Can i get dirctions on how to pull out a 2003 alternator on chevy calvlier
Alternator bad.. Im a girl.. but i think i got this under control gina / send dictions to kkornbreadandchicken@yahoo.com please
  • 7,365 Answers
Hi Regina
you problem was put in the sewing machine catagory
if you will put it in the car catagory, I'm sure you will get some help
Posted on Nov 05, 2012
2 Suggested Answers
  • 75 Answers
SOURCE: My account has occured h_hovakim@yahoo.com
Check the following link
https://edit.yahoo.com/forgotroot?done=&src=&partner=&intl=us
Choose: My account may have been compromised
follow the instructions on screen.
Fill your personal information that you used to create account.
They will send you your password to your alternate or new email id that you provide.
If above does not help then you need to contact them in
account-security-help@cc.yahoo-inc.com
Posted on Jul 21, 2010
03 ford focus replaced alternator checked charging system still not charging have power to alternator from battery light comes on after 10 seconds while running new battery, it only shows battery voltage...
Im no expert but my kids older car had several alternators replaced. 2nd one was bad.. We got one new and one rebuilt. I think the rebuilt worked a week and car died again.
Sep 07, 2013 | 2003 Ford Focus
How to put in 2003 chevy calvlier alternator my self
1) Open driver's door window (in case the car auto-locks shut), remove keys from car's interior, and disconnect the vehicle's battery's negative terminal wire and tuck it away, making sure it cannot touch the battery negative terminal (you might wrap it in a cloth, just to make absolutely sure) (make sure you have any stereo security codes, before disconnecting this). Also make sure you have any alarm system turned off, or have the key to do so.
2) Remove the alternator drive belt. Serpentine belt types require a spring tensioned pulley to be forced against spring pressure, away from the belt in order to remove the belt (MAKE SURE you take careful note of this belt's route for easy refit. Take a photo if necessary!). Traditional tensioners require a locking bolt to be slackened and then an adjustment bolt to be slackened, plus affixing bolt to be slackened in order to freely remove the belt.
3) Disconnect the wires from the back of the alternator unit. You may typically have one plug connector and one or two heavy duty wires on the back.
4) Remove any remaining alternator fixing bolts which are keeping it affixed to the engine block, and remove alternator.
Refit:
1) Locate alternator position and lightly screw in all affixing bolts (do not tighten if using traditional type, manual tensioner). Tighten if using a serpentine belt tensioner (spring loaded type).
2) Re-attach all wiring and check for tight connections.
3) Replace drive belt. If using traditional tensioner, then manually adjust the belt tension so that you can twist the belt to about 90 degrees when tight, no further.
4) Clear the engine bay of all tools, reconnect vehicle battery negative lead.
5) Restart vehicle.
6) Listen for belt squeal (may need tightening further if manually adjusted). Take note of dashboard charge warning indicator. If illuminated, then check battery connections and alternator connections.
7) If you have a multimeter, then check voltage across battery terminals with vehicle running. Voltage should measure around 14Volts with a healthy alternator fitted.
8) After running for a few minutes, stop engine and recheck belt tension if using a manual tensioner. BE CAREFUL of any hot areas as these may burn. If in doubt, then wait until the engine is cold and re-adjust if necessary.
Job Done!
Nov 03, 2012 | Cars & Trucks
2008 CTS front directional not working?
Try replacing ALL directionals for the side that is not working properly. That fast blink in the back usually means bad bulb, but could also mean bad relay.
Can you elaborate? You say emergency flashers work, but FR directional does not. Does the bulb-in-question light when the E-flashers are going?
Oct 19, 2012 | 2008 Cadillac Cts
I have just bought a mazda etude but not sure if it has a faulty battery or a faulty alternator how can i find out by the way im a girl that really has no idea when it comes to these things on cars . when...
If it stopped on it's own, the alternator is bad. Replace the alternator, jump start the car and hopefully the battery will heal itself. And you don't have to apologize for being a girl--there are plently of guys asking dumber questions than this!!
Sep 17, 2010 | 1999 Mazda 626
2003 chevy truck 6.0 liter gas. knock senser bad is it located under intake manifold? i just got a quote for $800. Is this reasonable?
2003 6.0 2wd When I put in reverse dash goes dark and gauges dont work for like several minutes? Any one have a clue?
Jun 29, 2010 | 2003 Chevrolet Silverado 2500HD
2003 Chevy TrailBlazer..bad rattling under truck and feet.
It could be a bad rear blower motor, or resistor? theres a lot under the truck that could make noise, have a repair shop check it and make repairs.
May 13, 2010 | 2003 Chevrolet TrailBlazer
Mower will start but when I pull back on the self propelled handle it doesn't take off, you have to push it still. The self propelled cable has came loose from down under the plastic piece that covers the...
Im a girl and I fixed it myself, yay! The cable had broke down where the self propel is at and came out of the eye that it was to be in so i re-wired ti back. Anyways Im glad I didn't get a response on here cause I got a bad steer about my tv and i think you just are guessing and hope people don't bother any longer and that you have lucky guessed. thanks anyways
Jun 02, 2009 | Troy Bilt 5.5hp Self Propelled Mower
2003 Chevy Silverado 1500 Error Codes
P0135 is a bad 02 sensor
P0442 is a evap problem
P0449 is a vent solenoid
i would check the vent solenoid first its a 4ws fuse under the hood in the fuse box make sure you have power to it you should have power at all times the ground comes from the pcm i think if you fix this everything else will work they are all computer controled
Mar 23, 2009 | 2003 Chevrolet Silverado 1500
Computers & Internet Logo
David Payne
David Payne
