Question about AEG 24 in. Favorit 86050Vi Built-in Dishwasher
Error code .60 AEG dishwasher - AEG 24 in. Favorit 86050Vi Built-in Dishwasher
3 Suggested Answers
heralddriver
SOURCE: DISHWASHER AEG 80860
Just fixed a similar problem on an AEG F3A by following other advice on this site. Simply tip the machine forwards on to its door (best empty it of crockery first!!!).and then put it upright again when water has stopped dripping out of it. You wil get quite a bit of water on your floor which I reduced by pumping the water out of the salt resevoir first - but if you don't have a pump just have several towels handy
Posted on Oct 25, 2008
BIKER T
  • 909 Answers
SOURCE: AEG Favorit dishwasher AAA shows Error code 10
Normally if washer doesnt complete cycle, its because the element has tripped the over temp.th/stat.(underneath), or is faulty. otherwise 1 of the 2 boards are faulty. Often the board at the bottom front left.(behind the kick panel.)is the issue. Roaches seem to accumulate on the bottom board and disrupt the circuit. If you have a mechanical timer, wiggle it side to side and note if there is a difference.
Posted on Sep 16, 2009
AEG dishwasher Favorit 86450I displays error code AL7.What does it mean?
i was looking up some info about your dishwasher and this problem might be part of the control board or the pump not turning on in the dishwasher however if one is tech savy you can actually get a ardino board to run the dishwasher (seen on youtube)
Feb 23, 2017 | AEG Dishwashers
I have a AEG Favorit 65011 VI dishwasher which stops in the middle of a programm an shows error ,60 that is not mentioned in the Users Manual. Can you please help me?
Fault in heating phase. Could be:
Heating element, wiring between heating element and power board,
power board (usually relay). Sometimes can help to resoldering (cold solder joint) or replaced relay on power board.
Dado
Mar 10, 2015 | AEG Dishwashers
I have a AEG Favorit 65011 VI (dishwasher) which stops in the middle of a programm an shows error ",60" that is not mentioned in the Users Manual. Can you please help me?
The temperature must increase by a certain amount at each step.
If there is no temperature increase during three minutes, the electronics will generate "Heating Time Out" or fault code i60.
In this case program will continue to the end without heating and the washing result will probably be unsatisfactory.
Could be: Heating element faulty; intervention of safety
thermostats (open); faulty wiring; NTC sensor (poor
thermal contact); insufficient water circulating in the
tub; washing faulty pump (impeller stripped); circuit
board faulty.
Dado
I have an aeg dishwasher showing error code 49 what is this and how do I fix it
Error code E49, generally speaking, at AEG dishwasher does not exist.
Dado
Jan 05, 2015 | AEG Dishwashers
AEG F60873 temperature problems.
The problem when the dishwasher does not heat is failure which requires to remove the qualified personnel and therefore error code is not shown on the display but it is visible in the service mode.
Possible error causes:
faulty heating element
wiring between heating element and PCB
PCB (printed circuit board)
Dado
Aug 24, 2014 | AEG Dishwashers
AEG F65070VI fitted dishwasher error code 46 & 30
This error is flood alert because of a leak in the tub. IT might be a seal but you have to remove it and drain it and lay it down to see and then you need parts.
Jun 04, 2013 | AEG Dishwashers
Error code 30
i fixed the problem by tipping the machine over slightly, as suggested by other members, about a pint of water came out the bottom and it now seems to work perfectly.
Mar 27, 2008 | AEG 24 in. Favorit 60870M Free-standing...
AEG 50760 Dishwasher shows Error Code 30
there is water in the base of the macine. lean it over to the side to get all of the water out then try again.
Feb 14, 2008 | Dishwashers
Dishwasher is on before I physically switch it on
Support AEG Australia
I don't know what "the timer? has gone" means. You can't clear the timer or reset it? I would call their support. There is also support in the UK. But you can take a look at the following page:
http://www.instructables.com/id/How-to-repair-your-AEG-or-Electrolux-dishwasher
No diagnostic codes?
Error codes for AEG Dishwasher
Oct 29, 2017 | AEG 18 in. Favorit F54850 Slim-Line...
AEG 24 in. Favorit 86050Vi Built-in Dishwasher Logo
221 people viewed this question
Top AEG Dishwashers Experts
Oloyede Monsuru
Mike
Are you an AEG Dishwasher Expert? Answer questions, earn points and help others
