Question about Baldwin 5445.003.PASS Classic Lever, Lifetime Polished Brass
Baldwin rosette removal - Baldwin 5445.003.PASS Classic Lever, Lifetime Polished Brass
I was wondering what the age of our baldwin piano serial #399572 is. thank you for any help
You did not state model, Check the attached links,for your model.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.pianoworld.com/baldwin.htm
Free Piano Age Research
Baldwin Piano Age
Baldwin Pianos Company History Serial Number Search
Mar 10, 2016 | Music
What is my Baldwin spinet serial #1003855 worth?
Baldwins from the 70s and 80s are a bit notorious for various mechanical (and tuning) problems. Most of them pianos were good, but they might have a few parts that were bad, so be aware that you'll need to tune it to sell it, and you may need to do some repair work.
Most prices are listed by model number, not serial number, so you'll need to figure out which model you have. I found a pricing guide, but I don't know how recent it is. There is contact information on the page that might help, though. Baldwin Piano Prices
Jul 19, 2014 | Scripophily.com D. H. Baldwin Company...
Unable to remove old door handle for Baldwin 5255 lever
They are usally pressure fitted, however paint on the door it self will make it stick.
Take an sharp utility knife and score the paint as tight to the
escutcheon as you can, then it should pry off.
Feb 01, 2014 | Baldwin Wave Left-Handed Entry Lever...
Baldwin door hardware not working. Thumb-latch broken or disconnected.
You look like you have a Baldwin Manchester. Take a look at
http://s7d1.scene7.com/is/content/Baldwin/egentrall-images-emerpdf
to inspect and realign your latch assembly. If you still have problems call their Consumer Help Line 1-800-566-1986
Hope this helps
Feb 28, 2013 | Home
I am replacing old Schlage exterior handleset with a new Schlage exterior handleset. How do I remove circle on interior of door?
Some schlage rosettes screw off. They have a special wrench. You might go to a lock shop, and ask the locksmith how to take it off. Other type knobs you pop off with a chisel or knife.
Sep 10, 2011 | Garden
How do you replace a keyed door lock set> There are no screws visisble to disasemble
Don't know why this is postedin the Chainsaw forum but here goes. Look for a small hole or slot in the hardware of the door lock, sometimes on the underside. This is usually where a tab of the lock hardware inserts into a slot of the decorative cover. Gently pry the cover off at this point and you should expose the inner lock, with two longer threaded bolts going through the door to the lock mechanism on the other side. Sometimes this can also be done with a very small allen screw that holds the lock cover to the lock mechanism.
Aug 31, 2011 | Garden
How do i remove a towel bar that does not have a set screw on the flange cover?
I think you grab hold of the rosette closest to the wall and spin it off, it should expose the set screw. If that isn't it, one of those things will turn. Try a few different spots. hope this helps.
Mar 20, 2011 | Moen 24 In. Towel Bar...
JVC AV-56WP74 convergence board
This link works for me; http://www.vancebaldwin.com/ hope this helps :) PS your search/security settings must need tweaking if you didn't get that link from google.
Jul 26, 2007 | JVC AV-56WP74 56" Rear Projection...
Baldwin 5445.003.PASS Classic Lever, Lifetime Polished Brass Logo
177 people viewed this question
Top Baldwin Electrical Supplies Experts
ken skalski
Gene Haynes
Are you a Baldwin Electrical Supply Expert? Answer questions, earn points and help others
