Question about Philips HR1861 700 Watts Juicer
How to clean philips juicer
How to remove foil mesh
I have been given an Anthony Worral Thompson juicer by Breville byt and unable to get the mesh try out to clean it. How do I remove it?
Sep 23, 2011 | Breville JE3 Juicer
I cant remove the blade or mesh basket to clean it.
you need the orange crescent shaped tool to loosen the filter
Jun 28, 2010 | Jack Lalanne Power Juicer 250 Watts
How do you take it apart to clean it ?
It's really easy, you take down the metal bar and the top comes off, then you should see the orange mesh basket which is removed using your little tool - it's like a key which you turn to remove the basket - rinse under the tap - piece of cake.
Mar 15, 2010 | Jack Lalanne Power Juicer (Stainless...
HOw do i clean it?
flip down the lever to pull it all apart.
rinse out the lid, food pusher and base(that the mesh filter sits in).
scrub out the mesh filter with a dish brush or the included brush if you have it. be carefull the grater-like parts at the base are very sharp. make sure it's clean by holding it up to the light. if there are any particles left clinging to the mesh it will seriously interfere with the effectiveness of your juicing.
you can line the pulp collecting jug with a plastic bag so that you dont have to clean that out as well.
it's best to clean everything immediately. if for some reason you can't, at least rinse the plastic parts and leave the mesh basket to soak until you can get back to it.
if you have any dried food or staining on any of the parts then a soak in water with lemon juice in it (maybe the juice of 3 or 4 lemons) should help soften up particles and strip away stains.
hope this helps....
Jan 09, 2010 | Breville JE900 Juicer
HOw do I get the metal filter off, I can't remember and I cannot find my book
The crescent tool has two protruding metal “nubs”. After you open the juicer so you can see the mesh basket that turns around, and a flat grating disc that has two holes that match those nubs. Insert the nubs into the holes and turn counter-clockwise to loosen the disc. (you’ll have to hold the plastic edge of the mesh basket so it doesn’t turn). Once it’s loose, keep turning it until it comes off. You can then remove the disc, the basket and part containing the spout to clean them. Just reverse the process to remount the parts, making sure not to overtighten the disc.
Oct 26, 2009 | Jack Lalanne Power Juicer 250 Watts
Amazing juicer cant take apart to clean i have no instructions
You should have a little handle lock with it, that you attach to the holes on the mesh sieve, that lifts it out, then the rest can be dismantled.
Sep 03, 2009 | Juicers
STRIPPING DOWN THE JUICER FOR CLEANING
Yes.  There should be an orange handle-looking accessory with to small metal rods sticking out that is made to clik into the wire mesh screen and unlock it be twisting the screen mechanism slightly so you can unscrew it out.
See the enclose photos of the tool.
Hope this helps...
-enov8
Mar 03, 2009 | Jack Lalanne Power Juicer (Stainless...
Cleaning a Mesh Filter on my Juicer
The stiff brush that came with mine has worked well for me. Have you tried a fingernail brush or maybe some canned air?
Nov 19, 2007 | Juicers
OPENING the JC-250 Juice Extractor
Hey, you probably have figured it out! I just got a juicer without a manual and couldn't find a way to dismantle for cleaning but I got it!!!!!!!!! Just put it upside down and twist and turn. Everything will fall off ( cutter and container). I'm so happy to help!!
Jan 22, 2007 | Brentwood JC-250 Juice Extractor 350 Watts
Philips HR1861 700 Watts Juicer Logo
Top Philips Juicers Experts
eyecam
Tom Chichester
David Payne
David Payne
Are you a Philips Juicer Expert? Answer questions, earn points and help others
