GE washer Replace washer coupler
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
GE washers do not have a coupler. What is your model number?
Posted on Nov 04, 2012
We removed the agitator to replace the coupler and now can't get the coupler removed.
Assuming it's a washer made by GE? Did you remove the bolt in the centre of the coupler? Once you remove the bolt, it should just lift off.
May 07, 2016 | Washing Machines
How to replace agitator
Agitator coupler GE front serviceable washer - YouTube
? 5:02
www.youtube.com/watch?v=4Rf4RO2MGeM
Nov 3, 2011 - Uploaded by theapplianceman Agitator coupler GE front serviceable washer ... How To Repair Washing Machine Agitator - Remove And Replace AgitatorDogs - Duration: ...
Sep 24, 2015 | Washing Machines
GE Washer will not agitate but it will spin
Put old coupler back on transmission shaft. Can you now turn coupler? You should not be able to. If you can, grooves in coupler are stripped out. Replace coupler. Part # WH49X10042
Sep 13, 2017 | GE WDSR2080D Top Load Washer
GE WJRR4170E0WW WASHER spins but does not adjatate.What part likely needs to be replaced?
the most probable thing causing that is a stripped agaitator coupler. This video will show ya how to replace that coupler http://www.youtube.com/watch?v=N26MCQKuXn0
when removing it before buying the part you should be able to hold that coupler up to light and see if it is stripped and the teeth on it are smooth. it should be toothed and and not ground down smooth.
the part number for that coupler is WH49X10049 it can be purchased at your local appliance parts store on online at
searspartsdirect.com
repairclinic.com
apwagner.com
apdepot.com
partselect.com
GENE
Aug 27, 2011 | GE Washing Machines
My ge washer does not wash, it just spins. Help me fix pls.
if you mean it does not adjatate that would be your adjatater coupler grab adjatater at bottom both sides pull adjatater up it will be hard but it will come. when that comes of you will see adjatater coupler remove bolt in center of it that part will pull up. now to replace that part ge changed it about 2 years ago when you get the new coupler you will need the new bolt. 'GE sells that coupler as a kit comes with the new bolt thats the way to go...if I helped you please vote if you need more help please ask good luck
Feb 08, 2011 | Washing Machines
Ge frontload washer seems like it is not aggitating... what would be the problem???
Hello there:
The first thing to check when your GE washer is not agitating, is the belt. Let me tell you how to check the belt & the clutch with out having to take the washer apart.
The belt: Set the timer in the spin cycle and pull the timer knob to turn the washer on.
If the washer drains the water and then spins the way that it should, this tells you that the motor, belt & clutch are not the reason why your washer won't agitate.
A broken belt could be the reason your washer is not agitating or spinning.
The agitator: After making sure that the belt, motor & clutch are working ok, lets check the agitator.
The agitator uses a plastic agitator coupler that is couple to the transmission shaft by using splines cut in the coupler and on the transmission shaft.
Too much usage or overloading the washer too many times will wear the agitator coupler splines. With out the splines the coupler could not be coupled to the transmission shaft and that could be the cause why your washer is not agitating.
The clutch: A bad clutch could also be the reason the washer won't agitate or spin. Usually when the clutch is bad the washer will be noisy, like when you have bad brakes on your car.
The transmission: The transmission could be the reason your washer is not agitating. A common problem with the transmission is oil leaking right on top of the motor pulley and the belt.
As you can see, there could be different reasons why your GE washer is not agitating. You just need to keep checking each part until you find the problem and replace the part responsible.
Oct 03, 2010 | GE WSXH208A Front Load Washer
Washer will fill and spin but will not agitate ge top load washer wwsr3130w0ww
It doesn't agitate If your washer doesn't agitate, check these: Lid switch Motor coupler Belts Clutch Drive motor Drive pulleys Transmission Agitator Lid switch If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. Motor coupler Many washers produced by Whirlpool® use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. If this happens, you need to completely replace it. Belts Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.) Clutch If your washer was made by GE®, it may use a clutch for agitating the clothes. As the clutch wears out, it may prevent the washer from agitating well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician. Drive motor Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor. Drive pulleys The motor or transmission drive pulley may be worn and unable to turn the drive belt. If so, replace the pulley.
Jan 02, 2010 | GE WBSR3140DW Top Load Washer
GE Washer WJSR2080V3WW will fill, spin and drain but not agitate.
The problem is the agitator coupler (about $ 7.00) simply pull straight up on the agitator - Give it a good tug. take the one bolt holding the coupler off - pull straight off. Replace the coupler and bolt (they are sold together). Line the agitator lines up with the coupler lines - when they line up it should go all the way down and snap back into place. and your done.
Sep 01, 2009 | GE WJSR2080V
GE Top Load Washer
There is a plastic coupler piece that goes bad under the agitator. The agitator pulls straight off with a little oooompf. The coupler is bolted to transmission shaft sometimes i have to use a puller to remove coupler as its seized to trans shaft PLEASE rate my help as solved as it darn good
Oct 02, 2007 | Kenmore 24872 Top Load Washer
GE WPRB9220D Top Load Washer
There may be nothing wrong with the splie/gearbox shaft. At the top of the agitator on the inside is a brass "dog" That may be worn and you will need to replace it.
Oct 28, 2006 | GE WPRB9220D Top Load Washer
Washing Machines Logo
15 people viewed this question
Top Washing Machines Experts
