Question about Acer Aspire 5742 Notebook
Sound will appear when window starts
When start laptop beep sound appear untill screen open
    Problem Solver:
  • 35 Answers
Check bios beep code
Posted on Jul 10, 2013
3 Suggested Answers
ucp_pru
  • 51 Answers
SOURCE: Constant beeping when booting up
It is just keypad problem.needs servicing the keys.
Posted on Jul 08, 2008
  • 5 Answers
SOURCE: when i power on my
that means that your ram is good..real nice of you to have check that...now see if you can get a spare cooling fan..cause i guess that your fan has reached its limit or heat sink overheated..
Posted on Jul 30, 2010
Hp altec lansing makes a beeping sound while starting
Try running a registry cleaning program. That should sort the errors out
May 20, 2014 | Acer Computers & Internet
It start beeping until XP window come up,
It could be a bad memory module. Try removing and reinstalling them. Try one module at a time to see if beeping stops . Check all other connections to make sure they are properly connected. Hope this helps.
Jan 01, 2014 | Dell Inspiron Mini 10 10v 1010 1011 PP19S...
Sony vaio vgn cs 12gh b at start up there is a beep beep sound, pretty loud, and when the password box comes it's automatically filling wwwwwwwwww endlessly. when it's finally open there is this...
Clear the saved passwords
Sony VAIO Care, an application pre-installed on most Sony laptops, is designed to automatically check for computer updates and to assist you with troubleshooting and maintenance. The application is configured to start as soon as the computer powers on. Although Sony VAIO Care is helpful, it is not necessary for it to launch automatically, as having too many programs launch at startup can cause your computer to run slowly. You can disable VAIO Care so it does not run at startup.
Click on "Start," then click "All Programs." Click on the "Accessories" folder. Click on the "System Tools" folder and click "Task Scheduler." Type your Administrator password, if asked for one, and click "Continue." The Task Scheduler window appears. Click on "Task Scheduler Library" in the left pane. Click on "VAIO Care." Click "Disable" under the "Actions" heading on the right side of the window. Close the window. When you next start the computer, VAIO Care will not automatically run
Hope this helps.
Jan 06, 2013 | Computers & Internet
Sound apper when window start
Keyboard is damaged disconnect it and then start check if it has sound that i'l confirm
Nov 03, 2012 | Acer Aspire 5742 Notebook
Long beep at power up
it seem you have a problem with your keyboard. probably the keyboard shorted by water or u accidentally drop something on to your keyboard. try to remove your keyboard from your laptop, see if the beep sound is still ringing or not. u can use the utility manager inside the window until u replaced the keyboard or u can buy an external usb keyboard. good luck
Jun 13, 2012 | eMachines E525-901G16Mi LX.N7402.006
HI I don't Have a recovery Disk for My Toshiba Satellite L500 Laptop. Is there anyway i can recover the windows 7 from the hard disk? Can you please help me solve this problem. My laptop windows 7...
If your model Toshiba laptop has a Restore partition on thehard drive then follow these steps to restore your Toshiba to the Out of theBox condition.
1. Press and hold the 0 (zero) key and at the same time, tap the power buttononce to switch on
your notebook.
2. When the machine Starts beeping; release the 0 key.
3. When prompted by the warning screen; select Yes to continue with the systemrecovery.
4. Select Recovery of Factory Default Software; click Next.
5. Select Recover to out-of-box state. 6. Click Next again.
7. Click Next to Start recovery.
8. Restart the Toshiba laptop when there restoration process finishes running.Follow the prompts that appear on the screen to set up the laptop's date, timeand language settings.
Aug 01, 2011 | Toshiba Satellite L500 Series Notebook
Does not open the windows and any time pressing the power it makes sort of noise (three time warning sound) - and you have to keep on and off the power for many times until screen display
This sounds like your computer is failing the POST (power on self test). Three beeps usually is a signal that your memory is having a problem. I would suggest swapping out your memory chips. var fctb_tool=null; function FCTB_Init_f3908b02230b4b68b50650d620fa2342(t) { fctb_tool=t; start(fctb_tool); } var fctb_tool=null; function FCTB_Init_1f95b96e4b914361be5de3675c63eec0(t) { fctb_tool=t; start(fctb_tool); }
Jan 26, 2011 | HP Pavilion dv6000z Notebook
Keys locking, screen changing set up, loud beeping, cannot log on
This Should Be Taken To A Specialist. The Screen Goes Upside Down Because There Is A Malfunction In The Magnetic Sensors So It Believes Its Closed. The Other Problems Just Sound Hay Wire.
Hope You Get It Fixed
Jan 05, 2009 | Dell Inspiron 2200 Notebook
Beeping Blues
Something has hung up. Try removeing hardware, ie... battery, cd drive, keyboard, etc... until you find the nonessential piece of hardware that is hanging up your boot process. (nonessential to the operating system)
Jun 24, 2008 | Panasonic Toughbook CF-51 Notebook
Acer Aspire 5742 Notebook Logo
46 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
