Question about Water Heaters
Flame sensor is dirty - Water Heaters
  • Water Heaters Master
  • 5,245 Answers
What pilot light assy. do I need to buy for model# 640y0rt4, water heater ??? please wont stay lit
check that the flame sensor is clean. It would be a stiff piece of wire that would sit right over where the pilot lite is. If it is dirty...it wont sense if there is a flame....and if it dosnt sense a flame....it wont let the pilot lite to turn on.
Jun 03, 2015 | Reliance 606 Series 40 Gallon Natural Gas...
On A.O. Smith water heater model BTH 199 100 where is the heat sensor rod located ?
Parts list:
http://www.hotwater.com/lit/partslists/197728-004.pdf
Flame rod, flame sensor sits next to igniter inside combustion chamber. This can be cleaned with sandpaper. Do not touch with fingers. Purpose of flame rod is to detect whether ignition has caused actual, sustainable fire inside the combustion chamber.
If sensor is bad, or no ignition is detected after 2-3 attempts, then 'no ignition' error is given.
Bad gas control valve, bad-or-dirty flame rod-sensor, low gas pressure, misaligned rod, dirty combustion parts, etc
Service handbook:
http://www.hotwater.com/lit/training/316586.pdf
High gas pressure spikes can daMAGE gas control valve p7
Product manual:
http://www.hotwater.com/lit/im/com_gas/197727.pdf
Word-search for 'failure'
Low gas pressure. p14 and p54
1-3 trials before declaring 'ignition failure. p48
bad flame sensor (clean with sandpaper) #10 p58
unit must be grounded (check outlet with circuit analyzer) #12 p58
Sequence flow chart p59
Rough starts = ignition failure p60
Troubleshoot chart - ignition failure p62
Mar 12, 2013 | A.O. Smith BTH-199 BTH-199 100 Gallon...
Rheem 27 ignites for about a second when cold tap turned on
When you ignites, I assume you mean it fires. If so you have a dirty or defective flame sensor. Usually they can be cleaned with steel wool or a piece of fine sand paper, do not rub aggresively!
As the term implies, it is supposed to varify that the gas has indeed ignited and sends a signal to the gas valve to remain open. If the sensor has a built up film from dirt or moisture it does not properly sense the flame and shuts the gas valve off to prevent a build up of gas in the burner box.
Mar 05, 2013 | Rheem RTE 27 Tankless Electric Water...
Error codes
iIf main burner is comming on then going off you may have dirty flame sensing rod,if no main burner flame it may be bad gas valve.
Feb 25, 2013 | Water Heaters
I have a Richmond 40 gal water heater model# 6G40PVW-40PF manufactured 5/2010 and it wont't stay lit. I don't have the owners manual as we purchased our home in 12/2011 and it was a foreclosu
Well I you have the problem resolved by now, but I will answer anyhow. This just happened to me yesterday with the same water heater that you have. My problem was that the flame sensor was dirty and not picking up that the burner was lit, so it shuts everything down and goes into lockout mode. I had a similar problem with my furnace lighting system. It is called flame rectification. What actually happens is the flame itself allows a small current to flow through it, so the flame sensor actuall makes electrical contact with the burner. The control senses this connection and knows then, that the flame is on. If it doesn't sense this connection, it thinks the flame is out, so it must shut off the gas valve to prevent a possible explosion. Take your burner out and clean up everything in there, being careful not to break the small glass bulb inside, which is another safety device. Fine emery cloth of a wire brush will clean up the flame sensor good. Also wire brush the burner itself, since this is the other end of the rectification circuit.
Apr 01, 2012 | Audiovox Richmond 6G40-36F 6-Year Tall Gas...
Sometimes it doesn't light at all other times during use the hot water goes off and the box keeps flashing green as it continues to spark
it sounds like the flame sensor is dirty or faulty. when the pilot lights the flame sensor rod recognises the flame to allow the main gas valve to open and ignite the burners. you can clean the flame sensor with some steel wool or sandcloth
Dec 29, 2010 | Bosch & Tankless LP Hot Water Heater
Water heater will light but only stays lit for about 5 seconds then shuts off
sounds like the flame sensor isn't detecting the flame. It could be dirty or broken.
It's normally dirty so that could be fixed easily. Look in your owners manual to see where the flame sensor is (it usually looks like a metal rod with a bend on the end and just one wire coming out the bottom).
Turn off the power, remove the sensor, clean it with emery cloth and replace it, turn on and if that was the problem it should work just fine now.
Jun 24, 2010 | RTO Atwood Water Heater - 6 Gal LP
My tankless eco-180dvn water heater is sending me a 12 code, what does that mean?
That is a flame failure..there are many reason for this
be sure you have gas
there could be air in the gas line
flame sensor dirty
Jun 23, 2010 | Rheem EcoSense by 7.4 GPM Tankless Water...
I have a Rheem Classic Series Super Quiet 80 gas furnace. My problem is the furnace will turn on burner fires for a couple of seconds then burner turns off and fan blows. This cycle cotinues and eventualy...
Sounds like it could be a dirty or bad flame sensor.
When the burner lights ,there is a flame sensor in the flame and it is suppose to sense the flame and send a signal back to the control board which will keep the gas valve open, if it gets dirty or is bad it doesn't send the signal back to the board and the board will shut the gas valve off and after three tries it will lock out the furnace and you have to reset it to get it to work again.
The flame sensor looks like a wire and it's in the flame usually it will get gas deposits on it, then it won't work.
You can clean this sensor with an extra fine piece of steel wool, but before you attempt to do this DISCONNECT ALL POWER TO THE FURNACE.
Dec 29, 2009 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Water Heaters Logo
20 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
