days
I have a fisher paykel dd603 dishwasher. If I select the normal wash setting on the top drawer, it posts the time in the lcd screen as 56 mins. The unit will wash as usual until it reaches the 28 min mark. At this point it will stay on 28 mins and continue to run, but it won't rinse or empty the drawer of water. Also it never counts down below the 28 min mark. It has flashed a F4 and F1 code. I've cleared them both, and checked to make sure that no water is standing on the bottom of the unit, and that the heating element is working. I should mention that the top drawer did overflow about two weeks ago, and that I did clean up the water. I don't know where to look from here. Any suggestions?
Sep 10, 2007 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and Paykel 24 in. DS603H SS Free-standing Dishwasher Logo
54 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
