Question about Nikon Coolpix S4 Digital Camera
How to find playback menu
Want to download pics on internal memory to camera card but can't find "copy" in playback menu. (where is playback menu?)
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Nikon Master
  • 102,366 Answers
Press the Playback button (the right-pointing triangle, just to the right of the MENU button) to enter the Playback mode then press the MENU button to bring up the Playback menu. Copy is the seventh item on this menu.
Posted on Nov 05, 2012
SOURCE: Nikon Coolpix 5200 Getting Message ""Memory Card is Write Protected"
Inspect your SD card carefully. Some SD cards come with a write-protect lock switch on the side of the card. When looking at an SD card from the top there is one required notch on the right side (the side with the diagonal notched corner) and on the left side there is usually a switch. This is the write-protect switch. When this write-protect switch is in the down position (away from the end that is inserted) then it is write protected and read-only. When the switch is in the up position it is write enabled.
Posted on Jun 10, 2007
walkietalkie
  • 32 Answers
SOURCE: No image on screen
If you want to follow my way to try fixing it yourself, keep reading and do it at your own risk. You paid several hundread dollars for the camera and I just paid $20 for it. Therefore, I tried everything I can to make it work, even if I had to open the camera body to play with the inside. Fortunately, it was not neccessary to take it apart.
Once again, AT YOUR OWN RISK to follow my way to get back your real time image screen.
Read the following steps once and make sure you understand before action.
(1) Load your camera with a freashly recharged battery.
(2) Switch on to see if it's working and still without the real time screen.
(3) Switch it off, and hold it tight in you palm with the LCD facing inward.
(4) Now, with you palm up, you should be able to see the model name 'CoolPix S6' under the lens and the flash.
(5) While holding the camera and aiming at the 'CoolPix S6', raise your other hand with the fist next to your ear.
(6) Match the aim as describe in(4) to the aim of your elbow 's protruded part and make pratice moves. Yes, you'are going to smack it
to your elbow.
(7) When you are ready, try first not to hit your elbow too hard once.
(8) Switch the camera on to check. If you have the 'Screen' now, congratulation! If not, repeat (4) to (8) but with a stronger impact
Force. You might have to try more times until your elbow could not take the sore.
I got mine fixed by performing the above steps just once, but I started at a medium impact force. Before this fix, I tried to whack it on both sides, the top and the bottom to my knee cap.
Why I chose knee cap and elbow? They hurt if you strike too hard. The target is to apply enough impact force to shake but not break the parts inside the camera.
Good Luck!!
Posted on Oct 21, 2007
thydzik
  • 86 Answers
SOURCE: Photos are being stored in the camera memory instead of the card
Once the memory card is inserted correctly the camera will store photos on the memory card, if it is removed, the camera will store photos on the internal memory.
user manual can be found here
http://support.nikontech.com/app/answers/detail/a_id/14564
Posted on Jul 21, 2009
  • 102366 Answers
SOURCE: How do i move my pics from my internal memory to
There should be a "Copy" entry in the Setup menu. You can use this to copy pictures between the internal memory and the SD card.
Posted on Dec 31, 2009
  • 102366 Answers
SOURCE: Can I download pictures from
You can connect the camera to the computer with the USB port. If there's no memory card in the camera, the computer should see the pictures in the internal memory.
Alternatively, you can get a new memory card (you're going to need one, right?) and copy the pictures from the internal memory to the card, then put the card into a card reader and transfer the pictures taht way.
Posted on Aug 15, 2011
I can't view images on Internal memory when SD card is inserted.
Put the card in, then select "Copy" from the playback menu. You will then be given the option of copying individual images or all of them. See the instructions beginning on page 99 of the manual: http://www.fujifilm.com/support/digital_cameras/manuals/pdf/index/s/finepix_s5700_s700_s5800_s800_manual_01.pdf
Jul 11, 2013 | Cameras
Nikon coolpix s4 camera: want to download internal memory pics onto my camera card and need to find "copy" in playback menu but can't find playback menu. Can you help?
Nov 03, 2012 | Nikon Coolpix S4 Digital Camera
How can i get photos from my Internal memory to my S.D. card? can't see an option on the menu and can't view photos from the internal memory whilst there's the memory card in it.
Put the card in the camera. Press the Playback button (right-pointing triangle). Yes, you won't see any pictures from the internal memory with the card in. Press MENU/OK to bring up the playback menu. Use cursor-up/down to highlight "Copy" and press cursor-right. Press cursor-up/down to select "INTERNAL MEMORY TO CARD" and press cursor-right. Select the desired option and press MENU/OK.
