Question about Frigidaire Affinity ATF7000E Front Load Washer
E91 after replacing control board i get an error e91
  • samiams74701
    samiams74701 Nov 03, 2012
    I have checked the wiring and all is good, the selector lights work i have also left the machine unplugged for over 30 minutes and i still get the error.
  • Official Brand Answer
  • 4,342 Answers
Hello - Typically error code E91 on Frigidaire washer indicates a communication error with the user interface to main control board. A certified technician will need to check the wiring between both parts. Either part could be defective or unit may possibly have faulty wiring. Depending on the diagnostic either or will need replacing.
Posted on Nov 05, 2012
What does it mean when my Frigidaire professional series dishwasher has an error code of 91 and the China/Crystal setting light is illuminated?
Rod, Try unplugging or turning off breaker for ten minutes to reset. If this does not fix, you may want a good Tech. have a look, diagnose and estimate repair.
Code E91 could be User Interface to Main Control Board communication error. Communication problem. Check the wiring between the Main Control Board and the User Interface Board. Wiring bad, correct wiring problem. Wiring good, replace the User Interface Board. If the problem is not corrected, replace the Main Control Board.
What Is Error Code 91 On Frigidaire Dishwasher Professional Series
http://www.manualsonline.com/support/frigidaire/dishwasher/error-code-91-5195801
http://forum.appliancepartspros.com/washer-repair/476079-error-code-91-a.html
http://www.elektro-ivicic.cz/data/user-content/soubory%20ke%20stazeni/Electrolux-chyby.pdf
Jul 14, 2016 | Frigidaire Dishwashers
AEG L87480 on desplay makers E91 what means
E90 is family error code visible to the customers. It is necessary to read the error in the service mode so please proceed with the following procedure for rapid reading of alarm codes:
Press and hold down START/PAUSE and the option button nearest to the START/PAUSE button for at least two seconds!
After that the display will show one of the following errors that are more precise:
E91, E92 - Communication incongruence between main board and display board (versions not compatible). Posible causes: wirings, main board or control/disply board.
E93 - Incorrect configuration of appliance. Posible causes: Incorrect configuration data; electronic board faulty.
E94 - Incorrect configuration of washing cycle.
E95 - Communication error between microprocessor and
EEPROM. Posible causes: Electronic board faulty.
E97 - Incongruence between programme selector and
cycle configuration. Posible causes: Faulty electronic board (Wrong configuration data).
Considering that this is a complicated fault, my advice is to contact an authorized service center.They have special equipment such as an interface that allows them to upgrade software in your appliance. If you are not doing anything on the appliance before the failure, the only thing you can check is the contacts between wiring and electronics.
Dado
Jan 11, 2016 | AEG Washing Machines
Error code e 91 for frigadare affinity dryer
most likely faulty control board...........
cheers
Apr 05, 2015 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
Electrolux washing machine wh1092 when turn on lights 1,4 and 8 flashes. Nothing happens
If I understand correctly there is blinking LED-s from "Prewash","Rinse Hold" and "End of cycle". In binary code it is fault E91 what means communications error between main PCB and display board.
So, could be: main electronic PCB, display board or wiring.
Dado
Dec 13, 2014 | Electrolux Washing Machines
What's the meaning of E91,and F47 error codes on
Use Google to get the answer
GM/Cadillac OBD1 Codes E91 & F47
Aug 22, 2013 | Cars & Trucks
Frigidaire affinity front load washer, my power went out and came back on, now the washer keeps beeping 3 beeps about every 30 seconds. Error code E91 will flash up when I push any button
Hi bsful1 - Typically, E91 indicates that the main control board has gone bad or is not communicating correctly. Before replacing this part, I would first recommend resetting power to the unit for about ten minutes. If the error code still displays, it is advisable to contact an appliance repair tech to accurately diagnose and make the appropriate repairs.
Apr 11, 2013 | Frigidaire GLTF2940ES Front Load Washer
Error Code E91
E91 is for the control board failure and needs to be replaced. Here is the part to order. To replace the board remove the top of the unit.
Dec 05, 2012 | Frigidaire ATF6000ES Front Load Washer
Atf6000es error code E91
Hi Angelia,
E91 means that there is a communication problem with the user interface to main control board. You will need a certified professional to check the wiring between the main control board and the user interface board to determine which part has to be replace.
Sep 12, 2012 | Frigidaire ATF6000ES Front Load Washer
FLASH ERROR E91:01 ON DSC-T5
Replace its A-1075-328-A ST-113 BOARD, COMPLETE problem will solve after replacing Flash Assy
Nov 25, 2008 | Sony Cyber-Shot DSC-T5 Digital Camera
Frigidaire Affinity ATF7000E Front Load Washer Logo
678 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
