Question about GE JET-220 80 Watts Microwave Oven
Doesn't "heat" has power, all other functions work, but the microwave no longer heats food. It's a GE with model #J ET130 OA1
  • chipalatta Jan 04, 2009
    No there aren't any unusual noises and the unit doesn't seem louder or quieter than normal. Timer works properly and the unit still "runs", just doesn't heat.
    In fact, you can actually put something in to heat and not notice anything until you reach in to get the food and notice it didn't heat up...hope this helps.
  • William Miller
    William Miller May 11, 2010
    When you hit Start to
    cook, do the inside light and turntable come on?
    Any unusual noises? Is
    it louder or quieter than usual?
    These answers will help
    me judge whether it's in the high voltage
    section (magnetron, transformer, or diode) or the control section
    (door switch or control board relay or connection).
    Note: Exploded view
  • GE Master
  • 9,086 Answers
Especially considering the age of your unit (about 1980) with the symptoms you have, I would most strongly suspect a shorted high voltage rectifier diode or a bad magnetron, or a loose and possibly corroded connection on the magnetron's terminal.
The diode is a fairly cheap fix, and the mag will cost more.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find a helpful exploded view diagram here and order parts by entering your full model number here.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html
(if it's not shorted or burned, it's probably okay)
http://www.gallawa.com/microtech/mag_test.html
http://www.gallawa.com/microtech/xformer.html
Posted on Jan 04, 2009
Runs but does not heat the food.
Microwave Not Heating Troubleshooting Guide - YouTube
? 2:45
https://www.youtube.com/watch?v=_3SbJueEn1w
Aug 31, 2012 - Uploaded by Repair.com
Allow the circuitry to dry out by avoiding stovetop cooking for a few days. .... it to microwave, but its just not warming up myfood at all, any idea on how i can .... Everything works except themicrowave- it wont heat anything up.
Microwave Diagnostic - Has Power Not Heating - GE ...
? 2:34
https://www.youtube.com/watch?v=E_iUYIV8wD0
Aug 9, 2013 - Uploaded by ApplianceVideo.com
Microwave Diagnostic - Has Power Not Heating - GE, General ....internals of a similar GE Microwave unit that would not heat food.... Sometimes it turns on, sometimes it doesn't. .... My GE microwave space saver does not heat but it comes on. ... What's Inside A Microwave Oven (Teardown / Taken Apart) ...
Nov 18, 2015 | Microwave Ovens
How do I fix the oven when it no longer heats food but all other features of the oven work fine?
Could be a burnt out fuse but most likely its the heating coil is burnt out.
Sep 01, 2015 | GE Microwave Ovens
GE Profile Spacemaker 2004 JVM3670BF02 doesn't Heat up
Ensure that you have select the correct range of temperature.
Sep 11, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
Not heating
Hello
Power Supply
Check whether there is a proper power supply. Look to see whether the cord is connected to a grounded 3-prong outlet and the cord is fully plugged in. If the electrical system is built-in and no power cord is visible, replace or reset the household fuse or circuit breaker.
Microwave Functions
Some basic microwave operational steps may affect whether the microwave is heating. Open and close the microwave door, as the unit will not function with the door open, and push "Stop/Clear" to cancel any previous settings, such as the timer, which do not heat the microwave oven.
Setting the Microwave
Once the power to the microwave has been reset, or verified as working, and the microwave is ready to run, select a new cook cycle and press "Start" to see if the microwave begins to run and cook food as expected. Allow the food to cook for the alloted time and then open the microwave door and check to see if the food has cooked or heated. Choose a longer cooking time and restart the microwave if food is heating but is cooking slowly.
Repair
If all efforts to troubleshoot the function and power to the microwave still do not get the appliance heating food as expected, there may be a repair issue that needs to be addressed. Contact professional technician for advice.
Oct 05, 2011 | Sanyo Microwave Ovens
Problem with the GE Spacemaker (JVM1640SJ) Microwave Oven GE Spacemaker XL1800 won't heat food anymore....It worked this morning, now won't heat. What should I do?
GE Will replace the magnetron for 9 years! Mine is a 2004 model with a one year warrently according to manual. HOWEVER they did say the magnatron was covered for nine years: call 888-239-6832. When I called they said thats all they get calls for and would send out in 3-5 days. NO CHARGE. I had to ask if there was coverage longer than a year on major parts and that's when they offered the info and I eventually was transferred to the right office. Saved $120 bucks on parts alone.
Jun 13, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
My microwave comes on lights work but doesn't heat food
The most likely cause is a defective magnetron, "heats food" cost to repair will be close to a new microwave oven.
Jun 02, 2011 | GE JE1540 Microwave Oven
The microwave no longer heats food and it smells as if something is burning. Everything else on the microwave works. Is this a common problem and how can I fix it?
Its your Magnatron tube, thats what makes the microwaves and heats the food. The part will cost you more than a new micro. The new model that replaced yours is a JVM1540 and you can get them for 179.00
Jan 17, 2011 | GE JVM1440 Microwave Oven
The unit will no longer heat food or beverage
if there is no heating function, chances are that the Magnatron has died. repairs are just not worth the money considering that Microwaves can be oicked uo second hand and with warranty from many Cash converter stores and even some retailers who sell refurbished models from $50
Please rate my help++++Thanks for using FIXYA
Nov 20, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Our microwave (GE) not longer heats food items.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
r
Sep 27, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Have GE JVM2050 over the range microwave, which stopped heating food and water since this morning. All other functions including light, key pad, clock, turntable work normal. The magnetron sound also
if everything works except the heating, it is most likely the mag tube is on its way out.........that is the most common reason for it not too cook.......since the microwave is a GE and it is 3.5 years old, i would say you are better off buying a new microwave, the mag tube starts at around $70.00 and up + the labor it costs too have a service person put it in........around another $60.00
May 02, 2009 | GE JVM2050 Microwave Oven
GE JET-220 80 Watts Microwave Oven Logo
76 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
