What is the Sky remote code for a Sage TV model 51-26?
This manufacturer does not seem to be listed anywhere that I search and therefore I cannot find the 4 digit code for my sky remote to operate the TV. The TV remote has packed up.
SOURCE: trying to set up sky remote with TV (19LG3000)
The Sky Remote Code 1280 worked for my Sky+ box
Dannyboi1940
Posted on Feb 18, 2009
chrispurs1
  • 372 Answers
SOURCE: Tv wont switch to Sky when remote control is pressed
Hi.
On the sky box do the following.
Check scart to tv is in the correct socket marked TV.
Try pressing services
then system setup
then picture settings.
Then try switching scart control to on or off.
If this sorts it great. If it doesnt check scart lead has all pins wired & not only A few.
http://dysonmanuals.llc.nu
Chris..
Posted on Jan 20, 2008
SOURCE: BOUGHT SAMSUNG LE40A656 LCD CAN,T GET SKY REMOTE TO WORK
I tried the closest model no. in the Sky list in the system setup, I think the code was 0840. Cover the front of the remote and press TV, then press red & select button until the remote led light blinks twice, key in the code 0840 and then press select.  Try the volume button and this should work.  If you get stuck go into interactive and system setup and select setup of sky remote and it gives you a list of makes and models, this is the closed one to the LE40A656 and works with mine.
Hope this works for you.
Posted on Jan 28, 2009
  • 325 Answers
SOURCE: Can't find a code for my ver 6 sky remote for LG50PS3000 TV
on your remote:
TV,
red + select (blinks twice)
TV,
0056,
press VOLUME button if this does not work press TV then repeat
once the VOLUME button works your telly press the SELECT button (stores the code).
If this does not work its because you have a rev 6 remote. take the cover off the battery case and it will tell you the rev number.
I install sky day in day out and ive only had one LG telly that did not accept this 0056 LG manufactor code.
The HD rev 8 remote will work no problem if you follow my steps..
Hope this Helps
Little Dish Fitter
Posted on Sep 01, 2009
SOURCE: remote control code for ONN tv, Model- LE 19L`cdd-vd0701`
Flat Panel Televisions I HAVE A SKY+ BOX AND NEED A Remote control code for ONN tv, Model- LE19LCD0801
Posted on Jan 03, 2010
Hi I have a poloroid 32" LED tv MSDV3233-U3 Need a code to operate sky q remote ECO60
polaroid is the badge not the manufacturer, Its probably manufactured by Starlight, sky dont list any codes for them, but they do list 3 under starlite.. which may be the same company .065,037,292 all worth a try I suppose. http://sky.xorro.co.uk/sky-remote-codes.html#biglist
Oct 18, 2017 | Televison & Video
I have a 30" Targa Visionary TV, model LT 3020. I cannot find a code to make it respond to the latest, rev 9 (or older) Sky Remote.
you will have to ask for the sky operator for the code sir.
mostly there wont be any code. just ask him if you need to change some settings to make it respond.
Aug 02, 2008 | Televison & Video
NEED SKY CODE FOR AKURA APL3221W-HDID
Firstly you may need to identify which version of remote control you have, versions that are dated pre 2002 may not operate the more modern TV's and a new remote control will be needed see:New Remote Control Prices . To see which version you have, open the battery cover on the back of the Sky remote and look at the text on the sticker it will state 'Sky rev' (or Sky+ rev or Sky HD rev), followed by a number, such as 4, 6 or 8. This number indicates the version of your Remote Control.
Version 1: August 1998
Version 2: December 1999
Version 4: May 2001 (Sky+ introduced)
Version 6: March 2004
Version 8: January 2006 (includes all current Sky+HD remote controls)
Programming the remote control
To control your TV firstly switch on the TV set, point the Sky remote at the TV, press the "TV" button on the Sky remote, then press and hold the "Select" and "Red" buttons together until the red light at the top of the Sky remote control flashes twice. Enter the code for the TV listings below (Use the 4 digit codes from the left hand column), the red light will flash twice if a valid code has been entered. Press the standby button on the Sky remote control, this should switch the TV set off, if so then press the "Select" button to store the settings. You should now be able to switch the TV back on and use the volume control button from your Sky remote.
If the TV did not switch off then it may require a different code, you can either start again using one of the alternative Direct codes below or continue with this process by continuously pressing "TV" then "Standy" then "TV" then "Standby" etc until the TV set switches off. This will provide a manual scan for variations within that product code.
If you are still unable to control your TV from the remote control see: Programming The Sky Remote or go to Sky's official website where you can see if a particular remote control version number will operate your make of TV, this can be found at: Sky please remember to use your back button.
Akura 0042 246, 292, 397, 065, 440
Apr 09, 2011 | Televison & Video
Need a code so that i can operate my LG tv. model no. 37LG5010 using my sky remote.
