Question about Acer Aspire 5100 Notebook
Connectivity I just bought an Acer netbook. I cannot connect to my wireless internet in my home. I have the wireless access code, but it says limited use. The operating system is XP. The model is zG5 Can anyone help ? We have 24 hours to fix this as we are enroute to a year backpacking around the world
  • Edward Morgan
    Edward Morgan May 11, 2010
    How does the signal look in the Wireless networking software?
  • 366 Answers
Connect to router using Lan cable
and check if you are able to Browse.
If OK go to my tip
Posted on Jan 04, 2009
Conecting to verizon jetpack
I had them and others. They do not work well and are not worth the money. If you have cable with a wifi hotspot option, you would be better off using that.. The Jetpack sucks big time. Cancel the mifi service.
Oct 01, 2017 | Acer Aspire One Netbook
Can not connect to internet
People often get confused about how to connect their netbooks (or laptops) to the internet. It's the same for cheap netbooks or expensive netbooks - you can connect pretty much all netbooks to the internet in four ways.... And it's really easy once you get past the jargon.
1 - Wired netbook connection using your home ISP
The first way, and one I use a lot, is just plug your netbook into your router at home, using the netbook's Ethernet port and the cable supplied with your router.
This way works every time, gives a fast and secure connection, but means that you need to use your netbook within cable distance of your router. Any internet usage will be part of your normal broadband usage with your home ISP, but isn't the point of netbooks that you can be mobile with them? Who wants to have nice new netbooks tied up by a cable?
2 - Wireless netbook connection using your home ISP
Another way to get online with netbooks if you're at home is to connect wirelessly to your home router.
It's a very easy process - just turn the netbook on and it will seek out your router. You get a fast connection, good security (if you tell your router to use WPA encryption) and it will usually work anywhere in your house or garden. Several netbooks, laptops or other computers can use your internet connection this way from the same router, so your family and friends can use their netbooks at the same time.
3 - wifi netbook connection out and about
A really cheap way to get online when you're out and about is wifi. Many busy locations - pubs, hotels, shopping malls - have "wifi hotspots" which are simply powerful wireless routers that you can use to connect your netbooks wirelessly to the net.
Some are free and can be used by any computers that are nearby. Others are owned by telecomms operators like BT Openzone or mycloud and you need to pay to use them. Monthly subscriptions or pay as you go are available. So are these free and cheap choices ideal for using with cheap netboks?
For anything other than general browsing on netbooks, beware of wifi. The free ones have no security at all, and the others have password protection, but the data you send and receive is not encrypted. This means anyone in the vicinity could snoop and listen in on what you were doing. I don't bother with wifi for this reason.
See our separate feature on wifi for more about this.
4 - Your 3G netbook connection - at home or away." width=240 height=131>
netbook dongle for 3G wireless internet
The final way to connect netbooks to the net - (and yes there are only four ways - I told you it was easy) is using the latest mobile phone network - 3G short for Third Generation. Just like a mobile phone, you can pay as you go or take out a monthly subscription with one of the phone companies to suit your needs. Then, using a little device like a USB stick called a USB modem, or a "dongle" plugged into your netbook, you can connect quickly and securely to the net in most of the UK and lots of places overseas. Some netbooks even have a slot to put your SIM card straight in
If you can use a mobile phone where you are, you can probably connect to the internet using 3G. Many people use 3G to connect netbooks to the net even at home and don't bother with a normal ISP.
Your pc could have a phone line input for built in modem DO NOT use that.
Use the lan inlet connector.When you connect the lan cable it should gain access at once.
Unless your connection is protected by a code.
If you have a wire less connection its probably protected with a code when you set the router up.
You have to enter the code to gain access to your network.
Here is a link that shows you how to repair the connection:
And if you have wire less:
Good luck.
Mar 11, 2011 | Sylvania G-Netbook
My acer aspire one wont connect to internet. it says it is connected to wireless, and i have wired it to modem but the problem still persists. please help.
Based on your description, the following is assumed.
1. The service to your Internet Service Provider is through a cable or DSL modem.
2. Internet service was initially set-up with your netbook directly connected to the modem.
3. A wireless router was since added and is using the direct wired connection to the modem.
4. The netbook is connected to the wireless access point being provided by the router.
5. The netbook says it is connected to the wireless access point but still no internet access.
The problem is likely due to the modem capturing the MAC address of the netbook when access to the internet servce was initially set up using the netbook directly connected to the modem and now the modem will only allow access with the netbook directly connected to it. You can check this out by reconnecting the netbook directly to the modem. It may be possible to "flush" the captured MAC by unplugging the AC power to the modem, waiting a few minutes and then powering back up with the router connected in place of the netbook. To make it easier, you may want connect your netbook directly to the router's LAN side to check if you now have internet access through the router. If you still don't have internet access, you will need to use your netbook to log onto the router to clone your netbook's MAC address for the router's WAN connection. The router's user guide/manual has directions on logging in and doing the MAC address clone. It will also have an explanation as to what is a MAC address.
Jan 30, 2011 | Acer Aspire One Netbook 8.9" Notebook
I bought 2 Acer Aspire one netbooks and I can't get either one to connect to wi-fi. They show strong connectivity to the wireless network, but no internet?
you are seeing it strongly connected to the ROUTER---try unplugging the router for a few minutes and plug it back in----Does the netbook "SEE" the network? entered correct ssid? Is the wireless switch enabled on the netbook?
Dec 24, 2010 | Acer Aspire One Netbook
Unable to connect Acer One D250 netbook to 2wire modem. Limited or no connectivity. I can connect through wireless at work and hardwire.Comments: Dec 30, 2009- Netbook sees the network, has excellent...
Replace the Cable and Check.
If the problem still persists then
Give the same network setting to the wireless network adapter as you assigned to your local area connection.
Note: Before doing that remove the IP address of that Local area connection or change it's IP address to some other number.
This will most probably solve your problem.
Otherwise, Used an external USB Wireless Adapter.
Jan 01, 2010 | Acer Aspire One PC Notebook
With an Ethernet cable, connect from the netbook to a LAN port on the 2WIRE modem.
Access the built-in web-server on the 2WIRE modem, and configure the "wireless network settings" to your choice of SSID and network password/passphrase.
Then, from your computer, "View Available Wireless Networks",
and connect to the SSID that you have chosen.
Dec 29, 2009 | Acer Aspire One PC Notebook
I have just bought 2 Acer aspire one netbooks. Before Xmas I checked that these would connect wirelesly to internet and they both did - have now tried again after Xmas and they wont connect wirelessly...
Hello, Vicki.
A drained battery would have no bearing on wireless access.
Since both laptops do not access wirelessly, sounds like as issue with your hub. Try the laptops at a wi-fi cafe to see if they work OK.
Hope this helps.
Dec 28, 2009 | Acer Aspire One PC Notebook
Trying to connect acer netbook to wildblue internet using apple airport extreme. keeps reading "limited connectivity."
"limited connectivity" normally comes up when u type in wrong wireless network key. check the correct wireless password
Dec 27, 2009 | Apple AirPort Extreme Base Station...
Dropped Wireless connection on Aspire One 8.9" Netbook
make sure your isp is suppling your 2nd ip address...
Dec 25, 2008 | Acer Aspire One Netbook 8.9" Notebook
Acer Aspire 5100 Notebook Logo
115 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
