Question about BLUE MAX Garden
Brand new Blue Max 20" chain saw wont start, has fresh gas/oil mixed @ 25:1
Bought 2 of these chain saws, both won't start. On switch is on, gas & oil are full, no firing of the engine, tried with both choke out and in & followed the starting instructions in the manual. Any help to get these going?
I also have a BlueMax 45cc chainsaw that I could not start right out of the box. I got lucky a couple of times after many (20 or 30 pulls) but normally I just gave up. Many others online seem to be having this problem with this chainsaw.
It turns out the solution for me was that the starting instructions in the manual are not really complete, there is another step that aids in starting: it needs some throttle. The chainsaw does not like to start with power at idle. After setting the switch to on and setting the choke, as the manual says, before attempting to start, squeeze the throttle while pressing the side button to lock it. For me, this allowed it to FINALLY start with only a few pulls. I learned this when I ran across this video:
How to start BlueMax Chainsaw 45CC
Hope this helps anyone else who runs into this.
Posted on Jun 15, 2014
    Master:
  • 492 Answers
If its new, check the carb float has gas in it. Sometimes the float needle will get stuck and not allow gas into the float.
Posted on Oct 18, 2013
  • 12 Answers
SOURCE: Will not start - brand new
Make sure carb is receiving gas. With saw cold prime 6x's pull out choke no throttle pull cord should turn over once then turn off choke and pull cord no throttle. This should work.
Posted on Mar 15, 2009
  • 76 Answers
SOURCE: 39cc McCulloch chain saw
The issue sounds just like a carburetor problem. I had a saw that did the same exact thing, and found that I hadn't been adjusting the carburetor properly for years. I managed to find the instructions on-line, and then it ran like a dream, just every time I store it, I have to go back through the motions again.
Let me know if you need adjustment guidance and I will see if I can dig up anything.
Posted on Oct 04, 2008
Loringh
  • 185 Answers
SOURCE: Chain saw starts with starting fluid only but will not run.
Hi lwhssh:
Suggest you drain the fresh gas/oil and add a fresh batch but first add a gas stabilizer to your batch of gas/oil in the storage container. You will probably still need to use starting fluid for a few times When 2 cycle engines sit for a long period of time, the gas/oil mixture undergoes a change and tends to leave a residue on the delicate parts of the carb. The gas stabilizer will help that.
I always do the following for 2 cycle engines when I put them up for the winter. Empty the gas container on the device and then start it to use up any gas left in the fuel lines and carb. this keeps any residue from forming.
Hope this helps Good luck Loringh PS please leave a rating if appropriate. Thanks
Posted on Nov 29, 2008
  • 211 Answers
SOURCE: chain saw emitted sparks and now does not start.
Hi
When the engine get warm and die(I suppose)check the spark at the sparkplug.You can let the saw run until it ran out of gas and you will not distroy the engine.Change the sparkplug.
best regards savumihai71
Posted on Dec 19, 2008
steve_lima
  • 181 Answers
SOURCE: poulan chain saw P3314
pull the muffler off and check if the piston is scored,if it is you need to replace the piston and cylinder.
Posted on Jan 07, 2009
Which oil do i use in a ryobi C4620 chainsaw?
Do NOT use lightweight motor oil for that bar! Use only bar/chain oil for it - nearly any brand will do just fine, but it needs to be bar/chain oil. Bar/chain oil is specially formulated to stay on the bar & chain in use - motor oil will fling away & your bar won't get the lubrication it needs.
For fuel mixing, use nearly any brand of 2-cycle oil, which is specially formulated to provide lubrication even when it's mixed into your fuel. Use about 3.2 ounces of 2-cycle oil per every gallon of gasoline - a little more won't hurt (it'll make the saw smoke a little), but never use less. Always shake the gas can just before you refill your saw's tank - shaking helps make sure the oil & gas are well-mixed.
Mar 13, 2013 | Garden
Husqvarna 372xp won't start... Mysterious
I recently bought a brand new 372XP and spent the first day trying to start it as per the instruction manual with no success, never even fired once. Removed the plug to find plenty of fuel and that the plug has a good spark. Left it until the next day mainly to allow my arm to recover (& scour the internet for clues). I found a forum that said not to use the decompressor and sure enough without the use of the decompressor button it fired first go with the choke on then I reset the choke & it ran properly on the second pull. The decompressor button can be reset with fine nosed pliers or removal of the top cover by undoing three screws. Good luck it's a great saw once you know how to start it.
