Question about Dryers
KENMORE 110.9728210072821 Dryer does not heat
Hasn't been used in 8 years and worked fine before that for 6 years, Hooked it up yesterday and the ignitor doesn't come on but is OK,I hear the gas valve click but doesn't come on.
Your advice did not help I'm sorry to say. I talked to a appliance Parts place over the phone live and it was easier to diagnose it over the phone instead of running back in forth to a computer being the dryer was in the basement and my computer was on the 2nd floor,that's why on your site I got disconnected twice cause they wanted a response right away and since I was downstairs and didn't answer after several attempts by your techs I got disconnected!!!!!!!!!! very rude Sorry but I wasn't Happy.
Posted on Jan 06, 2009
No heat
While your model number is not listed on the Service Manual at the link below, you will find information on how to check out the heater on page 8-6.
Good luck
http://www.servicematters.com/maytag_library/docs/16023110.pdf
Sep 29, 2009 | Maytag MDE16CS Electric Dryer
Dryer runs fine but no heat
change the fuse in back of the dryer
Jun 23, 2009 | Kenmore 73952 Gas Dryer
Older dryer just stopped heating. Air still blows
Sound like you need to replace the heating elament you will need to take your model number and make to repair shop for replacement parts or have a repair person come out and fix it for you . thanx for using fixya
Jun 16, 2009 | Kenmore 64742 Electric Dryer
Kenmore Dryer-Mod.#11066514694-won't spin or heat
This could be caused by an internal thermal overload switch. These usually have a limited life span in any appliance that uses heating elements. Try to locate the overload switch which usually looks like a small diode or resistor. You can determine if this is the cause by bridging the switch with a piece of wire, then trying the dryer once more.
Best wishes,
Graemevm
Jun 06, 2009 | Dryers
Kenmore Dryer 62802 Doesn't Heat
sounds like the heating element has gone south
if you open up the dryer you can check continuity across the element but make sure power is unplugged
Apr 13, 2009 | Kenmore 62802 Electric Dryer
Model 11060052991 kenmore elite dryer
For heat issue I had replaced the heat relay switch a year ago and that worked. For the start button holding issue I replaced the motor relay switch and the dryer is fine again.
Nov 25, 2007 | Kenmore 63942 Dryer
Used dryer 74602 not heating
If the lower front cover comes off remove the cover and vacuum around heating element and surroundings. A lot of time there is a lot of lint build up and the heating element will stay off for safety.
once this is done you should be fine.
Another place to check is the exaust hose. Make sure it is not blocked along with the vent that leads outside. If this is blocked it will cause the dryer to go into shut down mode.
Hope this helps.
Nov 25, 2007 | Kenmore 74602 Gas Dryer
Dryers Logo
Top Dryers Experts
