Question about Garden
Mastercraft 60-3718-2 snowblower engin oil - Garden
3 Suggested Answers
  • 42 Answers
SOURCE: connecting throttle linkage on brigs & stratton snowblower
here is a site that may help you. I hope so, these things can be a real pain in the neck. let me know if you need any more help, I would be glad to help you.
http://wssemw.arinet.com/scripts/EmpartISAPI.dll?MF&app=EWSS&session=9ea7684f-6a4b-45b9-89c9-d4a5ad4e20da&cat=27&TF=epcFrame&assem=62752&highlightNode=No&selAssem=123060&mdDescrip=130232-0676-99
Posted on Mar 12, 2009
  • 747 Answers
SOURCE: Owners Manual Mastercraft Snowblower Model 31ae680h515
their will be a phone number located on the unit a help line or go on line to sears service center web site they are very helpful
Posted on Sep 04, 2012
Sometimes the drive moves & then it stops on my Mastercraft Snowblower
Most self propelled snow blowers are driven by a sliding rubber disc. That disc is driven by a belt from the engine. The belt can wear and needs adjustment. The handle that you hold has an adjustment for the tensioner pulley and spring assembly used to engage the belt. The belt can also be worn to the point of needing to be replaced.
Jan 22, 2017 | Mastercraft Garden
Mastercraft Snowblower 8hp28inch cut.Snowblower starts to miss and run rough after it is warmed up what is the problem
This link should help:
http://www.fixya.com/search.aspx?cstm=0&_s=manual+for+a+Mastercraft+8+Hp+snowblower
Feb 05, 2016 | Garden
How do I start my Mastercraft snowblower
check gas and oil
check blower housing (round part) for ice and snow ( clear if needed)
put gas and choke on full
prime 3 times pull cord or hit electric start
repeat if it doesnt start with priming 3 more times
Jan 03, 2015 | Garden
Looking for proper spark plug for CTC mastercraft snowblower 10-33 model 318 961 515 older model
Pull the Old one out and purchase an E3 Spark Plug. They work great on Smaller engines. There are only a hand full of plugs for small engines...
Nov 07, 2014 | Garden
My mastercraft "deluxe" 8 hp, 26" snowblower won't
Could be dirt in the carb. If this engine has a fuel cup on the bottom of the carb take it off and clean it out and clean the fuel jet. It is the little screw that has a little hole through it. If this has any dirt in it the engine will not run. A lot of engines I get in this is a quick fix as most people do not run the old fuel out before they store it for the summer. Check the spark plug as well and see if there is wet gas after trying to start. Maybe your choke is not working.
Oct 26, 2017 | Garden
Which oil should be used for mastercraft 60-3975-8 snowblower
A good rule of thumb is: In 2 stroke engines, use synthetic or synthetic-blend 2 stroke oil
In 4 strokes, if it is cold, using regular SAE oil...SAE 30 only...if using synthetic oil (highly recommended), then you can get away with using a multi-viscosity oil like 10-30. Synthetic 30 weight is OK too. Just in cold temps, standard multi-viscosity oil does not perform well and manufacturers like Briggs caution against using it, stating engine damage can result.
Dec 11, 2010 | Garden
I need a manual for a Mastercraft 8 Hp snowblower P/N 316 582 515
Jim
Dec 03, 2009 | Garden
Mastercraft snowblower will not start
if old gas was left in the tank and not flushed it makes the carb stick and won't allow the proper gas flow to the motor...I would first test the plug by verifying it has spark..if it does what i do at times is quickly spray some quick start in the plug chamber and reinsert the plug and try to restart...this at times will get the spark going and allow the motor to start.....you can also try to spary some in the carb before starting...just a squirt or two....the best thing to do is actually clean out the carb as it is likely the issue.....hope this helps
Dec 18, 2008 | Mastercraft Garden
Garden Logo
118 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
