Question about Euro-Pro 605 Mechanical Sewing Machine
Sewing machine is making screeching noise - Euro-Pro 605 Mechanical Sewing Machine
  • Carolyn malone Nov 03, 2012
    Where exactly is the noise coming from?
  • Euro-Pro Master
  • 1,564 Answers
If you are hearing screeching it could be a worn belt. Or it could be that your EP needs servicing (oil and lube)
Posted on Nov 04, 2012
Singer Heavy Duty 110 making whining/screeching noise.
If you cleaned and oiled according to the owner's manual, then that probably isn't the issue. Suggest consulting the owner's manual, troubleshooting section. Machine could also be out of time.
Some reviews on this machine are not great:
Amazon com Customer Reviews SINGER HD 110 Heavy Duty Model Sewing Machine
If you've had this machine for seven years and haven't had problems until now, it may be a good time to think about replacing it.
Oct 04, 2015 | Singer Sewing Machines
Memory 3000 makes occasional screeching noise
Take in in for a Maintenance. There are many areas the may need a drop of oil, or adjustment. You don't want to do it.
Mar 25, 2015 | Janome Memory Craft 3000
My Serger, Brother Lock 1034D is sewing great but periodically makes a loud screeching noise. Any ideas?
if you heat the area before its oiled it will wick it up
mini torches rule, or just run machine for 3 mins to warm it up a lot
use some wd40 its light oil but evaporates some on some
there are 2.00 stethoscopes out there i use one . got it at tool import
this noise will always be there its a sleeve going bad with offset wear.
the bearings will be on some support structure as the mech passes rods through them.
there are some amazing lubes out there but some can be hazardous to your skin an blood with micro balls.
Jan 12, 2015 | Brother Sewing Machines
Embroidery arm does not work
Sounds like the embroidery arm belt stop is out of adjustment. Unless you're pretty handy, take the machine and arm to a professional. If you're going to tackle it yourself, get a service manual for the machine.
Mar 21, 2014 | Husqvarna Designer I
When I wind a bobbin, it makes a screeching noise and the needle goes up and down. What step am I missing ?
On the right side is a big wheel and in the middle a smaller one. You need to unlock the smaller wheel so that the needle mechanism does not run when re-winding a bobbin. You need to use both hands to do it. Hold the bigger wheel and then loosen the inner wheel anti clock wise. Once you have finished loading your bobbin you need to tighten the inner wheel again for the machine to be fully functional again.
Jan 12, 2014 | Singer 7436 - INGENUITY
Screeching noise
have you tried a new needle--flat side to the back of the machine
check to see if the thread has come off the thread take up lever
it's also possible that there's something wrong with the motor since it sounds a bit loud
it probably needs to be serviced
Feb 23, 2012 | As Seen On TV Mini Mechanical Sewing...
My Bernina sport 801 is making a loud screeching noise heard under the presser foot/bobbin area
clean under the needle plate
clean the bobbin area for loose threads or lint
if this doesn't make the noise stop then it may need to be serviced
Aug 03, 2011 | Sewing Machines
Makes a loud screeching sound when I sew.
I think it's time to oil your machine. Take a look at you user's manual and clear out any lint (fluff) before adding special sewing machine oil to the moving parts.
Sep 11, 2010 | Janome 8080 Computerized Sewing Machine
Bernina deco noise
See if drive belt is not running against the plastic body on right side.!
Nov 17, 2008 | Bernina Bernette Deco 600
Euro-Pro 605 Mechanical Sewing Machine Logo
167 people viewed this question
Top Euro-Pro Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you an Euro-Pro Sewing Machine Expert? Answer questions, earn points and help others