Firstly you may need to identify which version of remote control you have, versions that are dated pre 2002 may not operate the more modern TV's and a new remote control will be needed To see which version you have, open the battery cover on the back of the Sky remote and look at the text on the sticker it will state ‘Sky rev’ (or Sky+ rev or Sky HD rev), followed by a number, such as 4, 6 or 8. This number indicates the version of your Remote Control.
Codes are 0065, or 0405,or 0037
Code are 0065, or 0405, or 0037
Code are 1293, or 1206, or 0206
To control your TV firstly switch on the TV set, point the Sky remote at the TV, press the "TV" button on the Sky remote, then press and hold the "Select" and "Red" buttons together until the red light at the top of the Sky remote control flashes twice. Enter the code for the TV listings above (Use the 4 digit codes), the red light will flash twice if a valid code has been entered. Press the standby button on the Sky remote control, this should switch the TV set off, if so then press the "Select" button to store the settings. You should now be able to switch the TV back on and use the volume control button from your Sky remote.
If the TV did not switch off then it may require a different code, you can either start again using one of the alternative Direct codes above or continue with this process by continuously pressing "TV" then "Standy" then "TV" then "Standby" etc until the TV set switches off. This will provide a manual scan for variations within that product code
Apr 25, 2010 | LG 37LG50 37 in. LCD HDTV
What is the code for a sky remote control to user on an ATEC 32" tv?
I do not know what version sky remote you have but I'm not sure it matters. I could not find any codes for your Atec TV anywhere. Chances are it's a new manufacturer possibly a home brand. This is a brand sold manly in a localized area. But because of the web it allows it's sale anywhere.
The first link is to Sky.com help. The second is basically telling you if your TV isn't listed give them time.
I will ad that I have seen some issues with the picture of Atec TV's not being properly display when used with the Sky system.
Sorry I couldn't be of more help. I will keep an eye out for update regarding your remote and TV. If one pops up I'll post it to this thread.
"HAPPY (insert preference here)" and "MERRY NEW YEAR" To you and yours.
http://www.sky.com/portal/site/skycom/skyhelpcentre/producthelp?nodeId=73a6e9e0-0ade-4eed-810b-cec670799bcc&articleId=11320303
http://www.sky.com/portal/site/skycom/skyhelpcentre/producthelp?nodeId=73a6e9e0-0ade-4eed-810b-cec670799bcc&articleId=5111510
Dec 21, 2009 | Acer Televison & Video
How do i key in code for digibox
TO PROGRAM THE remote USING THE 3 DIGIT CODE:
1. Turn on the TV receiver
2. Press TV on the Sky Remote Control
3. Hold down SELECT and the RED buttons together for approximately two seconds, until the RED LED on the Sky remote blinks twice.
4. Enter three digit code from list for the receiver (early versions now flash twice).
5. Press select to enter code structure (the LED will flash twice if a valid code has been entered).
6. Now press the STDBY button and test other functions.
Repeat if necessary until a code is found that works most common functions.
TO PROGRAM THE remote USING THE 4 DIGIT CODE:
1. Turn your TV on.
2. Press tv on your Sky remote control.
3. Hold down select and the red button together for about two seconds, until the red light on the Sky remote control blinks twice.
4. Press tv on your Sky remote control again.
5. Key in the four digit code for your brand of TV. The light on the Sky remote control blinks twice. If the light blinks once only, recheck the code for your brand of TV and start again at Step 1.
6. Press the standby button on your Sky remote control. If your TV switches off, press select. The light on the Sky remote control blinks twice (code stored). If your TV does not switch off, press tv, then press the standby button. Repeat this (press tv, then standby) until your TV turns off, then press select (stores code).
If at this point the LED on the Sky remote control blinks three times then all possible codes for that make of receiver have been checked. Repeat from step one, ensuring that you enter the correct manufacturer code.
At the end of the sequence, if you see the TV Guide screen, the remote control setup process is complete. If you did not see the TV Guide screen, you must now complete the following steps.
8. Press tv on your Sky remote control.
9. Hold down select and the green button together for about two seconds, until the red light on the Sky remote control blinks twice.
10. Key in the number of the channel on your TV that you use for watching satellite TV.
11. Press select on your Sky remote control. The red light blinks twice. The remote control setup process is complete.
If after trying this, you still have problems, call your broadcaster's help desk. For your broadcaster's help desk number, select the Telephone Numbers option from the Services screen.
Dec 19, 2008 | Computers & Internet
My sky remote wont control the volume on my tv
Hi Re Easytouch 42" HD TV - look for Hisense - I took a guess and LCD3204 EU code 376 - remote works but buttons don't tally up - getting there slowly!
Just bought a madeforyou 4:1 remote that is programmed on my PC.
Ok - not proper solution yet but nearly there!
Dec 19, 2008 | Televison & Video
Trying to set up sky remote with TV (19LG3000)
Dannyboi1940
Nov 24, 2008 | LG M1910A 19 in. LCD Television
Televison & Video Logo
87 people viewed this question
Top Televison & Video Experts
