Question about Watches
I want to remove extra links. Should the ones with arrows come out?
    Novelist:
    Champion:
  • 227 Answers
Yes
Posted on Nov 03, 2012
2 Suggested Answers
Mastercare
SOURCE: removing links
It?s very tough to remove the links, I would recommend taking it to a dealer If you have to, you will either need a fine punch (or very masonry nail), a medium hammer, and a piece of wood a couple of inches square, a rag or wash cloth. A sturdy flat blade watch makers screwdriver. The ones from a dollar store may not work, and a pair of pliers. There are two types of links, both of them are a pig to remove, expect lost fingers, lots of swearing and possible scratched strap. Version one, The one I think you have, Place the watch strap flat on something hard, put a cloth under it so it will not mark, the outside of the strap will be on the cloth and you will see the arrow, there is a rectangle with a nipple recessed inside. Place the blade of the screwdriver between the nipple and the edge of the rectangle, press down and wiggle between the nipple and the edge and twist, there will be a locking pin which comes out of the side link, in the direction of the arrow. Wiggle away until you can free the locking pin. It?s simpler to put them back. Version two, Place the rag folded a couple of times on the block of wood Place the strap on the rag so it?s on it?s side, hang the watch over the edge of the block so the strap is flat against the block and there is nothing touching the watch (hanging in air) Look at the edge of the strap, see the small pin, in the fold of the metal, punch it out (down into the cloth) enough to then grab it with the pliers, I actually drilled a small hole in the block of wood so the pin would be pushed into that rather than against the wood, but don?t drill holes in your dining table! I would still recommend taking it to a dealer,
Posted on Apr 05, 2007
I have a benrus watch that has a bracelet that does not have the usual pins with arrows to remove links. they links have arrows but no pins . instead the ends look like staples with only the flat end...
I had a watch with a strap that sounds like the one you describe.
The "pins" were indeed staple shaped and were removed by gripping them with a long nosed pair of pliers and pulling them out one one side and then the other.
Take care when replacing them as they might bend.
Feb 11, 2011 | Watches
How do i install additional links to this model watch? the company mailed me 2 additional links but no installation instructions Fossil model ES1967
  • Turn your watch on its side so the links are vertical. On the inside of the links closest to the clasp you can see arrows, which point in the direction that the pins must be pushed out. Only about four links on either side of the clasp have arrows, because these are the only links with removable pins. On the edge of the links on the opposite end from where the arrow is pointing you will see a small circle where the pin is inserted.
  • Place the tip of your pointed tool on the small circle mentioned in Step 1. Push downward on the pin in the direction the arrow is pointing. Once the pin starts to come out of the link, use your fingertips or a pair of tweezers to completely remove the pin from the link. You may need to use force, but be careful not to scratch your watchband. Use a pointed tool from a jeweler's or hobby kit or watch pin removal tool.
  • Slide the links apart where you removed the pin so there is a gap in the watchband. Slide your new link into the gap and fit the neighboring links into the new link so it matches the rest of the watchband.
  • Insert the new pin into the watchband. You will need to insert two pins, the pin you removed in Step 2 and your new pin, into the two empty pin holes. You need to insert the pin small end first so the larger pin head does not pass through the link. Insert the pin against the direction of the arrow rather than in the direction the arrow is pointing like you did in Step 2. Use your pointed tool and your fingertips to push the pins completely in the links until the pin head is flush with the edge of the link.
  • Aug 18, 2010 | Watches
    Remove links
  • Wrap the watch band around your wrist to determine how many links need to be removed for the watch to fit properly.
  • 2 Place the watch face-down on a flat surface.
  • 3 Look on the back of the watch band. You will find an arrow that indicates which direction you should push the pins to remove the links.
  • Find the point at which the extra links need to be removed for your watch to fit your wrist. Using a 1 mm flathead screwdriver (or the edge of one side of a pair of tweezers), push the pins in the direction indicated by the arrows.
  • Finish removing the pins with your pliers.
  • Keep the extra links in case you ever need extra room on your watch band.
  • For further assistance, check out the link:
    http://www.pulsarwatches.com/home2.asp#FAQ
    Aug 17, 2010 | Pulsar Men's Stainless Steel Bracelet...
    Can't figure out how to revove links to make it the proper size
    locate the arrows on the inside of the watch, use a push pin and small hammer, and lightly tap the push pin into the groove while bracing it on both sides so the pin has room to come out. Make sure the direction you are hammering is the same direction the arrow points. The pins inside are tapered, and will only come out in the one direction. Do this on two of the pins to remove one link, or leave one pin between the two being removed to remove two links. Put the watch back together by reversing the first step. Hope that helps!
    Dec 23, 2009 | TechnoMarine Square Ceramique SQCB02C...
    Adjusting a casio s940db watchband
  • On the inside of the band, locate the links with the arrow etched on them. The arrows mark the removable links.Lay the watch on its side on a flat surface with the arrows pointing downward. Be sure to leave about 1/2 cm of space between the bottom of each removable link and the flat surface. Using a 1/32" flat head jeweller's screw driver (or metric size 1.0), insert the tip of the screw driver into one side of the removable links' pin holes. You will find that the pins have an end that looks like a screw head. This is misleading - press down very firmly on the other end. Press downward firmly to make the pin pop out the other side. Be careful not to lose it.Remove the pin on the other side of the arrow-marked link.Repeat as necessary to remove half the needed links. You will remove the other half from the other side of the band to maintain equal band length.Flip the watch over so the arrows are pointing upward.Align the holes in the remaining links. Insert the rounded edge of one of the pins into the open link hole. The pin will go in without trouble until the top.Holding the pin in place, carefully flip the watch over again and firmly push the pin fully into placing using the flat surface. The pin will snap into place.Repeat for the other half of the band as necessary.
  • Sep 26, 2009 | Casio G-Shock GW300CA-1V Wrist Watch
    Remove links
    It really depends on how your watch-strap is designed. If it is a rigid one with arrows on some of the links, you may find the answer here:
    remove links
    There are other models with links held together with small split-pins. You have to push them out in the direction of the arrows as well. This works fine using a sewing needle with a broken tip.
    Aug 02, 2008 | Timex 27191 Wristwatch
    Trying to shorten the band on a fossil watch. removable links have arrows which point outward on both sides of the link.
    You need a small, (smaller than the pin hole) punch to force the pins out of the band. Since the arrows point in both directions you can push from either direction. Push enough of the pin out to be able to grasp it with a pair of small pliers and remove it. Do that on both sides of the link, replace the extra with a small hammer and you're done.
    Sarvadrk
    Jun 18, 2008 | Fossil Watches
    Remove the extra links in a luminox 3204 watch band
    It was nothing more than split pins holding the links together. I pushed them out removed the links and pushed them back in.
    May 12, 2008 | Luminox Navy Seal Dive 3204 Wrist Watch
    I just bought a fossil watch ch2331 and need to remove a link. how do i do it?
    Some of the links are removable on this watch & some are not. Look inside the band you should see some tiny arrows on the removeable links. You need to push the pin through in the direction of the arrows & remove the link. Then to put the band back together you need push the pin through in the opposite direction of the arrow. Make sure the widest part to the pin goes in last or it won't fit.
    Mar 09, 2008 | Fossil CH2331 Wrist Watch
    Watches Logo
    Top Watches Experts
    Ansel Alberto
    Ansel Alberto
    Are you a Watch Expert? Answer questions, earn points and help others
