Question about Kenmore HE2 Plus Front Load Washer
Kenmore washer he2 plus won't start
Just ran a systems test and everything seems to work fine. Washer will Not start when the start button is pushed. All lights are working and I have unplugged it and tried it again and still nothing. Any ideas?
  • 1028 Answers
SOURCE: kenmore eliete washer fails to do anything
probably bad main control under top left rear ..ck for bad connections first just in case
Posted on Aug 21, 2008
  • 220 Answers
SOURCE: f21 code on kenmore he2 plus
Clean the filter in the pump behind the bottom panel,but remember it's full of water,If it's on a pedestal you can take the pump loose from the mounting pull it out a little and put a small pail or bucket under it before you open the trap.if it isn't on a pedestal it's a bit more challenging unless your in a basement with a floor drain. Open it very slowly and let the water drain a little at a time don't take it all the way out or you'll be in for a flood....good luck
Posted on Sep 03, 2009
  • 5 Answers
SOURCE: Kenmore HE2 front load washer. All cycle lights flashing plus spin and clothes clean lights on.
I'm sure this is probably too late, but hopefully it will help some else. I just had the same problem. First, unplug the power. Then take the lower front panel off and grabbed a bucket. Place the bucket under the large "plug" on your right. This is the drain. Slowly unscrew the drain plug, Hold your nose as it will probably smell. Allow the water and such to drain into the bucket. When you see the blob of wet lint drop into the bucket you will know why the machine refused to work. Make sure you clean the drain plug and screw it back in tightly. Put the lower panel back on and reconnect the power. I hope this resolves your issue.
Posted on Oct 10, 2009
  • 5 Answers
SOURCE: I need the repair manual for the Kenmore HE2 Plus washer
manual for the HE2 and Duet Sport here:
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/6545d78b3f479480852571650061b1ba/$FILE/8178558.pdf
(give it time to download, big file)
Posted on Nov 06, 2009
blueextc3221
  • 15935 Answers
SOURCE: Kenmore HE2 Plus Washer won't unlock
This advice is for Kenmore Elite and Whirlpool Duet model front loading washers. If you experience a problem where the door becomes jammed and will not unlock or open, here's an easy way to gain access inside your washer WITHOUT calling the repairman.
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Sometimes these doors will not unlock for whatever reason. If there are no error codes being generated, this could have just been a momentary glitch. If you see "Fdl" or "Fdu" error codes, these are usually indications of a failed door latch assembly and will require replacement.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
Lights keep flashing and door locks without finishing cycle
Kenmore HE2 Plus Front Load Washer Keeps unlocking ...
www.fixya.com > ... > HE2 > Kenmore HE2 Plus Front Load Washer
flashing prewash and add garment lights My HE2 Plus will fill with water, but when ...Kenmore HE3 2plus wont finish cycle Washer wont finish the last1 minute of cycle. ...We ran a load twice and it still did not unlock. du is the code for cannot ... Why does the door keep unlocking and locking in between the drum rotating?
Admiral, Whirlpool, Maytag - Washer Repair - Not ... - YouTube
? 5:51
https://www.youtube.com/watch?v=oBihToN6dxs
Sep 6, 2013 - Uploaded by ApplianceVideo.com
Troubleshoot your Admiral Top Load Washer that has these following symptoms: Not Completing all Cycles ...
Washing machines - Ariston
Jan 05, 2016 | Washing Machines
F-24 error code so I ran a clean washer cycle, and the laundry room is now flooded.
what's f24 code? - Kenmore Elite HE3 Washing Machine ...
https://www.ifixit.com/Answers/View/85549/what's+f24+code
iFixitAug 21, 2015 - Aiman, The F24 error code indicates a water temperature sensor reading that is ... The Kenmore Elite HE3 is a washing machine by Kenmore.
F24 Error Code on My Kenmore Washer ' eHow
www.ehow.com > Home
F24 Error Code on My Kenmore Washer. Kenmore washing machines have several high-tech features, such as a stain treatment option, reduced energy and ...
Kenmore HE2 Plus Front Load Washer F24 error code ...
...error code F24 I have a Kenmore HE2T washer and I keep getting an F24 error on it.. I have no idea what is means can't find the manual help!!! The "F24" error ...
I have a Kenmore HE2T error code F24 - Fixya
www.fixya.com/support/t3608391-kenmore_he2t_error_code_f24
Dec 9, 2009 - Posted on Dec 09, 2009.
Dec 06, 2015 | Kenmore HE2 Plus Front Load Washer
He2 maintenance procedure failure
unplug for a minute and see if it resets the cpu.
Jan 21, 2018 | Kenmore HE2 Plus Front Load Washer
Kenmore HE Washer Model 11046472501 - add a garment light stays on with the door lock light on at the same time. We have unplugged the machine and ran the drain and spin mode, but he washer won't
Not sure if these will help or not:
http://www.youtube.com/results?search_query=Kenmore+HE+Washer+diagnostics&oq=Kenmore+HE+Washer+diagnostics&gs_l=youtube.12...4054.11443.0.13769.12.12.0.0.0.0.236.2449.1j0j11.12.0...0.0...1ac.1.93rgz26enSw
Jan 26, 2013 | Kenmore Ap4327152 Motor Control Board for...
Loud noice in the spin cycle while going fast
What is the complete model number of your unit?
Dec 04, 2012 | Kenmore HE2 Plus Front Load Washer
Kenmore HE2 Won't Turn On
1) test the power cord for open 2) test the outlet box, see for blown fuse or c.breaker put some desk lamp and see if work 3) test inside of the control board if there fuse blown or c.breaker tripped 4( test the lid switch is closed, can be faulty or open replace 5) test the input voltage 115 if there are the control board faulty.
Jul 18, 2012 | Kenmore HE2 Plus Front Load Washer
Lights blink on settings around the knob won't run from there
Your door switch is not working, the machine thinks that the door is still open.
Mar 11, 2012 | Kenmore HE2 Plus Front Load Washer
HE2 Plus Washer starts then shuts off immediately.
Aren't microprocessor controlled appliances wonderful? Especially when the code is flawed! No wonder the space program bit the dust!
May 12, 2017 | Kenmore HE2 Plus Front Load Washer
Kenmore HE2 front load washer. All power to the maching is good. Thhe start button just beeps in quick sucsession. Won't start. It seems to think the door isnt' closed but it is, and tightly. ...
It is indicating that there is a problem either with the door lock or the door locked sensor requiring a service call, sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Sep 19, 2011 | Kenmore HE2 Plus Front Load Washer
Kenmore HE2 Plus Front Load Washer Logo
217 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
