Question about Nikon Coolpix S4 Digital Camera
Nikon coolpix s4 camera: want to download internal memory pics onto my camera card and need to find "copy" in playback menu but can't find playback menu. Can you help?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Nikon Master
  • 102,366 Answers
Press the Playback button (the right-pointing triangle, just to the right of the MENU button) to enter the Playback mode then press the MENU button to bring up the Playback menu. Copy is the seventh item on this menu.
Posted on Nov 05, 2012
SOURCE: Nikon Coolpix 5200 Getting Message ""Memory Card is Write Protected"
Inspect your SD card carefully. Some SD cards come with a write-protect lock switch on the side of the card. When looking at an SD card from the top there is one required notch on the right side (the side with the diagonal notched corner) and on the left side there is usually a switch. This is the write-protect switch. When this write-protect switch is in the down position (away from the end that is inserted) then it is write protected and read-only. When the switch is in the up position it is write enabled.
Posted on Jun 10, 2007
SOURCE: black monitor Nikon Coolpix S4 Digital
Give the lense side of the camara a few moderate slaps while moving camara from bright to dark obgects back and forth. the shutter gets stuck and doesn't respond to changing light. that's why outdoor pictures are usually too bright and indoor pictures are black.
good luck.
Posted on Aug 19, 2008
  • 69 Answers
SOURCE: Memory Card Capacity for Nikon P4
you can put a 16 gig in without any trouble
Posted on Dec 20, 2008
robmcd27
  • 423 Answers
SOURCE: nikon coolpix L11
I'm sorry but you can't use the camera as a webcam. Here is why. There is no function on the camera to stream video.
Also, the camera goes into standby mode after 30 seconds (by default). And 3 minutes after that, it shuts off completely. It does that to save batteries. Again. I'm sorry. Good webcams average between $20. to $50. usd and they are made to work 24 hours a day 7 days a week.
You can use a 4GB memory card in your camera, as long as it's an SD card.
If you get that message, it means you haven't formatted the card for use in that camera. You have to format the card in the camera before you use it.
Even though the solution was not what you prpbably wanted, don't let it stop you from rating it a fixya. I would appreciate it. Let me know if I can help you with anything else, and thanks for coming to FixYa.
Rob
Posted on Feb 23, 2009
SOURCE: Nikon coolpix 4600: How to transfer pictures from camera to card?
ok I figured out how to do it! put the memory card into the camera, then go to view the pictures. Then press the menu button and scroll until you see the copy button. Then you will see the option to copy from camera to card, or card to camera. Press the option to copy from camera to card and press select all....(or whichever pictures you want copied...I wanted all pictures copied). Then voila! it takes a few seconds to copy from the camera to the card, and there you have it! :)
Posted on Dec 26, 2009
How to find playback menu
Nov 03, 2012 | Nikon Coolpix S4 Digital Camera
How do I take the pictures out of the internal memory and put them on an SD card so I can take them OUT of the internal camera memory?
Use the "Copy" command in the Playback menu to copy the pictures from the internal memory to the card. Once the pictures have been safely transferred to your computer, format the internal memory to clear it.
Jun 19, 2012 | Nikon Coolpix S6100 Digital Camera
How do I transfer pictures on the internal memory of my Nikon Coolpix P90 to an SD card?
With a formatted card installed in the camera, press the MENU button, select the Playback menu (right-pointing triangle), then select the "Copy" command.Full details are in the "Copy" subsection of the "Playback Options: The Playback Menu" section of the manual (page 134 in my copy). If you need a manual, you may download a copy here.
Apr 15, 2012 | Nikon COOLPIX P90 Digital Camera
How do I save pictures on my camera's internal memory on an external memory card without a cord?
Use the Copy command in the Playback menu.Press the Playback button (right-pointing triangle) to enter the Playback mode, then press the MENU button. Select the "Copy" command and press the OK button.Full details are in the "Copy" subsection of the "Playback Options" section of the manual (page 110 in my copy). If you need a manual, you may download one here.
Apr 11, 2012 | Nikon COOLPIX S570 Digital Camera
How to download from internal memory of coolpix S210
Use the Copy command in the Playback menu to copy the pictures from internal memory to a memory card. You can then download from the memory card as usual.
Alternatively, if you want to use the USB connection, remove the memory card from the camera before connecting the camera to a computer.
Mar 01, 2012 | Nikon Coolpix S210 Digital Camera
How do I get a picture from my internal memory to a memory card
Press the Playback button (right-pointing triangle). Press the MENU button. Select "Copy."
Sep 11, 2011 | Nikon Coolpix S4 Digital Camera
I have two problems: 1) how do i transfer pictures from internal memory to memory card? this is from a nikon coolpix s200 camera. it was just given to me without the usb cable and the driver. 2) can i...
1) There's a "Copy" entry in the playback menu that will let you copy pictures between the internal memory and the memory card. Display the playback menu by pressing Playback (the right-pointing triangle) and then MENU. In my copy of the manual, it's on page 94.
2) Consider NOT using a driver at all. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Nikon Transfer or any other photo cataloging program.
You can download the current versions of all (free) Nikon software from
http://support.nikontech.com/app/answers/detail/a_id/61
May 04, 2011 | Nikon Coolpix S210 Digital Camera
Cannot figure out how to move pictures taken on Nikon 3200 without SD card in by accident. Want to move pics from camera to SD card. How?
Use the Copy command in the Playback menu to copy your pictures from internal memory to the SD card, then download them from the card as usual. Full details are in the "Copy" section beginning on page 79 of the manual.
Dec 28, 2010 | Nikon Coolpix 3200 Digital Camera
How do I transfer my pictures from the internal camera memory onto the computer?
One of two ways.
1) Remove the memory card if one is installed. Connect the camera to the computer using the USB cable. Transfer pictures normally.
2) Copy the pictures from the internal memory to the card, then take the card out of the camera and plug it into a card reader. Transfer pictures normally.
To copy pictures from the internal memory to a card, press the playback button (right-pointing triangle) to enter playback mode, press MENU, then select "Copy".
You can use the USB connection or the card reader, whichever you're more comfortable with, whichever you normally use.
Oct 18, 2010 | Nikon Coolpix S3000 Digital Camera
My coolpix s9 cam will not transfer pics from cam..i would use a card reader but the pics are on the cams harddrive and not the sd card...please help!or does anyone know how to tranfer pics from cams...
You can copy pictures from the internal memory to a memory card by selecting "Copy" from the Playback menu.
Press the MENU button to bring up the main menu, then select the right-pointing triangle to get into the Playback menu.
Jun 28, 2010 | Nikon COOLPIX S9 Digital Camera
Nikon Coolpix S4 Digital Camera Logo
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
