Question about Roper Refrigerators
Install Refrigerator Compressor 3 in 1 Start Kit - RCO410
Need to know how to wire
fridgetech
  • 473 Answers
SOURCE: ADMIRAL REFRIGERATOR
The blue wire goes to the overload (common), the other two wires will go on either side of the relay.  If you have an orange wire put it on start.
Posted on Oct 13, 2007
the dr
  • 447 Answers
SOURCE: jenn air french door refrigerator broken by repair company
Ill be glad to shed some light on this for and stand behind this as I too am a Factory authorized dealer. These units did come with faulty compressors failing about 80% of the time. What happens is the compressors get worn and stop starting properly. You can make them work temporarily by installing a 3n1 (basically makes the compressor have more starting torque). However they eventually get so worn that even a 3n1 cant start it. Ive never read any bulletins from any major company (Frigidaire used this same compressor) saying a 3n1 voids warranty. It certainly didnt damage the compressor it was already damaged when the tech installed the 3n1. Also these compressors are failing at such a high rate its not even questionable that the 3n1 damaged anything. Honestly it really sounds to me like the tech is nit-picking not wanting to do the labor intensive job of changing the compressor. He may not even be able to. Also the new compressor should be a 8201555 (I just did one this afternoon ---thats how common this is) and its a much more reliable Embraco compressor. Once its installed you should have no more compressor issues for many years. Feel free to have anyone who questions my solution to call anytime 850-510-9563 (Joey Shearer, Precision Appliance, Tallahassee, FL)
Posted on Jan 15, 2008
peyton32034
  • 410 Answers
SOURCE: Need to Install a Supco 3 n 1 start capacitor
3 in 1 starters like the supco that you have pictured can and will cause premature failure of your compressor. newer compressors are not designed to handle the start up current the 3-n-1 provides. I reccomend replaing wiht an original oem part the part number is 8201786. If you still want to use the hard start use the 410 model obviously hook up the red white and blak wires to the compressor the 2 left over leads will connect to the 2 original wires that come in to the compressor I beleive they are red and white. polarity does not matter. good luck Peyton
Posted on Feb 28, 2009
tborn6
  • 700 Answers
SOURCE: How do I wire the RCO410 into my maytag fridge?
look at the wiring on the relay, then if you have a techumseh compresser the top terminal is common with black wire going to it, the one on the bottom left is start with the white wire going to it, and the one on the bottom right is the run with the red wire goiung to it.
Posted on Apr 07, 2009
  • 1218 Answers
SOURCE: Haier model AES 44B, I need to know how to
Good day,
With a very accurate ohm meter zero'd out, and set to the lowest setting., .......
Check between all terminal options with the probes of the ohm meter until you get the highest reading. ....
The terminal your not on is the COMMON terminal. Record it.
Then, with one probe put it on the common terminal, and check from common to one, and then the other.
the terminal that gives you the highest reading is the start terminal, and then the other is obviously the run terminal.
Posted on Nov 04, 2009
I have a 2000 chevy impala i cut wires on factory n dont know what wires go to what on after market stereo need to know what colors on factory harnus r what ex-orange,illuminate orange 2...
2000 Chevrolet Impala Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Orange
Car Radio Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Antenna Trigger: White
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Mar 03, 2018 | Chevrolet Impala Cars & Trucks
Need to know how to rewire the stareo
try modified-life-logo.gif.com but the remote wire is the blue,
May 09, 2010 | Kenwood KDC-MP142 Car CD/ MP3 Player
Security Camera
it is important to know model and make or camera if you want a solution
Jul 09, 2009 | Home Security
Need to know wirring diagrams
the red is your memory alwayse is a live wire. Yellow tells cd player to turn on and off, Black is your ground. the other ones are your speaker wires go to your doors. Also if you have a power antenna it is the blue wire with the white stripe. Hope this helps
Jan 10, 2009 | Car Audio & Video
Zephyr ep30 range hood
That green and yellow is your ground wire....wire nut that to your bare copper wire feeding the hood.
Sep 03, 2008 | Zephyr Pyramid ZPY-E30S Kitchen Hood
Refrigerators Logo
570 people viewed this question
Top Roper Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
