Question about Air Intake & Fuel Delivery for Toyota Camry
Cranks, has spark, won't start
    Top Expert:
  • Toyota Master
  • 76,691 Answers
The following are the general instructions on the start of diagnosing any electronically controlled engine or transmission problem.
The engine and the automatic transmission (transmission control is only for automatics, engine is still computer controlled no matter the transmission type) in this vehicle are computer controlled and in most cases when a fault occurs a fault code is stored in the memory of the computer control module. There are exception to this, such as the Mass Airflow Meter and fuel pressure problems. What must be done is to have all the basic testing done such as a scan of the system for fault codes as well as a check with a live data scanner tool for engine functions that are not within range of normal, a trained technician is required to know what is correct and what isn't, then based on careful diagnostics done from a factory repair manual the correct part is replaced or the wiring repaired or the computer replaced (known as the PCM or ECM,ECU), which is very rarely the problem. Other basic checks must be done as well such as mechanical problems with the engine as well as engine state of tune and mileage on the engine. The transmission can have mechanical issues as well such as no gear engagement at all or a failed pump or other pressure related problems. Also engine mechanical problems can and do cause many drive-ability related problem such as rough idle and other symptoms.
Posted on Nov 05, 2012
My 2000 honda civic wont turn over and has no spark but the ignition coil and modual are both fine
Won't turn over? Do you mean the starter won't crank the engine over?
Or the engine cranks over and won't start, and you have tested for spark when cranking and have no spark? And then you have tested the coil and ignition module, and they tested out good? Am I on the right page here? If so, maybe the next thing to check would be the crank position sensor. The ecu (computer) signals the ignitor (ignition module) when to initiate spark after it digests the signals from the crank position sensor and the cam position sensor.
Nov 04, 2012 | 2000 Honda Civic
My engine won't start
in the dark have the bonnet open & have someone crank the vehicle. you listen & look for where the spark is arcing. when found repair.
Oct 10, 2012 | 1996 Toyota RAV4
My 4 runner starts sometimes and won't other times, it justs cranks over but won't run
As with any no start issue, you will need to check for spark and fuel pressure when it won't start to know how to proceed.
Aug 19, 2012 | 1997 Toyota 4Runner
Mac 3516 chainsaw won't start
Electronic ignition units work off speed of rotation so make sure yoy are cranking the engine fast enough, make sure the plug is well earthed against the cylinder whilst cranking, make sure the switch is in the on position, if there is still no spark you will have to replace the unit.
Aug 02, 2012 | Garden
2002 Chevy impala won't start
it could be multiple things, like .spark plugs. air filters. computers. fuel filters, and all kinds of different things
Jun 23, 2012 | 2002 Chevrolet Impala
My MTD Yard machines riding mower won't start.
Probably dead gas from sitting too long. Dump it out & put in fresh gas.Could have moisture in it. Pull out spark plug & crank it over several times after putting gas & let it sit a while to dry out or blow it out with compressed air. It should go.
Apr 04, 2012 | Mtd Garden
Going70 MPH cut off & won't crank
@ items of concern spark or fuel. For spark as you crank the engine ,assuming that you have a tach on the dash.Does the tach show movement(this will be very small) if it does you have a fuel problem if it doesnt then you will need a crank position sensor
Jan 22, 2012 | 2005 Kia Sedona
Jaguar xj8 2001 just completed timing chain & tensioner replacement. engine cranks won't start, what is the best trouble shooting sequence to use?
DID YOU RECONNECT IGNITION COILS AND THE VARIABLE VALVE TIMING SOLENOIDS.CHECK SPARK PLUGS IF YOU GETTING SPARK AT SPARK PLUGS.MORE LIKELY VALVE TIMING OFF.
Jul 04, 2011 | 1998 Jaguar XJ8L
Air Intake & Fuel Delivery for Toyota Camry Logo
130 people viewed this question
Top Toyota Vehicle Parts & Accessories Experts
Randy Ohler
ashburton
Colin Stickland
Colin Stickland
Are you a Toyota Vehicle Part and Accessory Expert? Answer questions, earn points and help others
