Question about PC Chips G320 Notebook
Dvd-rw drive in a esc green 320 notebook, doesnt work .
Just added a new drive a dvdrw sony. drive can open when pressed a orange light comes on. not listed in device manager nor can add drive
  • nickste5 Jan 05, 2009
    its a sony dw-d56a-vn made on nov 04 laptop drive. worked in a vaio a series have tested it before in that notebook. installed it in a ecs notebook g320 model. would not be reconised by bios nore windows it self. cleared bios an restarted laptop windows reconised and installed drivers for drive. restarted laptop again and when it came on it wouldn't dected it. ive tried the delete the upper and lower fields in regedit but to no avail. conectors on both the laptop and drive are but still it doesnt work, yet there is power.
    any help appriciated,
    nick
  • Matthew Shockey
    Matthew Shockey May 11, 2010
    Does the device manager list an unknown device? If it does this is most likely your DVD-RW drive.
    If the above is true you will need to install new drivers for the device. If you would like to provide the model number for your DVD-RW drive I would be happy to try and find drivers for you.
Sony AD-7260S does not write or read Dual Layer DVDs
i think your drive Lens is weak that reason your disk is not read or write
Sep 08, 2011 | Sony Optiarc AD-7260S - DVDRW (R DL) /...
Driver Sony Optiarc AD 7260 ATA
This post is not a question. There is nothing to answer.
May 18, 2011 | Sony Optiarc AD-7260S - DVDRW (R DL) /...
Bought a Sony optiarc AD-7261S, but have an IDE connection, so got a ADP-06 bridge board to connect the drive using my IDE cable. The Sony is the 2nd cd/dvd drive on this computer, and after plugging it...
you might have to physically unplug the leads for this cd/dvd drive restart your computer then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Apr 30, 2011 | Sony NEC Optiarc Sony Optiarc...
I installed the new cd/dvd driver, but the compter won't install it.
If this is the only drive on your PC you have to make sure that you have set up the jumper to master. the jumper is located in the back of the drive. you must also install the driver for the drive to work properly.
Feb 28, 2011 | Sony Optiarc AD-7260S - DVDRW (R DL) /...
I have Sony AD 7240S DVD RW drive on my computer. It was working fine, reading and writing medias, But all of a sudden from the last week my computer not detecting my RW as a burning capable drive, saye...
try uninstalling your burning software and drivers roll back the driver on the drive disable your antivirus and fire wall after disconnecting from the internet an run a fresh install of the drives drivers and software. if asked to keep present driver or replace choose replace present driver. this should fix you up.
Nov 06, 2010 | Sony Optiarc AD-7240S 24x DVDRW DL SATA...
Hi, My Optiarc DVD RW AD 7530B doesnt read or play DVDS or CDs. it has power but when you click on E drive, an error comes up, that there is no disc
hey gues... we have some problem about my dvd/cd rewritable Drives model AD-7530B . it's my note book HP 520 can detect disk drive , but can not work anything . could you help me and give me information . how i can solution this problem ?... thank's
Jan 26, 2010 | Sony NEC Optiarc AD-7530B 8x DVD?±RW DL...
Laptop Optiarc DVD RW AD 7530 B is not reading CD or DVD media. 1.DVD icon displayed in My Computer. 2.When I insert DVD or Cd in the drive,Green light flashes and tries to read the nedia and goes off...
2.When I insert DVD or Cd in the drive,Green light flashes and tries to read the nedia and goes off within few seconds.
3.DVD drive in My Computer when clicked shows empty folder
4.Uninstalled DVD drivers in Device Manager and let windows find it on reboot
5.Issue still persists.
6.Right now external DVD RW works perfect.
Please help
Oct 29, 2009 | Sony NEC Optiarc AD-7530B 8x DVD?±RW DL...
Disc tray doesn't open
Unplug and plug in the powercable then try again. Be sure that the cable goes in the powerslot as far as it needs.
Good luck to you
Dec 12, 2008 | Lite On LH-20A1H DVD RW Dual Layer Burner
Drive won't open
u can see a pin hole on the drive just above the open button or the green light...press the button once n poke the hole with a pin ,,,,it ll hit a soft end...continue pressing it with some force....the tray will open...
Jan 02, 2008 | LG Super-Multi GSA-4163B 16x8x16x DVD+R/RW...
PC Chips G320 Notebook Logo
362 people viewed this question
Top PC Chips Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you a PC Chips Computer and Internet Expert? Answer questions, earn points and help others