Full details are in the "Copy" subsection of "The Playback Menu" section of the manual (page 70 in my copy). If you need a manual, you can download one at
http://www.fujifilm.com/support/digital_cameras/manuals/pdf/index/a/finepix_av100_manual_01.pdf
Sep 13, 2011 | FUJIFILM FinePix AV100 Digital Camera
Can I put pics from my internal memory onto a memory card? Or how do I download to the computer from the internal memory?
You can copy pictures from the internal memory to the memory card by using the Copy command in the Playback menu. Press the MENU button in playback mode. Use cursor-up/down to select "Copy image/sound" and press cursor-right. Select the camera-icon-right-arrow-"SD" and press the OK button.
Full details are in the "Copying Files" section of the manual (page 105 in my copy). If you need a manual, you can download one from the manufacturer's web site at
http://www.pentaximaging.com/files/manual/OptioS40%20Web.pdf
Jul 22, 2011 | Pentax Optio S40 Digital Camera
How to delete all pics from dmc-lz3
If the pictures are on a memory card, format the card. This should be done every time you finish downloading your pictures to a computer. FixYa is full of people asking how to salvage pictures from a card that hadn't been formatted recently.
If the pictures are in the camera's internal memory, format it.
Either way, while in playback mode press MENU/SET to display the menu, then use cursor-up/down to select [FORMAT]. Full instructions are in the "[FORMAT]" section of the manual (page 78 in my copy). If you need a copy of the manual, you can download one from the manufacturer's web site at
http://service.us.panasonic.com/OPERMANPDF/DMCLZ5-MULTI.PDF
Jul 12, 2011 | Panasonic Lumix DMC-LZ3 Digital Camera
I have two problems: 1) how do i transfer pictures from internal memory to memory card? this is from a nikon coolpix s200 camera. it was just given to me without the usb cable and the driver. 2) can i...
1) There's a "Copy" entry in the playback menu that will let you copy pictures between the internal memory and the memory card. Display the playback menu by pressing Playback (the right-pointing triangle) and then MENU. In my copy of the manual, it's on page 94.
2) Consider NOT using a driver at all. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Nikon Transfer or any other photo cataloging program.
You can download the current versions of all (free) Nikon software from
http://support.nikontech.com/app/answers/detail/a_id/61
May 04, 2011 | Nikon Coolpix S210 Digital Camera
How do i get pictures off internal memory onto a computer or sd card
Hi, I have the similar s8000fd and I transfer pics from internal memory by taking out the sd card then connect to a spare usb socket on computer, then switch camera on. To transfer pics from internal memory to sd card - leave sd card in, switch on camera (playback mode), press menu, select copy, select 'internal memory to sd card', 'select frame' or 'all frames'. It should say 'copy ok?' Press OK.
Jul 10, 2010 | Fuji FinePix S8100fd Digital Camera
I can't access current photos from memory card, only old photos show up stored in built in memory. Also can not access "copy" from the menu, and nothing will download to my computer. All this worked fine...
"copy" is accessed from the playback menu. If that isn't available, decide if the pics stored in the internal memory are important. If not, format the camera with no memory card inserted to erase the internal memory. If you need those pics, then download them to your computer first...then format. Next, go into the menu and find "reset"..follow the on-screen instructions. Then, purchase an inexpensive card reader and download the pics from your memory card to your computer.(and promise yourself to use the card reader from now on...and remember that after downloading, use the "safely remove hardware" icon in the bottom right of your computer screen...don't just yank out the reader!). Finally, format the card in your camera and promise yourself never to use the internal memory again.
Jan 09, 2010 | Panasonic Lumix DMC-FS3 Digital Camera
Pictures stored in internal memory
The other answer doesn't work. I tried it. Okay, this is straight from the manual AND I tried it and it worked:
Press Play/playback to view pics.
Press Menu. Under playback menu, scroll down to COPY. Hit OK. Press OK for or scroll to & then hit OK for "Internal Memory -> Card" and press OK. Press Frame or All Frames. Press OK. Done! :)
God Bless. John 3:16
Jan 04, 2010 | Fuji FinePix A805 Digital Camera
My camera says that the disk is full. There are no pictures on the memory card. The camera will let me take one picture and then I get the disk full message. Is there an internal memory? If so, how can...
if there is a internal memory-which there proably is-remove card and hit playback and see if there are pics-if so either download or see if you can copy onto mem card inside camera through a copy function in playback menu-simply hit delete all or find format in menu and that wil clear internal
Sep 04, 2008 | Cameras
Nikon Coolpix S4 Digital Camera Logo
77 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
