Question about Janome MyLock 644D
Stuck Needle Plate Setting Knob
Plastic red knob will not move to R position on my Janome My Lock 644D machine. Everything appears clean. Loosened plate but cannot figure out why mine does not move at all. What to do?
  • carellb
    carellb Nov 06, 2012
    Thanks everyone for giving your solutions. If I had read the manual more thoroughly I would have found the answer there. I was to use my left hand to manipulate 2 pieces which removed the barrier that did not allow the piece to move. Thank you for trying to help, it was appreciated.
  • Janome Master
  • 1,564 Answers
Spray it with Liquid Wrench (NOT WD40!!) and let it set for a day or so.
Posted on Nov 06, 2012
5 Suggested Answers
SOURCE: Janome Memory Craft 9500 Troubleshooting
The solution that I found last night was the thread tension. I have never touched the dial, only had it set on 'auto." When I started playing with it, I realized the top thread should be really easy to pull through the machine and it wasn't. I started turning the dial (to 3 or 4) and the thread slid through the machine perfectly. No more birds nest! I really thought it was bobbin initially because of the horrible sound it was making.
Posted on Jun 05, 2008
bargainbox
  • 1388 Answers
SOURCE: Janome Needle plate and needles hitting something underneath
The broken pins are called chaining pins and are tricky for the home user to replace without risking damage to the needle plate as they are difficult to remove and the tiny burr used to hold them firm can easily open up and no longer grip the pin.
There are only a couple of things under the needleplate that are likely to collide with the needles. 1. Lower looper - with the needles 2. Both Loopers colliding with each other - not with the needles 3. Needle guards attached to lower looper - with the needles 4. Fixed Needle guard - with the needles
If you remove the needleplate and VERY gently turn the handwheel you should be able to see and feel where the collision is occuring and have a better idea of the issue.
I would strongly advise that you do not try to operate the machine until you are sure that the colliding components are adjusted. Broken loopers are approx $65 AUD and guards, tho' only about $20 AUD require some finesse in adjustment. Chain Pins approx $6 AUD
My recommendation is to speak with your local Janome dealer for advice and an approximate price to repair, replace or adjust as the case may be.
Your country's Janome website is certain to have a Dealer Locator page to list the nearest to you.
This is one occasion where it is sensible to call on the people who do these things routinely rather than try to DIY and make a more expensive hash of it.
www.bargainbox.com.au
Posted on Nov 22, 2008
bargainbox
  • 1388 Answers
SOURCE: I am trying to locate a power cord for my Janome
Use this link to go to the Janome Global Site
Select your country then look for the Dealer Locator page to find your nearest stockist
If you are in Australia, we can send you one, just drop us a line.
Bargain Box
Posted on Apr 12, 2010
SOURCE: I have a Janome 6260. My machine sewed great, but
I've had the Lo come on my screen of my sewing machine also, but normally when I turned it off it corrected the jam up.
Lo- A button is pressed when the machine halts due to a overload
wait 15 seconds to recover
if thread jamming causes the overload, remove the tangled thread
check the bobbin area for lint & loose threads
also check to see if the bobbin is warped
check you needle to see if it's bent-roll on a flat surface to see if it rolls correctly
if it's blunt it makes a popping sound when going thru fabric
let me know if these suggestions help
Posted on Sep 23, 2010
My presser foot moves right to left and I cant get it to stay in one position. I am trying to straight stitch.
You have it set to zig-zag. Check your stitch width setting. Consult your owner's manual.
Aug 04, 2015 | Janome Sewing Machines
For rolled hemming how do I move the needle plate setting knob from S to R
If you dont have a manual then this page will allow to to download it for free. Pretty straightforward and easy to read
http://janome.com/siteassets/support/manuals/sergers/inst-book-634d.pdf
Feb 07, 2015 | Janome MyLock 634D Mechanical Sewing...
The machine is stuck in zigzag cannon move control knobs
If the buttonhole dial has been rotated so that its indicator mark is not at zero (vertical aligned with the plate indicator mark), the stitch width dial will not function. Turn the buttonhole dial clockwise to the vertical mark.
SewTechnical Home
Jun 05, 2014 | Bernina Sewing Machines
Manual for janome my lock 644d
The Instruction Manual for the Janome MyLock 644D can be downloaded from the following link:
http://content.janome.com/documents/File/ManualFile/MyLock644D.pdf
Jan 25, 2012 | Sewing Machines
How to set the needle plate setting nob on the janome 504d overlocker
Sorry, From Left to the Right for the blade...then 1/2 turn to offset blade out of the way to disengage....don't forget to put blade back to correct position !!
Nov 11, 2011 | Janome MyLock 644D
My top thread frays and then breaks while I am quilting with my 1600p dbx.
change to a new needle
check to make sure thread has no knots or even change the thread spool
check the top thread tension it sound like it's to tight
check the needle plate for burrs
check around the tension knob for loose pieces of thread or lint
use a can of air that you'd use on a computer keyboard on the tension knob & if you don't have the can of air use unwaxed dental floss but make sure to write down the setting it was on before cleaning.
& also under the needle plate area in case there is loose threads or lint & also the bobbin area
Aug 11, 2011 | Janome 1600P-DB Mechanical Sewing Machine
Janome MyLock 644D Logo
172 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
