I have got a beko wma765s washing machine locked on child lock didnt get manual please how do i take it off
  • 15,935 Answers
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 14, 2010
I have beko 91442 lx and can get it to start. All lights etc on. Thought it might be child lock but can seem to get it on or off. What can I do please
i think it refers to elec-card
1- first unplug the machine for about 10 min
2- plug the machine and start short program
if led are on please specifies which led are lighting !!
thank you
Nov 21, 2014 | Beko Wm & Wma Models Washing Machine Motor...
Beko washing machine
Try letting the program run through
and see if that clears the problem sometime it will if not holding the power button for a wile should re set it
Jan 23, 2014 | Washing Machines
Beko washing machine WME8227B. Switch on power, set programme ,press start button, hear the door lock (noticed that the padlock symbol isn't on as nomal) no water flows , checked manual eg child lock, time...
Probably a fault with the lock or latch; should be no problem for an engineer to fix. Just try giving the door a firm push to close it, to see if the padlock light comes on.
Jan 10, 2018 | Beko Washing Machines
Why now it didnt work and it said CL on the screen???
Child Lock activated. Look for a picture on the Facial Panel with a small child's face (usually accompanied with a lock) follow the arrows to 2 buttons, press and hold these buttons for 3 - 7 seconds. Child Lock will then deactivate.
Hope this helps
* If you found this solution helpful, please vote positively.
Feb 17, 2011 | LG WM3677HW 3.7 cu.ft. Front Load Washer...
How do you reset a beko washing machine??
It's actually pretty easy. Try this: press and hold the start button in for 5 seconds.drain pump will start up.let it complete its routine (takes 2 mins or so).now the machine has reset.select program as normal and retry
Hope this helps
Dec 26, 2010 | Washing Machines
My Beko washing machine is displaying C on on the display and will not start.Any Ideas please.
"C on" means that the child lock is on; press the two buttons that are linked to a lock symbol at the same time for 3 sec. ;)
Sep 01, 2010 | Washing Machines
Beko washing machine wm8127w what is error code 'C on' many thanks
The child lock is on
There should be a lock icon with 2 arrows pointing at a button each
Press both these buttons at the same time and the display should read C:OFF
Jan 10, 2010 | Washing Machines
Beko WMA765S fills, stops, then drains and stops
i would think about replaceing the timer
Sep 09, 2009 | Washing Machines
Need to disable child lock
If you didnt lock the unit yourself - the ECU is failed and needs replacement.
May 27, 2009 | Washing Machines
Beko WMA 510 stuck on cycle
Hi if your beko WMA 510 washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Also check all waste pipes are clear and inspect the pump I have included this video below.
At our website I am doing self diagnostic videos on these beko's as we speak so all tutorials will be in this link below
How to replace Beko Washing Machine Motor Carbon Brushes
you might find this test video helpful but only do it if you have checked the motor
Sep 05, 2008 | Indesit W 123 Front Load Washer
Washing Machines Logo
203 people viewed this question
Top Washing Machines Experts
