Need a circuit board for a goodman furnace
I was told I need a new circuit board for my furnace. Does anyone have a good site they use to purchase parts and maybe even a part number? I figured it couldn't be too hard to find online...boy was i wrong!
    Problem Solver:
  • 9 Answers
Have you tryed ebay they sometimes have them from people that bought them and didn't need them the prices are very reasonable compared to what factory dealers want to charge if you have the part number that will help you alot in finding the right one.
Posted on Nov 04, 2012
5 Suggested Answers
  • 56 Answers
SOURCE: glow light blinks once
One thing to try is to check the voltage coming to the furnace to see if it is correct. They do have separate furnaces for California because of the NOX compliable laws but the boards according to my vendor are all the same. Look on the new board to see if you see any of these numbers # PCBBF112S or 01030F00005S. If you do have one of these numbers it is the correct board. If not change the board or if voltage is wrong get that corrected and you should be fine
Posted on Feb 13, 2009
  • 76 Answers
SOURCE: Need circuit board for Goodman GMNP-060-3 Rev B Furnace
Go to your nearest HVAC supply house. They should be able to get you it.
Posted on Aug 06, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: common terminal location on a goodman furnace
White wires are commonly the common connection (sorry for the pun). L2 is also considered the common leg. You did not mention if you are looking for high voltage or low voltage common. L2 is your high voltage leg. If the power venter ties into the thermostat circuit, W on the circuit board is the common terminal.
Posted on Dec 01, 2009
  • 9 Answers
SOURCE: Goodman GMPN060-3 Furnace will not stay lit.has
possible faulty gas valve if all fail safes stay closed. make sure flue is clear for pressure switch to stay closed.
Posted on Dec 16, 2009
Trying to set my goodman gmvc9570 two stage furnace to low fire all the time but do not have the manual to show me how can u help
Move dipswitch 3 on circuit board to on position. This way furnace will only kick into high if you have 2 stage stat and stat tells it to kick in.
http://www.goodmanmfg.com/Portals/0/pdf/M-Info/IOs/IO-GMVC8.pdf This web site will be for a gmvc80 but I believe the stages work the same. Page 17 is the setting you need.
Jan 21, 2011 | Goodman GMS90703BXA Heater
Hi I was told that if you buy a new goodman furnace on
True, because there is no installing contractor involved with the sale the manufacturer cannot be assured that the heater will be installed properly. Contact a local installer to see if they can sell you the equipment for a few dollars over their cost if you pay them to install it. It may be cheaper in the long run especially if you are purchasing a Goodman. If not, follow the installation instructions to the letter.
Feb 15, 2010 | Goodman GMS80453ANA Open Flame Mid-Size...
I have installed Generalaire 1137 humidifier to an Goodman Furnace. Furnace Circuit board has 115V Hum terminal for black wire. should I connect the white wire to EAC terminal on circuit board as well.
The white wire needs to go to an "N" terminal. There are usually a number of white wires all in one spot and a bunch of "N" ternimals. Hook the white wire to any of the empty ones.
Heatman101
Jan 29, 2010 | Goodman Furnace Draft Inducer Blower ...
Goodman GMP Furnace problem. Original problem is
Good one! Is the flame getting to the flame sensor within the few seconds? Maybe a good cleaning of the burners or flame tray would help. 1.3 ma is enough for the flame rod to tell the board to stay on. Re-do all the ground connections both at the board and furnace cabinet to be safe. Check the polarity of the power going to the furnace. What are the chances the second board is bad?
Jan 15, 2010 | Goodman Heating & Cooling
Common terminal location on a goodman furnace
Dec 01, 2009 | Goodman GMS90703BXA Heater
Yesterday the furnace was working and now doesn't come on.
You will need to have a service technician come out. It could be a fuse out on the board, a bad board or several other problems in the circuit that can only be determined by a professional on site.
Oct 03, 2009 | Goodman GMS807034ANA Heater
Apr 04, 2009 | Goodman GMS90703BXA Heater
Glow light blinks once
Jan 08, 2009 | Goodman GMS90703BXA Heater
Ignitor last a day then goes bad again going on 4th try help .
You are getting improper voltage to the ignitor. Check all grounds both in the furnace as well as at every connection heading back to the circuit breaker panel. If you find none, you will need to replace the circuit board.
Dec 08, 2008 | Goodman GMS90703BXA Heater
Heating & Cooling Logo
53 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