Apr 01, 2012 | Husqvarna Chain Saw Models 371, 372xp
The chain saw is brand new. It starts OK but after I make one cut it stalls (Every time).
Do you have the proper gas-oil mix? It should be 40:1, which is 3.2 oz of oil/synthetic oil to 1 gallon of fresh gasoline. Make sure you push in the choke after starting it. Also make sure the chain brake is off (chain should move freely by hand when the saw is TURNED OFF.) If gas mix is right, choke is turned off after starting and brake is off, take it back to the dealer/store.
Aug 29, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Chain saw won't start
Things to check,drain and re fill with fresh fuel/oil mix, replace the fuel filter in the fuel tank, remove the spark plug, rest on top of the cylinder and check for a spark, if this is all ok remove the muffler and check the condition of the piston through the exhaust port, any signs of damage and the saw will have to come apart for further investigation.
May 30, 2011 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
INQUIRY: I HAVE A MCCULLUCH PROMAC 555.....20'' SAW.....NEED TO KNOW THE OIL <> GAS MIX RATIO....need info A.S.A.P....THANX....manobogies@q.com
Run it on a 25-1 fuel oil mix with good quaility two stroke oil, use a non fling chain oil in the chain oil tank to lubricate the cutting chain
Apr 11, 2011 | Garden
Fuel mixture ratio
Oil Mix Ratio:
Starting in the early to mid 90s Dolmar, Echo, efco, Homelite, Husqvarna, Jonsered, Makita, Oleo-Mac, Red Max, Ryobi, Shindaiwa, Solo, Spear & Jackson, Stihl and Tanaka all started recommending 50:1
  • 1 gallon of premium fuel to 2.6 ounces of quality 2-cycle oil or
  • 4 liters of premium fuel to 80 milliliters of quality 2-cycle oil.
McCulloch, Poulan & Wen recommend 40:1
  • 1 gallon of premium fuel to 3.2 ounces of quality 2-cycle oil or
  • 4 liters of premium fuel to 100 milliliters of quality 2-cycle oil.
Chinese chainsaws recommend 25:1.
Jan 07, 2011 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
PRO 4000 I bought one used,I don't know the fuel oil mixture.your help would be appreciated
50:1 should work nicely. Be sure to use fresh fuel and a modern synthetic saw oil for the mix. Place the mix in it's own can and shake thoroughly just before each filling. Don't make up more than a gallon at a time unless the saw is used to make your living. Hope this helps!
Oct 15, 2010 | Poulan Pro Chain Saw 46cc 20"
What is gas oil ratio for a 16 inch poulan chain saw
Oil Mix Ratio:
The following ratios have been recommended for the last 10-15 years.
Dolmar, Echo, Efco, Homelite, Husqvarna, Jonsered, Makita, Oleo-Mac, Red Max, Ryobi, Shindaiwa, Solo, Spear & Jackson, Stihl & Tanaka; all recommend 50:1.
1 gallon of premium fuel to 2.6 ounces of quality 2-cycle oil.
McCulloch, Poulan & Wen; recommend 40:1.
1 gallon of premium fuel to 3.2 ounces of quality 2-cycle oil.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Aug 13, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
What is the oil/gas mixture for a 20" chain saw?
Oil Mix Ratio:
Lou
Jun 28, 2010 | Poulan Pro Chain Saw 46cc 20"
Hot chain saw wont start
When it won't start, remove the spark plug, lay the base on engine metal with the wire on, and pull through. The spark should be blue and snappy. If nothing, try a fresh plug. If still nothing, the ignition module may be failing with heat. Try blowing out sawdust from the engine and case with compressed air to improve cooling. Does the engine 4-stroke when not cutting, but immediately 2-strokes when cutting? Check the air cleaner and muffler for plugging. Make sure the carburetor fasteners are tight. Hope some of this helps!
May 01, 2010 | Garden
Garden Logo
1,851 people viewed this question
Top BLUE MAX Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a BLUE MAX Garden Expert? Answer questions, earn points and help others
