Question about Mtd Garden
Huskee Supreme (MTD body) loose steering, looks like some spacer or grommet is missing, but can't find in parts diagram
13AX605H730 Huskee Supreme 46"
  • 472 Answers
Huskee Supreme (MTD body) loose steering, looks li - ?l=mtd&p=76902073%5c0001&nd=0&z=30
OK THE PART YOU NEED IS PART # 37 PART # 941-0656A ITS CALLED A HEX FLANGE BEARING
Posted on Nov 11, 2013
  • 376 Answers
SOURCE: Huskee jerks while going forward
Go to... http://mtdparts.arinet.com/scripts/EmpartISAPI.dll?MF&App=MTD&TF=Empartweb&Lang=EN&searchDB=MTD&loginID=MTDCon&LoginPWD=&xmlPostDest=http://www.buymtdonline.com/webapp/wcs/stores/servlet/processShoppingCart_10101_19502_-1_19502 Enter the brand (Huskee) and model number, not the one you listed, but the one under the seat... hit search and click on illustrated parts, then click on Mower Deck. That will show you the routing and belt number.
Posted on Jul 06, 2009
  • 302 Answers
SOURCE: drive train belt replacement. huskee, mtd.
there should be a diagram on the new belts package showing how it goes
Posted on Aug 13, 2009
mickey813
  • 472 Answers
SOURCE: Looking for mower deck belt diagram for a Husky
THAT NUMBER IS NOT COMEING UP CAN YOU SEND ME THE NUMBERS FROME UNDER THE SEAT
Posted on Oct 08, 2009
SOURCE: Huskee supreme 46 " drive belt keeps comeing off..
mine is to tight..cant adjust the snowblower belt with PTO off it still turns what can i do Huskee tractor...email me at guitarblues60@yahoo.com
Posted on Dec 02, 2009
SOURCE: I don't know how to change the drive belt on a MTD
Go to mtdproducts.com then click on PDF Web Archive then click on "Public Site" then type in your model and serial numbers then down load the online manual then all you have to do is scroll down to page 25 and you're in business.
Posted on Aug 16, 2010
Looking for a LT 4200 huskee manual
Operator Manuals
If you don't find it, give them a call.
Also, here is a link for parts manual online:
https://www.partstree.com/parts/mtd/mowers-lawn-garden-tractor/13w2775s031-lt4200-huskee-lawn-tractor-2013/
Apr 27, 2017 | Garden
I need to know the belt sizes for a Huskee Supreme LT 23 HP 46" cut model # 13BS608H131 SERIAL # 1B173H10127
I serviced my tranny. Opened it up, found the problem, used a washer as a spacer, has worked ever since, and the mower is now about 11 years old.
Jul 09, 2011 | Garden
Lift kit removal, chasey to body
before u do this look at the radiator hoses and the fan,the gas filler hose for the gas tank,the steering linkage,tranny linkage and the exhaust manifold,and the brake lines,tires might be over sized too.Because all of these had to be modified when the body was lifted, after u have looked at this an disconnected the necessary ones then and only then u can remove the lift kit,you will need a floor jack and a couple blocks of wood,start by find all your bolts for this you should find depending on the lift kit,neoprene spacers between your body a frame,u will have to go to the dealer to purchase rubber grommets and shorter bolts to replace the spacers,and bolts,u will be taking out , after u have done this start loosening the bolts have your jack ready so u can lift up the body just enough so u can get the spacer out,depending on size of truck u will have 6 to 8 bolts,if your lift kit is higher than 3 in u might want to get two jacks one on the front end and one on the back so u don't bend the body and put unnecessary stress on it and put your truck body down evenly,after u have removed the lift kit and put all your grommets and the new shorter bolts in then u get to reconnect all the things u had to undo at first,ie radiator hoses and the fan,the gas filler hose for the gas tank,the steering linkage,tranny linkage and the exhaust manifold, and the brake lines,tires might be over sized..hope this helps and good luck
Apr 06, 2011 | GMC Jimmy Cars & Trucks
I have a Huskee Supreme Model # 13AX605H730. I have
According to MTD Parts Lookup:
The correct UPPER belt (referred to as the PTO belt and runs from engine to deck) is part # 754-04122 (Also available as 954-04122...in which only the packaging of the part makes the first digit of the part number change. The two belts are identical.)
The correct Description is:
[ Belt, V-Type, A x 90.24 ]
What that means in plain English is that this is a 1/2 inch wide V-Belt with an Industry Standard "A" cross sectional profile. The more important info would be that it's 90.24 inches long.
As for the "Deck Belt" (the lower belt that runs only from blade to blade to blade) it is listed as part #754-0349 or #954-0349 (again, identical belts, different packaging).
A very common problem we see in my shop is that the front pulley (the one directly attached to the engine) shows signs of separation at the weld and the grovve of the pulley becomes wider, therefore making the belt "act" like it's longer because it runs deeper in that groove.
Reply by using the "Add Comments" section if you need any futher info. I'd be glad to offer other possibilities for these symptoms you've described.
Hope this helps,
Dolf-
Oct 17, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
Drive train belt replacement. huskee, mtd.
Aug 13, 2009 | Mtd Garden
Hello porkeybyrde3:
You can Use the Breakdown to See if a Component is Missing or Assembled Wrong.
You can View a Breakdown/IPL of this Mower at this Site Addy, http://www.smallenginepartswarehouse.com/parts.asp and Select the Shop Online Parts Look Up. Then Select the Model Tab. Then Select the OEM (MTD) and Enter the Model Numbers. Then Double Click on the Model in the Results Area. Now you can Select the Section of the Mower you Wish to View.
>>If you cannot Locate the Model, then
>>Send me the Model Numbers Off the Mower, Please. With these I can Locate the Proper Manual and Better Assist you. The Model Numbers are Usually Located Under the Seat on a Sticker or Tag on the Body.
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
May 14, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Garden Logo
352 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
