Have a heating unit by carrier and it's push out cold air. the outside door was open and i didn't know it. what could it be.
  • Keith Miller
    Keith Miller May 11, 2010
    is this a gas unit is the flame lit
  • 30 Answers
Make sure the gas is on and the ignitor glows or sparks if you get that it should light up flames and blow warm. if the ignitor never works you may have a bad ignitor or the combustion gas removal motor may not be operating properly. how old is your system?
Posted on Jan 05, 2009
I have a 2000 pontiac grand prix with a digital climate control system. The heat quit working, it doesn't blow out any heat. Now that it is warm outside the air stopped blowing out any air. The digital...
I have a 2000 pontiac grand prix with a digital climate control system. The heat quit working, it doesn't blow out any heat. Now that it is warm outside the air stopped blowing out any air. The digital temperature on the climate control is not correct. When it states that it is below 30 degrees on the ext and it is warm outside the air wont be cold. Once it starts going above 30 degrees the air gets colder. Today the blower stop working all together. Was told it maybe the climate control unit was bad. You can hear the door opening/shutting when you switch the temp from cold to hot. But there was no heat blowing out whatsoever in the winter time. Could you please give me your opinion on whether or not it is the climate control unit or something else?
Jul 11, 2011 | 2000 Pontiac Grand Prix
I BOUGHT A USED HOME APPROXIMATELY 1000 SQ. FT. IT
quantity of gas alone does not make for cold air
to understand that it is necessary to understand how an air conditioner or fridge works ( ac, car ac , fridges , freezers etc all work on the same principle)
Simply put it is a heat transfer device where the heat of a room is transferred to outside the room
IT does this by allowing an extremely volatile liquid to evaporate ( being boiled off by heat in the room)
the gas is then collected by a compressor and recompressed back to a liquid
this process releases the heat back outside by the condenser and so the process is repeated until the amount of heat in the room reaches the temp set at the thermostat
Basic I know but it is sufficient to know that there is more than gas at work
if the compressor is inefficient ( worn , faulty etc) it cannot compress the gas properly and so instead of releasing liquid at the evaporator , it will be releasing gas which is not boiling off and removing heat
next is the thermostat
it controls the TX valve that regulates the amount of liquid that is allowed to enter the evaporator to collect the heat to be removed
next there is the condenser
if the fan is not working it will not remove the heat from that unit and so the compressor cannot do the job as it goes into over pressure and shuts down
Good advice is to get a second opinion from an accredited service technician, preferably a carrier service technician that has the technical knowledge of the make to be able to properly diagnose and test each component of the system
every system is repairable if the parts are available but the deciding factor is the repair cost against the energy saving costs and parts availability of a new unit so get quotes and then decide the action to take
Mar 01, 2017 | Heating & Cooling
Heat comes on when the temperature setting calls for cool.
getting heat in the cooling mode leans toward the reversing valve in the outside unit. it changes the flow of refergerint so that the hot air you get outside in the summer is blown inside in the winter. another possibility is that the reversing valve isn't getting 24v check to see if you have 24v at O and C either at the t-stat, furnace, or the outside unit. if you check at the furnace rember the safty switch for the lower door if that switch is open you will have no power. i would look at the t stat first if you have 24v there go to the outside . 24v present outside will mean a bad valve or board, no 24v means a bad or broken conection in the control wire between the stat and the outside unit(usally the orange wire)
Jul 10, 2010 | Carrier Heating & Cooling
What is purpose of pull lever on top right of decorative panel
It's an air intake vent damper. If you push it in, the unit won't pull any air from outside, instead it'll recirculate air from the room. If you pull it outward, it allows the unit to pull air from outside. During the day when it's hot outside, the lever should be pushed into the closed position to allow for more efficient cooling. At night, if you want to exchange air from outside when it's cool enough, pull out the lever to allow that to happen. The unit will exhaust hot air no matter if this switch is in or out.
Jul 05, 2010 | Maytag M7Q08F2ACOM Air Conditioner
Is it normal for fan on outside unit to be on while on heat mode
Yes, it is normal with a heatpump, you run the outside unit in cooling and heating.
It is also normal when the outside unit goes into defrost for the outdoor fan to shut off during the defrost mode and to see steam coming out of the outside unit, while it's melting the frost or ice, then the fan will come back on.
Jan 06, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
Why does my AC keep freezing (Carrier FB4ANF036). I have replaced the blower motor less than a month ago due to the same problem. Just last night we had a lightening storm and shortly after that the AC...
if your system is a heat pump you can switch to heat and see if coil outside gets cold while indoor blows warm air - then switch back to a/c - both coils should not be cold at the same time - low freon pressure / dirty coil / dirty filter / low air flow causes freezing
Sep 22, 2009 | Carrier Heating & Cooling
My Carrier Home AC unit stopped blowing cold air today. I opened it up and cleaned everything and didn't notice anything out of place, any ideas?
This could be complicated to resolve over the internet but I'll give it a try. When you stated that it stoped blowing cold air, did it stop blowing air all together? Also is the outside unit rtunning?
Sep 05, 2009 | Carrier 38CKC042 Air Conditioner
Carrier heat pump: aux heat does not seem to work
you have a heat pump which removes heat from outside air when it is too cold out below 30* the unit can no longer produce heat and electric strip heaters kick in
Feb 06, 2009 | Heating & Cooling
Only blows hot air inside
Set thr thermostat to AC instead of HEAT.
Dec 29, 2008 | Carrier 36KCARMS Air Conditioner
Hi- Can not tell if my unites are straight cool / heat or a heat pump.
if you look inside the condenser unit outside,see if you see the big reversing valve,if not it is a straight cool,heat, the heat strip ins in the air handler so you would have to take the side panel off and look for the heat stripe,my the way heat pumps also have a aux.heat stripe just in case it does not get cold enough outside,hope this helps you-mike
Oct 25, 2008 | Carrier 38CKC042 Air Conditioner
Heating & Cooling Logo
53 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
