Question about Singer 3116 Simple
What's your problem?singer simple feeder teeth
Moved lever on singer simple sewing machine and now feeder teeth are not engaged and can't reengage. Does anyone know how to fix without having to open the machine. Sewing pants for daughter's orchestra performance on cello.
  • Singer Master
  • 1,564 Answers
While attempting to engage the feed dogs with the switch, wiggle the hand while a little back and forth. Sometimes that motion will help it slide back into sewing mode.
Posted on Nov 04, 2012
SOURCE: Singer industrial sewing machine
It might be the way you're asking that's confusing the problem. It's simple to remove the hand wheel, slip the belt over the track, and then replace the hand wheel. It really depends on the model of your machine - is it by chance a 328K?
Martie Johnson (USA)
Posted on Apr 05, 2008
SOURCE: singer simple sewing machine will not sew
need needle threading instructions singer 3116 simple. pictures would help. thank you
Posted on Mar 15, 2009
  • 980 Answers
SOURCE: repair singer 502 sewing machine
You can get the fears quite easily and fit them yourself and if you email me I can attach full instructions.
drivewithken@blueyonder.co.uk
Posted on Sep 19, 2009
SOURCE: Reverse Lever isn't working...
Most likely the "dogs" inside the lever are broken off. Oil/grease on the metal rod cause chemical attack to the plastic lever and the "dogs" break. Singer should know to degrease this rod before assembly.
Posted on Nov 06, 2009
  • 1788 Answers
SOURCE: Wads of Thread Caught in Singer Simple Sewing Machine
Sounds like you threaded it wrong and kept trying to sew, gently get all of your material out of the machine, DO NOT FORCE, GENTLY ROCK IT OUT OR YOU WILL WRECK THE MACHINE, also watch your dvd and learn about threading from your book. Always, hold your thread ends when you start to sew. If, you cannot find your manual go to www.singerco.com, I have sewn for 50+ years and found that the dvd was very helpful, each machine is different.
Posted on Aug 21, 2010
Hi there. I have a singer 507 machine which was sewing fine until I changed thread in bobbin and now the feeder teeth are not moving to feed thE fabric thru, not sure what I may have done - Help!
the bobbin has nothing to do with the feed teeth
however it is possible that at some point you moved the forward /reverse knob lever to middle where the teeth will not move
Jan 03, 2017 | Singer Sewing Machines
Singer Sewing Machine 534 repairs
hi it sounds like the timeing has moved on (1) and also on (2) would need to be seen by dealer.
Apr 09, 2013 | Sewing Machines
Singer Sewing Machine model #2638 Does not feed fabric
Here is a link to page 22 of the manual. It shows you where to flip the lever to raise the feed dogs. If your feed dogs are not grabbing fabric your feed dogs are lowered.
https://www.manualslib.com/manual/1050311/Singer-2638.html?page=23#manual
Sep 20, 2012 | Sewing Machines
I cant get the material feeder to come up so that the material can slide
Make sure feed dogs (teeth in needle plate beneath needle) are showing. Flip switch to UP position to "feed" fabric. Sometimes control fir this located on back of machine lower left side and " hidden" by your extension table, so remove that table and you'll find the switch! Jimmy
Apr 07, 2012 | Singer 3116 Simple
Hi, have tried to use buttonhole feature on singer 4423. Dog feed teeth have dropped - won't come back up and the material isn't feeding though. Any help greatly appreciated.
Re: Reverse feed dogs on Singer 4423 Remove extension table so you can see switch on BACK of machine @ left side. Flip switch to raise feed dogs up. If machine actually sewing in reverse - check n Buttonhole adjustment. Reset it (located bottom right side machine) Jimmy
Apr 04, 2012 | Singer 4423 Sewing Machine
Fabric quit feeding through
there called feed dogs & if they don't feed the fabric thur the machine need they need to be check to see whats wrong with them
Mar 07, 2012 | Singer 3116 Simple
I have an Emerald 116 Husqvarna/Viking sewing machine and the feeder teeth have simply stopped feeding. It worked fine the last time I used it a couple of months ago and it hasn't been moved or disturbed...
HOW TO FIX YOUR FEEDER TEETH (DOG TEETH) ON EMERALD 116/118/120 IF THEY STOP WORKING....
So this is just a temporary solution to this problem... after reading through the user's guide (which really needs to be updated to have more troubleshooting suggestions), and basically taking apart various parts of the machine, I found a temporary solution.
1. Unscrew the Face Place (where the needle is attached to. #9 in User Guide Overview) There is only one screw on the side right underneath the Pressure Foot Pressure Dial (#8 in User Guide Overview). Taking off the Face Place gives you room to use a screwdriver for step 2...
2. Unscrew the Needle Plate (#12 in User Guide Overview), and take out the Bobbin holder (black). Slide the lever for the Feed Teeth to the raised position, and with your forefinger pop up the Feed Teeth (underneath the needle) to the raised position. You will here a click... and you are set to go. Reassembly your machine and get back to sewing!
Nov 21, 2010 | Sewing Machines
Oct 10, 2009 | Singer 3116 Simple
Singer simple sewing machine will not sew
Mar 15, 2009 | Singer 3116 Simple
I have a Singer 7442. Was working fine and we recently moved. Now when I start showing, it sews for about 5 seconds then there is a beeping sound and all of the lights flash on the front of the sewing...
the problem may be in the button hole lever sensor . Next time it stops try moving this lever up and down. if it works ,great. If it doesn't , well, the machine has at least a 2 year warranty on electronics.
sewman7
Jun 07, 2008 | Singer 3116 Simple
Singer 3116 Simple Logo
105 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
