Question about Saws
Tire comes off of wheel
The rubber tire comes off of the wheel
    Sergeant:
  • 468 Answers
This could be a big wild guess on how the tire comes off on the wheel. But I'll try to help you this thing. I don't know if your bandsaw has adjustment bolt above the upper wheel and below the lower wheel, but in case there is , use these bolts to center the band saw. Well, this could also be blade tension adjustment. Tires should be a very tight fit and a struggle to get on.
Wait, was tired glued on? If not, reglue.
Is that an old tire? If yes, tire must be well worn out and time to invest new ones.
I recommend you to use this time urethane tires rather than rubber tires.
Rubber tires works fine but urethane tires last longer and doesn't need gluing. When you purchase a new tire, make sure that it is a couple of inches smaller than the wheel to stretch the tire. It is a good advice to slightly tilt the top of the drive wheels towards you. I've been purchasing urethane tire with www.bandsawparts.com. Got one from them and still up running. Piece of advise also,Before installing the new tires, you double-check the surfaces of the pulleys to make sure the surfaces are clean and true.
Posted on Nov 07, 2012
  • 3 Answers
Over time the cheap oem tires stretch out and tend to come off the wheel. Bandsawtirewarehouse.com sells quality urethane band saw tires for your model band saw and most other brands.
Posted on Jan 29, 2013
Cant get my saturn vue 2008 rear tire off
I'm going to assume the wheels are aluminum and the hubs are steel. What's happens is a galvanic reaction when two different metals come in contact. Loosen the lug nuts and lift your vehicle on the jack then use a jack stand for safety sake. Remove the lugnuts and take a rubber mallet and strike the wheel from the inside in several places. If you don't have a rubber mallet, a 2-3 lb mallet will work as well. Keep striking the inside of the wheel all around the rim where the tire meets the wheel and it should come loose.
Dec 28, 2014 | Cars & Trucks
1997 Honda Accord
which wheel...? the flat tire or the spare tire..?
Sep 02, 2008 | 2000 Honda Accord
Flat front tire
you probably have alloy wheels. take rubber headed hammer and hit one side of the wheel, be careful because the wheel could hit you when it comes off.
Sep 24, 2013 | Chevrolet Impala Cars & Trucks
Tire comes off wheel
Are you using new tires? Urethane or rubber? Make sure the adjustment are correct or probably you need to replace the
tires. I am using ulta blue urethane tires because it lasts longer and it doesn't need gluing. Urethanes are more durable
than rubber. I got mine on http://bandsawparts.com/ultra_blue_urethane_tires.cfm .
Jan 31, 2013 | Jet 710115K Jwbs 14CS Deluxe 14 Inch 1 1/4...
Wheel rubber coming off
The rubber part is the tire. If it is balding, you should get it replaced. Have the alignment checked to ensure an even wear across all 4 tires and prolong the life of the tires.
Nov 09, 2012 | Microsoft Wireless Desktop 2000 Keyboard...
CRAFTSMAN BAND SAW 41815 WHEEL TIRE KEEPS COMING OFF
Check the tires maybe it's worn out. If it is, change the tires. I recommend to glue the tires whether it's urethane or rubber. You can try this site for replacement band tires: www.bandsawparts.com.
Aug 08, 2012 | Craftsman 41815 Wheel Tire
The rubber ******** the top wheel comes off
Paint the tire and the wheel with contact cement and let it set till you can touch it without sticking to it, slap on the tire, you should be all set, if the tire is shot, get some new ones. Hope this helps.
Feb 17, 2012 | Sears Saws
The rubber band on the lower wheel keeps coming off. Tried adjusting the tension up and down, no help.
sounds like the rubber tire is worn or the lugs that hold it onto the wheel are worn. Also you might want to check the condition of the wheel bearings while you are looking at it. What you might try in the interim is to reverse the tire and see if that helps.
Apr 21, 2011 | Saws
Took of the front wheel nuts but the wheel will not come off please help
You say Wheel Nuts which leads me to believe you mean the Tire and Rim won't come off. If you have the tire off the ground and all the Lug Nuts removed it may just be sticking a bit. Use a rubber mallet if you have one and hit the tire near where it contacts the rim using a lot of force. Make sure you have the nuts removed first. DO NOT USE A regular hammer to do this or you will damage your rim. If you only have a regular hammer make sure you hit the tire not the RIM. Sometimes the Rims will stick over time. If you are actaully talking about the Brake Disc, make sure you have removed the Brake Cylinders and use a rubber mallet to gently work them off.
Dec 12, 2009 | 2001 Mitsubishi Eclipse Spyder
Saws Logo
248 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
