Cars & Trucks Logo
Amanda benton Posted on Nov 03, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
2000 saturn LS1...ignition seems to be locked up. Battery functions, as well as the fuel pump, ignition coil, replaced the starter and crank sensor, and timing gears chain and water pump were all replaced by the dealership a year ago...still engine isnt turning over ... any ideas at all as to what i might try next?!
Jamie Alton
Level 3:
Top Expert:
  • Cars & Trucks Master 1,007 Answers
  • Posted on Nov 04, 2012
Jamie Alton
Level 3:
Top Expert:
Answers
1007
Questions
0
Helped
273141
Points
2955
Check power to starter motor and solenoid. If no power present on engine crank, then check ignition barrel, key and main fuses.If power present on cranking, but starter motor does not energize, then check starter connections and replace starter motor and solenoid if necessary.
Double check starter motor operation with starter removed from the engine. If it works, then check engine condition as this may be seized.
jamiem1416
Level 3:
Master:
  • Master 373 Answers
  • Posted on Jan 21, 2013
jamiem1416
Master
Level 3:
Master:
Answers
373
Questions
9
Helped
78032
Points
1021
Is your car engine turning over, or your key cyliner jammed?
  • jamiem1416
    jamiem1416 Jan 21, 2013
    have you checked your ignition fuse
5 Related Answers
Anonymous
  • Posted on Dec 18, 2008
SOURCE: 2000 chevy blazer, truck cranks
Does your battery go dead?
Anonymous
  • 3 Answers
  • Posted on Mar 09, 2009
SOURCE: vw jetta 1996 gl model engine not staring
Probably the rpm sensor located in the side of engine block under motor mount in front of the starter where it reads the teeth on the flywheel..will cause the engine to turn over and not start or start and shut right off about $124.00 at dealer..
Anonymous
  • 316 Answers
  • Posted on Jun 21, 2009
SOURCE: My 1999 saturn sl2 will
Sounds like a bad timing chain.
Anonymous
  • 365 Answers
  • Posted on Jun 27, 2009
SOURCE: 2000 buick lesabre no fuel system pressure. new
Your PATS security system is faulty...check the BCM up above the glovebox...Seems I've told you this before?
Anonymous
  • 56 Answers
  • Posted on Jul 15, 2009
SOURCE: 2000 chevy venture doesnt start
Not the IAC, or MAF, or 02
Does the Van Crank over?
Have you checked the IGN Relays? 1,2,and 3?
How did the Battery test out?
Anything below 11.9v battery is dead.
So I suggest that you do not throw any more parts and check the battery again.
3answers
2000 Chevy Grand Express 1500 Crank No Start.
Check the ground connections on the ECU computer.
Just replaced starter and 01 saturn L200 will not start
Search Results
    2001 L200 Cranks but won't start - SaturnFans.com Forums
    www.saturnfans.com > ... > Models > Saturn L-Series > L-Series Tech
    Nov 28, 2010 - 15 posts - ‎5 authors
    I have a 2001 Saturn L200 with 69K miles on the twin cam 16 valve 2.2 ... It will crank but will not start unless I put the gas pedal to the floor in ... Saturn L200 Cranks but won't start
    Mar 12, 2012
    2001 Saturn SC2 Cranks but does not start
    Dec 4, 2011
    2001 L200 won't start
    Dec 19, 2009
    Widow in need - L200 will not start - fuel pressure
    Nov 12, 2009
    More results from www.saturnfans.com
    2000 Saturn LS1, Starting Defect - YouTube
    ? 1:37
    www.youtube.com/watch?v=CBNU1IMqaRw
    Aug 9, 2009 - Uploaded by farmerinchico
    The anti theft system in the 2000 Saturn LS1, thinks you're trying to steal the car ... Once the security light is not flashing you canstart the car.
