Question about Electronics - Others
Need manual for Schumacher 2000W Power Inverter model #pif-2000
Plaese add link
Skinnerd1
  • 13 Answers
SOURCE: Need manuel
Here is a link to your manual.
http://manuals.batterychargers.com/manuals/00-99-000854.pdf
Posted on May 22, 2009
  • 608 Answers
SOURCE: Lost the wall charger of my Schumacher 400w power
Ah, I see, it seems what you have is a power pack. If so it would contain a gelcell battery, probably 12 volts. If this is true, then you may charge it with any 14-16 volt wall charger. You have to make sure you observe correct voltage and correct polarity when connecting up. Also you may have to obtain and change the plug on the charger wire.
I'm assuming the battery DC output is inverted to AC and you use it to power small AC appliances.
Posted on Mar 21, 2010
atthings
  • 59 Answers
SOURCE: shur-dri motor will not run on inverter
If your application is really One Horsepower. 745.7 watts then the inverter should be sufficient. However I can not be sure without more details
Posted on Jun 06, 2010
SOURCE: I need a replacement charger for my Schumacher
will not charger the batterys
Posted on Apr 24, 2011
  • 70 Answers
SOURCE: I have a pure sine wave power inverter 1000watt -
check the fuse on the unit
Posted on Jun 12, 2011
Where can I buy a replacement 45 amp fuse that goes in the Schumacher 750 watt power inverter?
According to the Schumacher 750W power inverter manual it can take two 40 or 50 amp spade type fuses which can be found on ebay with the link below.
40 amp spade type fuses
Sep 03, 2014 | Electronics - Others
Burning smell
What is the wattage of the device you are trying to run? Its possible that its too big for the inverter and its running hot.
Feb 09, 2014 | Whistler 2000w Power Inverter
Inverter
Hi Shirley
In 2006, Black & Decker purchased Vector Products, Inc. the maker of the inverter in question. Please click this link for more information.
I hope this helps & good luck!
Jan 07, 2013 | Vector 2000w Power Inverter
Have a 2000w inverter in my rv just purchased 3 months ago a olp light on and constant beeping what is the problem ,
With inverters and generators, the power rating is usually off by about a quarter.
Watts and volt-amperes are totally different and sometimes inverter manufacturers don't tell about the difference. A basic rule of thumb is to take whatever the inverter is rated for and knock a quarter off. So, in your case it would be best to assume a maximum rating of 1500 watts.
Also, inductive loads like drillers (electric motors) usually have a start-up current 3 to 8 times the rated operating current. Meaning that 100 watt driller will draw 300 watts to start up. So, if you use an electric motor rated at 700 watts, its startup load would be 2100 watts or even more and thus trigger the inverter overload switch. Hope this helps you.
Aug 04, 2011 | Schumacher Electronics - Others
My inverter keeps going to falt even though i only use it for a few seconds its only a few months old and has not been used mush its a 1000 2000 max
What are you trying to power with the inverter? Do you know how many watts your appliance need to run? Your 1000 watt inverter needs 83 amps from your battery to drive a 1000 Watt appliance. The minimum size wire you need to hook up the battery to the inverter is a size 6 as short as possible but no more than 25 ft.
Jul 28, 2011 | Inverter 1000-2000w Peak Surge Power
2000 watt cobra inverter keeps saing olp, overload
2000w means is out off rang load 2000w plus then alarm beep have running.
Mar 24, 2009 | Cobra CPI 1000 DC to AC Power Inverter
Electronics - Others Logo
330 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
