Question about Garland H283 Gas Kitchen Range
Griddle is warped - Garland H283 Gas Kitchen Range
    Novelist:
  • 125 Answers
Hi, are you sure the griddle is warped, and doesn't just need to be shimmed on one of the corners ? that is all it may take to level it up again, some of the shims may have fallen out and are sitting underneath the griddle surface somewhere. Hope that helps, and thank you.
Posted on Jan 05, 2009
What is a good electric griddle that can be used at home?
Lodge LDP3 9.5inch griddle would be a great choice to use at home.
Jul 29, 2015 | Kitchen Appliances - Others
I need a 20-in. Electric Griddle. know of any?
Yes, Lodge made a nice 20 inch cast iron griddle has bigger surface to cook more food with two side handles to make it easy to move. You have some other options like Presto 22 inch griddle, check out this link for different size griddles and pans with detailed information.
GroomNStyle Top 5 Best Saucepan and Pot reviews 2015
Feb 20, 2013 | Kitchen Appliances - Others
Viking griddle flaking
I have the same thing happening with my Viking griddle. I have nearly the whole top seasoned to a jet-black state - and it is stick free!! Now up near the front edge the coating/seasoning is chipping off. I've just been taking the loose chips off and not worrying about it too much, it maybe the size of a half dollar at this point. The front edge of the griddle is the hot spot on mine; and I've learned to adapt my cooking techniques. My guess is the hot spot on my griddle is responsible for the flaking...
Mar 25, 2012 | Viking Kitchen Ranges
Griddle top replacement
well this is different, but sounds like fun. I would just Repair the gas griddle you have. from the sound of it you need to replace the 3 or 4 tstats that control the griddle. If you are in a Metro area you can find a dealer for Robert Shaw and get the parts you need. but you may also start at http://www.garland-group.com/. everything there will be newer but you will be able ask about where the data plate is and then get parts lists. call a small comercial kitchen repair company and ask for help there too.
Jan 29, 2012 | Garland Ovens
How do I season the griddle that came with my new gas stove?
This is taken verbatim from page 11 of my Frigidaire Gallery range:
"Seasoning, using and caring for the griddle Before first use: -Wash griddle in hot soapy water. Rinse and dry completely. -Apply a thin coat of vegetable oil to the entire surface (front and back of griddle). -Preheat your oven to 350*F. Place the griddle on the upper rack in your oven. -Bake griddle for 1 hour at 350*F, then turn oven OFF and let cool before removing. -The surface may have a tacky feel to it from the seasoning process. If desired, wash the griddle in hot soapy water, rinse well, and dry completely.
Using the griddle: Remove the center burner grate and carefully replace with the griddle (some models). Preheat the griddle for 5 minutes on medium to medium low setting. Slow preheat ensures even heat distribution during the cooking process. DO NOT preheat the griddle on HI setting. Preheating on HI may warp the griddle and prevent even heat distribution.
After each use: -To prevent rusting, store in a dry place and keep uncovered. -After each use, clean with a stiff brush and hot water only. -Do not clean griddle in the dishwasher. -Dry immediately and apply a light coating of vegetable oil to griddle before storing.
Sep 20, 2010 | Frigidaire 30" Self-Cleaning Slide-In Gas...
Need to replace griddle thermostat
My husband and I just had to check out our griddle on our 48 inch Viking rangetop. You remove the grates and the grate holders on either side of the griddle..it just pops out. Then you raise your griddle up about 4" to remove your thermastats., noting the position they are in so when you replace you can put back correctly. After pulling the thermastats out, then you lift the griddle out. Griddle is extremely heavy so be prepared to have close surface to lay it. Hope this helps.
Carole
Apr 15, 2009 | Viking VGSC306-4B Gas Kitchen Range
Receiver pins broke off vintage Farberware 260 griddle
Would you be interested in selling the Farberware 260 griddle? I need parts for this particular griddle.
Apr 07, 2009 | Faberware Kitchen Appliances - Others
Can grill be safely converted to griddle on Thermador PRG486GLUS?
http://www.instawares.com/add-griddle-top-2.133-1002.0.7.htm
try this.
If it doesnt fit your specs. then i would suggest u find a thermador parts place and begin to buy the parts for the griddle as replacement parts. find a model of the stove set up that you want and make a list of all the parts that go to the griddle attachment.
My guess is that the reason for the flat "No" on the retrofit was that griddles require a thermostat similar to the one on the oven and broilers do not. So if their is no room behind the face plate where the knob would go then you can't put in a griddle. The other issue might be that the burners for the griddle wont line up with the brackets that are holding up all the broiler burners now. The griddle burner looks exactly like the one from the over only smaller so it has to line up strait where a regular front and back burner have to line up offset. maybe since you have the broiler already that should not be an issue? Then the problem is finding the griddle top it self that is going to be spendy. I think the link i gave at the top is your best bet. good luck.
Leslie
Mar 19, 2009 | Thermador PRG484GGUS Gas Kitchen Range
GE 40" range griddle
You will have to check GE. With a model this old, it will be hard to find a replacement.
Feb 11, 2009 | GE 30" Self-Cleaning Freestanding Gas...
Garland range griddle top
make sure your unit is leval if you have alarge build up you will have to remove griddle and claen then reinstall
Sep 08, 2008 | Garland PS-36G-4-26 Gas Kitchen Range
Garland H283 Gas Kitchen Range Logo
176 people viewed this question
Top Garland Kitchen Ranges Experts
John Tripp
John Tripp
joneable
Level 1 Expert
Are you a Garland Kitchen Range Expert? Answer questions, earn points and help others