2answers
No spark ferom coil
Probable Causes: Fuel Pump (P0230 to P0233) PCM (P0600 to P0606) Crank Sensor (P0355 to P0399) Fuel Pressure (P0190 to P0194) Chances are the Check Engine Light is not on, but you may find any of the following codes: P0230 to P0233 Fuel Pump codes P0600 to P0606 PCM related codes P0335 to P0339 Crank Sensor codes P0190 to P0194 Fuel Pressure Sensor codes No spark due to a bad crank position sensor, a faulty ignition module or PCM, a problem in the ignition circuit (ignition switch, antitheft system, wiring, etc.), a faulty park/neutral safety switch, a bad ignition coil (only on engines with a single coil ignition), or wet plugs or plug wires (did it rain last night, did you just wash the engine?) A less common cause is a worn starter that draws so many amps while cranking the engine that there's not enough juice left to adequately power the ignition system and fuel injectors. Contributing factors might be a weak battery and/or loose or corroded battery cables. No fuel because of a dead fuel pump, bad fuel pump relay, blown fuel pump fuse, plugged fuel filter or line, or failed PCM injector driver circuit or injector power supply relay. Or, the fuel tank might be empty (don't believe what the gauge is telling you), or the fuel tank might contain contaminated fuel (water or too much alcohol) or the wrong type of fuel (whoops, somebody put in diesel instead of gasoline). No compression because the timing belt or chain is broken, the timing belt or chain is loose and jumped out of time, or the overhead camshaft has snapped.
2answers
I have a 2000 saturn that will not start it is an automatic i changed the starter the alternator and the battery and it wont crank\
Fuel system, replace filter, check fuel pressure and see if its acceptable, or just go ahead and replace the fuel pump so we can rule that out as the culprit.
2answers
I have a 2000 saturn ls1 and i changed the starter alternator and the battery but it wont crank what the problem\
check the timing chain if the engine turns over but want start. coil pack and crank sensor.
CAR WILL NOT CRANK
I gave you more than you should need
a) Do you have crank no start? (see entire write up)
b)No crank no start?, ( battery, battery cables, ignition switch,,starter relay)
c)No dash lights, no crank? (battery, battery cables ignition switch)
If you have symptom A then the affected items are , ignition switch, battery, battery cables, starter, starter relay ,coil, coil pack, ignition module ,Distributor cap ,rotor, (if applicable) spark plugs and wires.
The best thing to do is to first make sure your timing belt didn't break. As long as the engine cranks you can do this. Give the battery a 3 min charge . Then have a helper crank the vehicle while you observe the rotation of all the pulley's and belts. They must rotate together. If the vehicle has a distributor remove the cap ground the coil wire and watch the rotor as the engine is cranked. it should spin. If this is a-ok your worse nightmare is over.
Now we have eliminated the timing belt as being a cause.
b) We now have to charged the battery again for three min and load test it( this is best done by a repair shop a load tester is expensive ).If the battery if more than 5yrs old you may want to replace it.
If battery does not pass load test replace it.
Whatever you decide the rest of the items can NOT be checked out without a fully charged battery.
Check ignition switch and starter relay for B+ going to them and leaving them. Check starter circuit. Make sure B+ is making it to starter ( use a digital voltmeter). If B+ (12 volts) is making it to the starter and it doesn't crank then the starter is defective. Remove the starter and have it bench tested to verify.
a) If starter cranks now your into coil testing .
Pull a spark plug hook it up to a spark tester and ground it, now crank the engine if you get spark coil is ok and in all likelihood so is module.
If you don't get spark test for spark at the coil wire.
If you get spark here and don't get it at the spark plug wire problem is at distributor cap , rotor or spark plug wire. If plugs look bad use a fresh plug to do testing and naturally replace them.
If all of the above are a-ok.
Next is fuel checks.
Easiest fuel check is to put key into ignition cylinder and turn to on position. Lister for pump to buzz or hum. if it doesn't then check fuel pump relay for B+ going to it and leaving it and going to the pump. If B+ making it to pump and it doesn't turn on the pump is your problem. If B+ not making it to pump either the relay or the ignition switch is defective.
Naturally if the pump is defective have a repair shop do the repair . Its dangerous and a real pain.
Good Luck
3answers
My 2000 saturn l series won't start.new battery. seems like it wants to start, just won't catch
If it turns over but won't run, I would check to make sure you're getting fuel and spark. Pull a plug after turning the engine over a few times and if it smells like gas then you're getting fuel, if not then that's your problem. If you're getting fuel, you may not be getting spark. Hold the plug against the engine block and have someone turn the engine over a couple times. You should be able to see spark, but if not then there's your problem. Good luck!
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
