When the Siemens Microwave oven is not being used the plate rotates inside. Once the microwave door is opened the plate stops rotating. When the food/drink is placed on the plate and the microwave heat setting is turned on the plate remains stationary which obviously results in uneven heating.
SOURCE: Siemens HF 87960 GB Microwave/Combo Oven
Please, Can somebody tell me where can I get one of this oven??? Thanks Andy
SOURCE: I have a Siemens microwave
I wonder if this is an inverter-based model... I ask because on Panasonic/Quasar units, a problem with the magnetron or inverter will cause this very symptom.
If so, because of the voltages and currents involved, I do not recommend that someone without experience attempt repairs on an inverter circuit.
I would contact the manufacturer at the number in your owner's manual to find the nearest authorized servicer.
SOURCE: Microwave door does not shut tightly
If your
oven door has gotten bent or warped (maybe you rested something heavy
on it…), you need to remove the door, disassemble it, and straighten
it. You can lift most oven doors off of their hinges by opening the
door several inches to its first "stop," and lifting the entire door
straight up.
If the hinges have become worn, damaged, or bent,
you probably need to replace them. We recommend replacing both hinges
at the same time, to prevent uneven wear of the undamaged hinge.
SOURCE: I have siemens combi microwave oven is working but
Sounds like a faulty thermal cutout switch. Take it to a repairer.
SOURCE: glass door for a Siemens microwave hf 879
I've the same problem. Inside glass broke while heating.
