Question about Protron PLTV-37 37 in. LCD Television
Control panel The volume wont go up or down and the channels wont go up or down either. The remote control wont function with the tv either.
  • Protron Master
  • 8,617 Answers
The remote or the Tvs IR sensor are the two most likliest causes of that issue.
Posted on Nov 04, 2012
2 Suggested Answers
  • 121 Answers
SOURCE: The channel keeps moving backward randomly, I
If the TV is basically behaving like the channel back button is always being pressed then that may indeed be the problem. Manipulating the button on the TV itself (you have correctly eliminated the remote as the possible problem) by repeated pressing of that button and making sure that it not hung up on the chassis does not resolve the issue then I am afraid that a trip to the repair store is in order.
Posted on Feb 25, 2009
We purchased a tv from a school channels only goes up to 02-13 cannot go any farther. We are using a universal remote that when we go to menu to channels it doesn't allow you to either enter or delete...
U can't do much on a universal tv remote.Only the basic mostly,like power on/off,channels up/down and volume up/down that about it.If u wanted more functions and controls and adjustments inside of the tv Menu for options like changing and adding functions.U must have the tv original remote to be able to do it.Try website like Remotes.com to buy the tv orignal remote.
Aug 29, 2011 | Philips 32MF231D Television
Urc22b remote control
Did you try this code-0866
Let me know if this worked.
Jul 02, 2008 | Televison & Video
Sansui TV/VCR/DVD combo
This solution is provided by one of our experts premtech
Child Lock
Combos
--Should have original remote. Press and hold the power button for 6 to 10 seconds
Combo Model T25208, V-Chip Forgotten Password
If you forget your password, simultaneously press VOLUME down on the TV/VCR front panel and the 0 number button on the remote for a few seconds. This resets the password and you can enter a new one.
Combo Model 13TVR62, V-Chip Forgotten Password
If you forget your password, press STOP/EJECT on the TV/VCR front panel and MENU on the remote simultaneously. This resets the password, but not the limits you’ve set.
Televisions with Parental Lock Feature
If you forgot your password for this feature, press the following buttons on the remote, one at a time. (Note: You must be in the password entry screen) Press, Mute, Display,Clear and Reset, this unlocks parental controls and you can now re-enter a new password.
OR TRY THIS..
Press and hold Menu on the TV AND volume down on the remote for 3 seconds. Nothing will appear on the screen, and the Parental Controls will unlock, and you can re-enter a new password with the LOCK PARENTAL CONTROLS
CTC169AU
Channels that have been locked can be viewed only when the PARENTAL CTRL function is set to OFF. This can only be done with the remote control-it can not be changed with the buttons on the front of the TV.
Therefore, after you turn on PARENTAL CTRL, you simply hide the remote control so that your children can not watch the locked channels. The locked-out channels will remain unviewable even if the TV is unplugged or the channels are autoprogrammed again. The only way to view locked channels is to use the supplied remote control to set the PARENTAL CTRL function to OFF.
The PARENTAL CTRL and the CHAN CTRL functions work hand-in-hand. The instructions below will first tell you how to turn parental control on or off with the PARENTAL CTRL function and then how to lock desired channels with the CHAN CTRL function.
1. Repeatedly press MENU to select SETUP MENU, and then press + or - to display setup functions. Repeatedly press MENU to select the PARENTAL CTRL function. . When this function is set to ON, PARENTAL CTRL is activated and any channels you locked with the CHAN CTRL function will not be viewable. . When this function is set to OFF, PARENTAL CTRL is deactivated and all channels are viewable.
2. To lock channels, press the MENU button to select the CHAN CTRL function. Select a channel you want to lock by pressing CHANNEL up or down. Then press +. The CHAN CTRL setting will change from NORMAL to LOCKED when that channel is locked. To return the channel to NORMAL, press the - button. Repeat step 2 for each channel you want to lock. If the PARENTAL CTRL function is set to ON while you are locking out channels, each channel will go blank as you lock it. When the PARENTAL CTRL function is set to ON and a channel which has been locked out is tuned, the TV will display the words PARENTAL CONTROL to let your kids know you have locked it.
