Question about Maytag MSD2756G Side by Side Refrigerator
Refer not cooling , freezer kinda cold, adjustments do nothing
Compressor is running , but no cooling in Refer side
    Top Expert:
  • Maytag Master
  • 9,472 Answers
Do you see any ice buildup on the back wall of the freezer or behind it?
Posted on Nov 04, 2012
Krazytech
  • 725 Answers
SOURCE: Maytag MZD2766GES side-by-side Refrigerator warm
is it frozen up? do you have any air flow thru the air tunnel from the freeze to the fridge? Check your air flow with the door switch pushed in. also check to see if the damper door opens... 1) if it is iced up you have a defrost problem. most likely a defrost timer. Turn off or unplug untill all the ice has melted off the evaporator back of the freezer..plug back in and it will work fine untill the ice builds up again. if this work you do have a defrost problem.. if not let me know and we can go deeper...
Posted on Aug 18, 2007
heatman101
  • 43501 Answers
SOURCE: freezer is very cold, refrigerator not cooling on Maytag side-by-
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
s
Posted on Sep 30, 2010
  • 1151 Answers
SOURCE: compressor runs constantly, fridge cools, but not as cold as new
If unit is running constantly, and not nearly as cold as it used to be, most likely a freon leak. Possibly a partially frozen over evap too. If evap is mostly clear except for about 5% of it, most probably a freon leak. Changing controls will probably not fix anything. Need to look into this a little deeper.
Good Luck and hope this gets it done for you.
Posted on May 10, 2009
watugot
  • 290 Answers
SOURCE: Fan runs but no cool air on both freezer side and cold side
If you hear the compressor try to start then click off, you probably have a bad compressor or a bad relay. If it is less than 5 yrs old the compressor is still covered by warranty and will be replaced free of charge. The relay is only covered for a year. With it being a Maytag, I bet it is compressor. There have been a few models with control board problems that have caused this symptom, but that's not likely to be your problem.
Posted on Oct 06, 2007
  • 5 Answers
SOURCE: freezer cold fridge just cool.
For those who had the control board replaced or are experiencing thefrig side warming while the freezer side continues freezing; Theproblem may (still) be a faulty control board. I fixed the issue byreplacing a $1.00 capacitor on the board. I'm not a techy and it wasn'ttoo difficult to solder. More info on what to do here; DIY Chatroom
I use a pump pressure garden sprayer with hot water to defrost the coils. Gets the job done in 20 minutes and I don't have to worry about defrosting items in the freezer.
Posted on Aug 09, 2009
Freezer cool but not freezing; refer cool but not cold
When the compressor is running all the time and the freezer is not cold enough, it could be the hot side can't lose the heat, see if something is blocking the radiator on the back, but most likely you lost the cooling fluid through a leak in the cooling system. When the temperature is rising slowly through the days (or hours) while the agregate is running, that will be the problem. You won't be able to fill it up yourself. The system is filled and sealed.
Apr 16, 2015 | Refrigerators
Side by side quit working refer not cooling / freezer defrosting.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
May 24, 2011 | Kenmore Refrigerators
My refer and freezer just stopped getting cold. fan is running ,relay on compressor clicks on and off every few minutes
heatman101
May 06, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Freezer not cold 50 degrees and rising
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
34qgarhsg
May 23, 2010 | KitchenAid KSCS25FKSS Side by Side...
Freezer willnot longer get cold only cool air
Do you hear the compressor humming? If the compressor does not run then your freezer will not get cold.
Aug 30, 2009 | Kenmore 54263 Stainless Steel Side by Side...
FROST BUILD UP IN FREEZER AND REFER NOT COLD ENOUGH
hello.
  • Defrost the freezer
  • Clean the condensor coils
  • Check the door seals
  • Test the door switch
  • If you recently adjusted the temperature control, loaded the refrigerator or are in a humid location, it is not uncommon for a refrigerator to run for 24 hours or more before getting cool.
  • Mar 15, 2009 | Refrigerators
    Fridge not cooling down stays at 68 degrees
    you may be low on freon..thats one thing about fridges if you are low one side will still stay cold while the other side gets warm
    Jan 12, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
    Kitchenaid Superba compressor
    The compressor relay is located on the compressor under a cover. Before you go to the compressor I would check for other problems that you can see and hear. If the compressor is running there is nothing wrong with its relay.
    1. Check the condenser and make sure it is clear and free of dust.
    2. If the compressor is cool or cold check for a bad temperature control.
    3. Check the freezer compartment for frost on back wall.
    May 29, 2008 | KitchenAid Superba Architect KSCS25INSS...
    Kenmore Side by Side Refrigerator, freezer doesn't work, refrigerator works
    Unless specifically made for use in a garage most units won't work properly. The owners manual should say what the temp range for proper operation is (usually 55F is the low range). This is because the refrigerator section doesn't need to be "cooling" to maintain 37F if the temps on the outside are below 55F. These things are made to work in a 70F room and will not work properly if under 55F. Stupid thing thinks it's cold enough so it will never turn on, the refer section will stay cold/cool due to outside temps but since the compressor never runs the freezer will just be the same temp as the refer section (at best). Sorry, but in order for a freezer or refrigerator to work in an unheated space it must have the temp control device controling the freezer section NOT the fresh food section. In other words, that model will not work in a garage unless the temps are above 55F always.
    Feb 06, 2007 | Kenmore 50522 / 50524 Side by Side...
    Maytag MSD2756G Side by Side Refrigerator Logo
    490 people viewed this question
    Top Maytag Refrigerators Experts
    Bailey's...
    Bailey's...
    Shehu Pro
    Shehu Pro
    Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
