Question about Whirlpool Duet GHW9150P Front Load Washer
F6E2 error code
My washer will not start and the door takes long to unlock. My machine is giving me an F6E2 error code. Can you please give me an idea of what the problem is and how much I'm looking to spend on repairs? Thank you very much.
  • Anonymous Mar 23, 2014
    f6e2 code with water level to high notice
    Top Expert:
  • Whirlpool Master
  • 9,472 Answers
Drive Motor Tachometer Error (Unable to Detect Motor Speed) - Disconnect power and unplug unit. Check wire harness connections between drive motor and Motor Control Unit (MCU), and between MCU and the Central Control Unit (CCU). Reconnect power and plug unit in. Check the MCU by looking for operations of the drive motor, and check drive motor for powered rotations. Replace failed component. Note: If this failure occurs during high-speed spin, the door will be unlocked after three minutes.
Posted on Nov 04, 2012
Lumpy816
  • 246 Answers
SOURCE: whirlpool duet sport washer trouble codes
F21 is a drain error code. You likely have something stuck in your pump. Remove the lower front panel. (there are 3 #20 torx screws on the bottom of it holding it on) Once you have the panel off, the white object in the front center is your pump.
Remove the #20 torx screw out of there to make life easier. Slide the pump forward slightly so you can raise it. Now, on the front of the pump is a handel that you will need to turn counter clockwise. So after placing something underneath to catch
the water left inside the machine ( a large bowl or bucket), turn the knob slowly counter clockwise. If there is too much water for your container, screw it back clockwise and go empty your container. Repeat until all of the water is out. Once that is done, unscrew it all of the way and slide if forward. You will usually find missing socks, toys, coins and all other kinds of fun objects. While you have the trap out, reach in with your finger to the hole on the right. Try and turn the wheel inside to make sure there isn't anything keeping it from turning (bobby pins, nails,
screws, etc) If there is, you will need to unclamp both hoses on the back of the pump and remove any further forign objects. Now re-assemble the unit but leave the panel off. Run a quick fill and drain to make sure all of your connections are tight and
you don't have any leaks. Put your panel back in and you're ready to go.
Please make sure you post a rating if this solution was helpful.
Posted on Jul 25, 2008
SOURCE: F22 Error Code
TAKE 3 SCREWS OUT THAT HOLD THE BOTTOM FRONT PIECE REACH UP BEHIND AND ON THE DOOR LOCK MECHANISM THERE IS A ROUND PLASTIC DOOHICKEY PULL IT DOWN ABOUT 1/2 AN INCH OR AS FAR AS YOU CAN AND IT WILL UNLOCK THE DOOR. I WOULD UNPLUG UNIT FIRST. I DON'T KNOW ABOUT THE F22 THING. MY JUNKER DOES THE SAME THING PERIODICALLY, I UNPLUG AND REPLUG IT TO CORRECT
Posted on Sep 09, 2008
SOURCE: Kenmore Calypso washer Ld code?
I just had the same problem. I borrowed my neighbors wet vac. The hose of the wet vac fit right over the end of the drain hose and I sucked out all the remaining water. My hope was that if the hose was clogged that it would clear it out. It seems that it worked. I put the drain hose back in the drain and turned on the extended spin cycle. It was working, so I put the water logged clothes back in the washer on the extended spin cycle and it took the water out. I am now in the process of washing another load to see if it really fixed the problem. I hope this helps.
Posted on Jan 25, 2009
57 varieties
  • 1653 Answers
SOURCE: ERROR CODE F28
Unplug the machine at the mains. Remove the detergent tray. Reach all the way back with your hand in the slot where the detergent tray normally fits and feel for a lever. When you find it pull it forward. Then replace the detergent tray. Plug the machine back on and the error code will have reset and the machine will be useable again.
Posted on Oct 05, 2009
quatlew
  • 139 Answers
SOURCE: whirlpool cabrio giving error message LD-what is wrong
Long drain error can be caused by something plugging the drain hose or a kink. Tale it off th drain while it is pumping out and check for a good flow. If the hose is ok the pump may have an obstruction causing low flow and it will have to be cleaned out.
Posted on Mar 18, 2010
Whirlpool duet washer mod.#wfw95hexw2 error code f06e02 what is wrong
Here is a handy webpage, it says F6E2 is Communication error between the main control and the motor control.
Whirlpool Duet Washer Error Codes
Nov 08, 2016 | Whirlpool Washing Machines
Kenmore Elite HE5t Washer stops in the middle of cycle with no error codes. Any idea how to fix?
sounds like the door switch either needs adjusted or totally replaced .try leaning against .next time instead of opening it
Aug 24, 2015 | Kenmore Elite HE5t Washer
What is fault f6e2 mean for a whirlpool washer model # WFW97HEXL2 ?
This code pertains to a loss of communication between the UI and CCU take the top off on either the left or right side you should find a plastic packet with the tech sheet for this code it will not pinpoint which is bad two computers not talking to each other from a customers standpoint tough neither part is cheap your gambling experience I change the CCU first
Aug 28, 2014 | Whirlpool Washing Machines
Bosch washer code eo4
Being a drain issue , you need to remove the drain pump, check the filter and also check on the outlet , click catchpot
Jan 20, 2013 | Bosch Nexxt Premium WFMC6400UC Front Load...
Hitachi washing machine error code Fb indicates problems. what prolems is that? Can you list out the meaning ot each error code.
My washing machineSF-110SS
have a display FD. Anybody know what's that means? And how to solve it. Please
Jun 23, 2011 | Washing Machines
Hi. My washer is coding dU then F as codes.. I cant get it to shut off and unlock the door to get cloths out. The book does not have a code for dU.. PLEASE SOMEBODY HELP ME :)
Door unlock error. The machine tried 6 times to unlock the door. Must be an item of clothing jamming the door. take the bottom panel off and reach up and grab the emergency ring, GENTLY release the door amigo. Use this GUIDE for repairs
and use your tech sheet inside that base panel for error codes and diagnostics.
Jan 24, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Error code
"dl"indicates a door lock error. A Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.
Check for the following when dl occurs:
  • Door Lock Mechanism broken.
  • Check Door Lock/Switch Assembly for foreign objects
  • Check Wire Harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
  • Door Lock/Switch Assembly Failure
Thank you !!
Jul 09, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Error Message
Your owner's manual may give a troubleshooting guide for the error code your machine might give you. Is it possible you have locked out the control panel? I "think" the calypso has a control lockout, usually a start button or cancel button. If you press it in for 3-5 seconds, it can lock or unlock panel. If all else fails, try unplugging it and see it it will drain out the water.
May 20, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
F22 Error Code
Sep 08, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
220 people viewed this question
Dan Webster
Dan Webster
Sal De