CTC185's
If the front panel function buttons don't work, (menu, ch up/dn etc.) but the functions work normal with the remote, enter the "Channel" menu with the remote and turn "Parental Control" off.
CTC203's
In the event you have forgotten your password, perform the following procedure:
Press and hold for 3 seconds the TV button on the remote while pressing the menu button on the TV.
This procedure will turn off the parental lock and erase the previous password .
Another Possibility To Try For Various Models: If TV's in the Parental mode and askes for a password that's forgotten, Press menu on the TV, select Parental Lock #4 on menu, then with the remote press Mute, Display, Clear, and Reset buttons in sequence.
TX808 Chassis
If Parental Controls have been set and you don't know the password, do this:
Press and hold the volume down and the channel up buttons at the same time for 5 seconds.
Now you can reset the password to 0000, and using that password you can now access the V-Chip menus.
TV's (Made by Daewoo or possibly Apex, ie. GE model 24GP653)
The factory default pass code of 6688 is also the override code, in case the owner forgets their pass code. If that doesn't work, another place in the owners manual says to push Function and Mute on the remote at the same time. Function is the top right button.
Jun 28, 2008 | Sansui DTV2760 27" TV
My samsung le32r74bdx remote control wont change channels and cant turn volume on tv up or down
You can verify that the remote is working. Get a digital camera with a LCD display.
Aim the remote at the camera lens and press the volume and channel buttons. If you do not see
a flash through the camera the remote is bad or the batteries are dead.
If you know someone with any samsung hdtv remote, you can borrow it and try the volume/channel
to see if the tv remote receiver is good.
Feb 08, 2011 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Menu keeps flashing remote control wont work, cant change channel or volume.when i hold down channel up andmess with remote sometimes it changes channel. channel down button is only one that doesnt change...
U have 2 situations:
1st U have a tv Key stucked or internal control board defective.
2nd U have a broken tv remote control.
Note: Check for stuck pressed keys on TV, if not send to repair shop, for checkup.
Nov 29, 2009 | Insignia IS-LCDTV32 32 in. Television
TV won't stop changing channels
Main board needs replaced !
Jul 03, 2009 | Televison & Video
Menu will not come up. Channel will not change. No remote.
brendee89,
I did not get who the manufacture was of the tv but you may want to see if one or more of
the menue buttons are stuck down on the tv's front panel. This has been a common cause of
problems with Mitsubishi and Sony tv's. It could also cause volume to go up by it's self, no menue
functions, no power up and or no remote control functions to work.
Hope this helps,
Skyman
Jun 16, 2009 | GE 19GT317 19" TV
Sky remote wont control on/off , volume, or terrestrial channels
Press tv on the Sky remote
press and hold select and red until the led blinks twice
type in 0 0 6 0
press the power button, if the tv turns off then the press select and the remote should work all the tv functions.
If the tv does not turn off then press tv then the power button and keep doing this until the tv turns off, once it turns off press select and it should work.
If you have any problems let me know
Dazz
Feb 15, 2009 | Samsung LW20M21C 20 in. LCD Television
Parental lock
Child Lock
Combos
OR TRY THIS..
CTC169AU
CTC185's
CTC203's
TX808 Chassis
Mar 26, 2008 | RCA TruFlat 27F520T 27" TV
No input channels
Universal remote control are normally programmed for basic functions, ie. chennel up down, volume up down, numbers, etc. This is even written in the manual that they do not guarantee that all functionality can be used. Here are your options: 1. Try all the codes that match your TV, there is a slim chance that the other code have the functionality that you need. 2. Buy the original model remote control. 3. If you know of someone that have the same TV, buy a universal remote control with 'learning' function and copy the signal from the original remote control. I have the same problems before. Now I use my Casio wrist remote control to copy the special functions such as A/V so that even if the original remote control is lost, I can still use these functionality
May 23, 2007 | Symphonic ST419E TV
Protron PLTV-37 37 in. LCD Television Logo
43 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
